Old 10-31-2012, 12:52 AM   #1233
AVOturboworld
Originally Posted by Calum View Post
@AVOturboworld, what is the REV limiter set to in your tune? Are the racerom features included? John Visconti has posted about ECU controlled boost and the possibility of adding an ECU controlled meth kit. Are these things possible upgrades with your kit?
Those will be possible upgrades, yes. We just need to test everything thoroughly as they come out, and will add in features as we can.
Old 10-31-2012, 01:00 AM   #1234
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by AVOturboworld View Post
We've logged oil temperatures in all conditions, never had any issues, not even in the desert. Same for the water temperatures.
The breather tank is there for monitoring purposes, it's not specifically designed for the FR-S, which is why it has the dodgy bracket I made up just for testing. I ran it for over 2000 miles in n/a form (no blow-by), now running it on the turbo setup to check.
It's already been addressed by others (thanks Bob@drift-office!), but to clarify, the base map as we are calling it is a daily driver tune. If we were simply making it safe to run to the tuner, we'd have been done a long, long time ago. We are creating a safe, smooth, fun to drive tune that works with 91+ octane pump gas. The reason it's called a "base map" is that it's not a tune specific to your personal vehicle.
Seriously, we've put a lot of long, long hours on the road and on the dyno to get this right for everybody, and I think I can confidently say, you won't see that from any other kit on the market. This is a kit designed to have the fit, feel, and reliability of a factory upgrade, just as if Subaru had done it. Except better.
It doesn't mean you cannot upgrade to higher performance with this kit, it means we are getting the stage 1 right from day one.
As far as upgrades, what kind of turbos will bolt in to this setup?
Tansey86 is offline   Reply With Quote
Old 10-31-2012, 02:40 AM   #1235
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Question Tune Info??
Originally Posted by JSK View Post
Will there be any other tunes available from AVO? Like for us Canadian guys that run 94 octane?
Same issue here in Dubai UAE, will there be a tune for different octane ratings? We got standard rating of 95 and premium of 98 octane.
The JDM tune that runs up to 250whp, what octane fuel was that??
Also what is the intercooler's HP rating, for future mods reference??
Thanks
ahaghshenas is offline   Reply With Quote
Old 10-31-2012, 02:50 AM   #1236
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Hey Guys got a question from your press release.
http://www.avoturboworld.com/index.p...news&Itemid=31
Turbo Specifications:
AVO18/49 Turbocharger with 5-7psi actuator - compressor wheel size 49.2/56 | exhaust wheel size 50.5/68
This specially designed AVO18/49 turbocharger comes with a 5-7 psi actuator for precise boost control at lower psi levels, ensuring engine longevity. The turbocharger is rated for 380hp of flow, so there is certainly headroom available with it from the base stage 1 kit, which is doing 276hp on 92 octane.
You say that this is a a 5-7 psi actuator for precise boost control at lower psi levels.
With this in place how can we run higher boost once we change the MAP sensor so it can support more boost?(as I read this was the limiting factor early in this 57 page thread).
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-31-2012, 04:15 AM   #1237
invisage
Drives: Thunder Silver 86 GTS
I'm pretty sure they are selling a complete tune, it's just optimized for 91 octane and low pressure. So there may be tunes for more power down the road. Personally I'm hoping a meth kit will be used for the stage 2. Combined I could see this kit making ~300 Whp. But that purely my uneducated opinion.
Emailed them about a possible meth kit a few weeks ago and they said they don't work with meth or e85.
invisage is offline   Reply With Quote
Old 10-31-2012, 04:56 AM   #1238
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
At laaaast! Thank you, Lord!
some questions though:
1) how exactly the oil pump is driven by the camshaft? do we have to drill in the head severely or there is a technological window?
2) if I will be running 93 ( 98RON Euro ) fuel and a full 2,5" exhaust - would that lead the car run out of maps you will be providing along ( or did the final testing include full freeflow exhaust) ?
