Old 10-31-2012, 12:12 PM   #1
JayWoop
Drives: Nissan R34 GTR
Reverse
I've Always wondered how does the gear shifting work if you want to put it into Reverse gear? there has to be a safety measure right what if you think its in gear 1 and it goes reverse into a wall.. haha
JayWoop is offline   Reply With Quote
Old 10-31-2012, 12:15 PM   #2
xn7485
Drives: 1995 Acura Integra GS-R
You gotta pull up on the shifter boot to shift into reverse.
xn7485 is offline   Reply With Quote
Old 10-31-2012, 12:20 PM   #3
empower-auto
Kouki-Monster
empower-auto's Avatar
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following 8 Users Say Thank You to empower-auto For This Useful Post:
ALbadboy (10-31-2012), CaptainSlow (10-31-2012), enjoi23 (10-31-2012), joshua (10-31-2012), neutral (10-31-2012), Plxdjake89 (10-31-2012), Subie (11-03-2012), zaptorque (11-01-2012)
Old 10-31-2012, 12:34 PM   #4
CaptainSlow
CaptainSlow's Avatar
Have you even seen an FRS?
You pull up on the black piece under the shift knob, then push left and up. The shifter will not move over unless you lift up on that piece (will only go so far as the 1/2 gate)
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-31-2012, 12:36 PM   #5
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Pretty much IMPOSSIBLE to put it in reverse by accident... Took me about 30 seconds to figure out wtf was going on when i went to test drive...
RedRocket is offline   Reply With Quote
Old 10-31-2012, 12:41 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
All 6 Speed gearboxes have a safety feature that prevents you from doing just that.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-31-2012, 12:43 PM   #7
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
With some of these threads you would think this is a 'new to cars' forum more than one that supports a sports car.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
GenkiElite (10-31-2012)
Old 10-31-2012, 01:20 PM   #8
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Hey, if a guy hasn't seen one and never drove a six speed how is he supposed to know.
There's a lock out feature that makes it impossible to accidentally put the car in reverse. You have to pull up on a ring that is below the knob and while holding that ring in the up position only then can you put the car in reverse.
whaap is offline   Reply With Quote
The Following 2 Users Say Thank You to whaap For This Useful Post:
Ft-86 Please (10-31-2012), Guff (10-31-2012)
Old 10-31-2012, 01:24 PM   #9
empower-auto
Kouki-Monster
bingo bango bongo
Rich Anderson
EMPOWER AUTO
The Following User Says Thank You to empower-auto For This Useful Post:
SSchifko (10-31-2012)
Old 10-31-2012, 01:28 PM   #10
hippari
I Love your GUCCI Wheels!
hippari's Avatar
Drives: Raven Black FR-S
Send a message via AIM to hippari
R34 skyline gtr's are 6 speed though...
@jinxyboi | @_iLLdynasty
Rice for the Rice God
hippari is offline   Reply With Quote
The Following 5 Users Say Thank You to hippari For This Useful Post:
enjoi23 (10-31-2012), Guff (10-31-2012), lbroskee (10-31-2012), Subie (12-03-2012), Synack (11-01-2012)
Old 10-31-2012, 01:40 PM   #11
CaptainSlow
Every manual transmission will have some kind if feature...some have to press down on the stick, some lift a ring, some press a button, and some are just electronic lockouts. If none of those were there it would just grind (unless you did everything in your power to force it in, in which case you deserve that repair bill payment).
Old 10-31-2012, 01:47 PM   #12
Kunzite
Drives: Toyota Auris
For 6 speed manual transmissions (there could be exceptions).
For 5 speed transmissions, some don't have such protection mechanism; and I know (old) cars with 4 speed transmissions, on which the reverse is where the 5th would be (no protection, either).
Kunzite is offline   Reply With Quote
Old 10-31-2012, 01:57 PM   #13
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
The fun part is switching between driving my 6 speed and 5 speed cars. The Miata's 5 speed is geared so you're at 4k rpm on the highway - so if you forget which car you're in, there's that natural inclination to shift into 6th - well, except that's exactly where Reverse gear is on the Miata!
ashtray is offline   Reply With Quote
Old 10-31-2012, 04:30 PM   #14
Aetyrno
Drives: 98 Camry
Every car I've ever driven had it. '84 camaro 4 speed, you had to physically push DOWN on the shifter from center neutral, then right and down (same as 6th gear position would be) to get reverse. '00 Neon has a lockout that prevents you from going into R from 5, if you pull straight back it deflects it into 4th. You have to let it settle into neutral before it'll go to R
Aetyrno is offline   Reply With Quote
help! reverse light not working nab335 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-14-2013 06:59 PM
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 10:18 AM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 09:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 11:21 AM
