Old 10-31-2012, 11:01 AM   #15
gmookher
Originally Posted by SleekMachine View Post
I installed this like 30 mins ago and I don't like it at all.
The shifter now makes excessive noise - whenever I put it in gear there is now a winding noise. Also, at low rpms you can hear this winding noise. In cabin noise is obnoxiously loud.
When I downshift the winding noise increases significantly and has an extremely large amount of resistance compared to stock; as if I am forcing the gear in. At one point I was worried that I was damaging the gears, so I left it in neutral and braked.
Maybe I'm the only one with this issue, but I'm going to get it removed.
Also, Yes I have it in the correct orientation.
so far sounds like the only one. its a simple install.
post a pic of your install please. that sounds all wrong. Whatever happened i suspect will continue if you reinstall the old part but DO let us know how that goes
something went wrong in your install I think. The part locates the rear end tang in the same location and orientation.
Old 10-31-2012, 12:35 PM   #16
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Sorry about that, it sounds like something is off for sure. There will be a little more vibration, but it's far from being obnoxious or loud.
One thing we'd like you to check is the metal sleeve inserts in the bushing. Do they seem like they're longer than the bushing? If it's not that, maybe something wasn't tightened up?
PERRIN_Chris is offline   Reply With Quote
Old 10-31-2012, 06:38 PM   #17
SleekMachine
SleekMachine's Avatar
Drives: Whiteout
Originally Posted by Panman View Post
Did you support the gearbox with a jack/lift during install?
Are you sure the driveshaft/propshaft was bolted back in correctly?
This sounds nothing like a bushing issue - I'd get a professional to check it ASAp
I did the whiteline kit at the same time and I assure you that it was supported and everything was bolted back. My friend owns a shop we did it together, trust.
SleekMachine is offline   Reply With Quote
Old 10-31-2012, 06:40 PM   #18
SleekMachine
Drives: Whiteout
Like you said simple install, could not be simpler. The only hard part is when working on the floor without a lift. As I said before, the orientation is correct.
The orientation is the same as the second to last picture from op, where the bushing mountain is on top and the bulge is facing the gearbox.
Old 10-31-2012, 06:41 PM   #19
SleekMachine
Drives: Whiteout
I'll check the metal sleeves today, prior to installment I believe the sleeves were not longer than the bushing.
Old 10-31-2012, 09:05 PM   #20
fl_speed001
Drives: Whiteout FR-S
Interesting, first I have heard of this. I have one ready to install when my break in is over and modding begins. Definitely interested to hear how this turns out.
fl_speed001 is offline   Reply With Quote
Old 11-01-2012, 03:22 AM   #21
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Hiya!
I'm currently doing the install. I've take out the OEM bushing and I'm about to install the PERRIN bushing.
One question. I undid the clamps that were holding the drive shaft, but when I undid them the driveshaft went down towards me about 4-5inches(it did not fall completely) and I heard a kind of vacuum sound. The shaft probably went out about 3-4 inches but I managed to catch it before it came out completely. Would there be any problem with that?(im a newbie)
stevo_12v is offline   Reply With Quote
Old 11-01-2012, 05:34 AM   #22
SleekMachine
Drives: Whiteout
Checked the sleeves and they are fine, everything is fine. I went down under to do an engine, trans, diff fluid change. After the fluid change the shifting felt a lot smoother, but still pretty notchy on 5th and 6th gear. Also, the noise level did go down, but it's still louder than stock.
The Following User Says Thank You to SleekMachine For This Useful Post:
vignesh (12-18-2013)
Old 11-01-2012, 07:29 AM   #23
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by stevo_12v View Post
Hiya!
The drive shaft connects to the gearbox and diff mechanically so that vacuum like noise shouldn't be because of that. Are you saying your shaft came out like detached? Ours was able to fall a few inches and sit on the exhaust
F1point4 is offline   Reply With Quote
Old 11-01-2012, 08:27 AM   #24
stevo_12v
The shaft came out, probably a couple inches. The 'bent' part of the shaft went down about the same level as the exhaust, it didn't fall out though. I put it back in and finished the Perrin/Cusco install I just did, no CEL lights and no drips. I hope everything is A-OK.
Old 11-02-2012, 06:24 PM   #25
twodollarcuts
Drives: Subaru BRZ Limited
Let us know how that goes. I'm thinking about installing one myself.
twodollarcuts is offline   Reply With Quote
Old 11-03-2012, 12:18 PM   #26
stevo_12v
It's pretty good mod. Shifts are real nice and smooth, less 'lurch'.
Old 11-04-2012, 07:26 PM   #27
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Installed it yesterday along with the whiteline insert, but didn't notice any real difference from stock as far as shifting goes...
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 11-04-2012, 07:50 PM   #28
gmookher
I guess we are all sensitive to a different level. Both wife and I noted a post install improvement.
The Following User Says Thank You to gmookher For This Useful Post:
rene0023 (10-03-2013)
diy, perrin, rear shifter bushing
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 03:48 PM