3) also interested in ECUTEK features provided ( launch, FF-shifting, etc )
4) have you discussed possibility running Speed Density - oriented flash? That would be a nice option for the guys wishing to leave stock MAP sensors...
MSTiFK8R is offline   Reply With Quote
Old 10-31-2012, 06:39 AM   #1239
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Thanks. That's all I really wanted to know, from the horse's mouth
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 10-31-2012, 06:49 AM   #1240
ahaghshenas
Drives: Subaru BRZ
Octane rating
Thanks
Did a little research on octane ratings and have found that over in the US, you use a different octane rating system [Anti-Knock Index (AKI)] where as pretty much the rest of the world uses [Research Octane Number (RON)].
So the fuel here is not as great as I thought.
The standard is 95 RON = 91 AKI
The premium is 98 RON = 94 AKI
loads of info on Octane rating on wiki
http://en.wikipedia.org/wiki/Octane_rating
Old 10-31-2012, 08:42 AM   #1241
2forme
I would assume an MBC or EBC.
Old 10-31-2012, 09:32 AM   #1242
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
also which oil would you recommend to run instead of stock 0W20 ?
cooling the turbo down needs more head dissipation = extra load on the oil
I got my DEFI oil press\temp gauge installed recently
On a warmed engine (90С\190F oil) engine runs 1-0,9 bar \ 13-14 psi oil pressure
On the road the oil pressure seems to follow the tacho pretty fast and pretty straightforward in most cases - 2K rpm for 2bar \ 30psi , 3 for 3bar and so on till the bypass at 6 bar \ 87 psi sharp , no matter how you redline the engine
of course, when it's cold, the oil press could be higher
I wonder how safe is running 13 psi idling on this waterish 0-20W
I got used to see 30+psi idling on my EJ20's and EJ25's , but the oil viscosity I used was never lower than 10-40, mostly 5-50 and 15-50
Maybe there is a sense to reconsider oil viscosity, what would you say based on your monitoring for FRS?
Old 10-31-2012, 11:45 AM   #1243
AVOturboworld
The same way on a standard turbocharged vehicle, via an electronic or manual boost controller, or with a higher psi boost actuator. AVO has new billet actuators coming out with adjustable springs. Actuators set the minimum psi the turbocharger will run at before it cracks the wastegate open to bleed off unneeded boost.
The reason it's essential to have a low psi actuator is so that you can even run a turbo at those boost levels. One of the reasons turbocharging a n/a subaru motor was considered dangerous back in the day was due to people slapping a standard wrx turbocharger on it - which had a minimum 8psi actuator. About 2-3 psi past what they could reliably run.
It's a key factor in any of our turbo kits for n/a vehicles, testing them for the boost levels they can run, and making sure we engineer the kits to run at those boost levels. That's why we have customer that have been running those kits on their cars for 5+ years, a few even 10.
Old 10-31-2012, 11:53 AM   #1244
2forme
I think some would be interested in the adjustable actuator (essentially an MBC) when running e85. I can already see some people grabbing the kit and getting a separate e85 tune.
Old 10-31-2012, 12:04 PM   #1245
AVOturboworld
It bolts on.
No, seriously. It does. It's amazing. Both oil return and feed bolt onto the head. We did some serious work with this kit.
It'll run ok on that setup, but remember, these are base maps, non-specific to any vehicle. No matter what, for best power/reliability, you should get a tune specific to your car on your local fuel in your country. The tune we provide is very similar to a Cobb Accessport Stage 1 tune. Off the shelf, safe mapping that's only designed for a specific hardware set.
We'll leave that up to individual tuners. We have reservations about SD due to the need to compensate for elevation changes.
Old 10-31-2012, 12:07 PM   #1246
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
SD only for the big power guys. Any change to VE and elevation would likely require a re-tune. I'll keep the maf, thank you.
Coheed is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
