Old 10-30-2012, 09:39 PM   #1
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
JDL Header & Exhaust System Development
We wanted to start this so we can share our exhaust development with you all. Ill update the first post as we get more prototypes done. If you have any questions let us know. We would also like to hear your thoughts ect
Product Development Plans
- Equal Length 4 to 1 Header
- Unequal Length 4 to 1 Header
- Stainless Steel Overpipe
- Catted Front Pipe
- Non Catted Front Pipe
- Staines Steel Dual Muffler Catback
- Single Exit Titanium Catback
Now onto the pics We will have this bad boy welded out and on the car in a few days
Just needs some O2 bungs
Update 12/6/12
From the header back will be dyno'd and added to the site by the end of the week. A few product shots for now
Catted front pipe
Engine back sigle exit system
Here are some on car shots. Sorry they are grainy, no tripod today
Collector analysis
Originally Posted by Lee@JDLAutoDesign View Post
Sorry for the wait guys! We saw an opportunity to do some analysis and hopefully improve our merge collector design and then leverage this design for both the equal and unequal length headers. Doing some of these design iterations analytically ultimately reduces the amount of building and testing we have to do so the end result is better products making their way to the customer sooner.
In my mind, the merge collector can make or break the success of the header design. If the collector design is effective, it can reduce the upstream exhaust pressure (for a given flow rate) and thus reduce parasitic losses associated with a cylinder having to "pump" out it's own exhaust. Obviously harmonic tuning plays an important role in cylinder evacuation, but the strongest exhaust harmonics are primarily tuned by runner length. A good merge collector can also minimize the mixing losses associated with 4 out of phase cylinders entering a common passage.
I'll spare most of the analysis details unless people are particularly interested, in which case I would be happy to elaborate. The gist of it is, I designed several collector profiles and then compared the resulting flow fields to the "baseline" collector design that has already been built and tested. I repeated these CFD runs for a range of exhaust flow rates to see if the benefits I found were across the board or only at a specific operating point. When I say a "benefit", I'm referring to reduced pressure losses across the collector. This benefit will be realized via reduced backpressure to the exhausting cylinders (and hopefully more power!).
Here is my model of the baseline collector:
The figure shows contours of X-Direction Velocity. The most obvious loss sources here are the large separation regions (dark blue) downstream of the collector throat and the wake that forms in the mid passage from the boundary layer of the inner wall.
An obvious way to reduce the pressure loss is to reduce the wall slope on the expanding section of the collector. Here is a model of the baseline collector with half of the expanding wall slope:
Overall, these are very similar results. The longer collector with the shallower wall angle has roughly ~2% less pressure loss than the baseline with no other changes. It also has a more uniform flow field in the center of the passage, caused by a reduced diffusion rate and less separation blockage... so definitely a step in the right direction.
I have ran several other simulations that I am still post processing, but I think we have already seen enough to influence our next collector design. I'll edit this post very soon with the results of the remaining designs
Update 4/23/13 Unequal done and out for dynos
JDLAutoDesign is offline
The Following 19 Users Say Thank You to JDLAutoDesign For This Useful Post:
1strwdcar (12-11-2012), 86design (12-08-2012), ATL BRZ (06-05-2013), BobDigi5060 (11-07-2012), BRAWL (10-31-2012), DAN_BRZ (01-04-2014), diss7 (08-23-2013), djdnz (11-06-2012), industrial (10-30-2012), JETRED (05-05-2013), jflogerzi (05-11-2013), JoeBoxer (04-25-2013), meeks (04-24-2013), R2RO (06-19-2013), SilverSkyline210 (10-31-2012), Spartan65 (08-28-2013), Sportsguy83 (05-02-2013), WRB-DZA-BRZ (08-16-2013), Zaneman (10-30-2012)
Old 10-30-2012, 09:52 PM   #2
Zadkiel
Drives: CBS BRZ Limited 6MT
You lost me at non-catted.
Back in (Crystal) Black.
Zadkiel is offline
The Following 3 Users Say Thank You to Zadkiel For This Useful Post:
2forme (10-31-2012), charged86 (04-22-2013), Ingen (05-11-2013)
Old 10-30-2012, 10:51 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
First proper collector I've seen yet. And thanks for manning up and going catless. I can't wait to see the results.
Calum is offline
The Following 3 Users Say Thank You to Calum For This Useful Post:
GenkiElite (10-31-2012), JDLAutoDesign (10-30-2012), OmarGC (10-30-2012)
Old 10-30-2012, 10:53 PM   #4
Zaneman
Drives: 2013 BRZ limited
Very excited to see a dyno of this sucker.
Zaneman is offline
Old 10-30-2012, 10:56 PM   #5
JDMenrique
DEEEERP
JDMenrique's Avatar
Looks very nice. In for results!
JDMenrique is offline
Old 10-30-2012, 11:00 PM   #6
JDLAutoDesign
Drives: 13 FRS
Thank you! A few more pics of the collector
The Following 5 Users Say Thank You to JDLAutoDesign For This Useful Post:
ATL BRZ (06-05-2013), Bonburner (12-11-2012), matsayswhat (10-31-2012), Spartan65 (10-31-2012), WRB-DZA-BRZ (08-16-2013)
Old 10-30-2012, 11:06 PM   #7
Calum
That Guy
That needs to be tagged NSFW. Damn that's sexy.
Calum is offline
The Following 2 Users Say Thank You to Calum For This Useful Post:
MisterSheep (11-13-2015), Tomzilla (11-03-2012)
Old 10-30-2012, 11:10 PM   #8
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
BTW header is a stepped design...1 5/8" to 1 3/4"
Jesse@JDLAutodesign is offline
The Following 4 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
Calum (10-31-2012), diss7 (06-09-2013), OmarGC (10-30-2012), WRB-DZA-BRZ (08-16-2013)
Old 10-30-2012, 11:11 PM   #9
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by OmarGC View Post
Niiiiiiiicccccccceee... LMK If you want another lab rat :P
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
Old 10-30-2012, 11:35 PM   #10
Yruyur
Yruyur's Avatar
Can the stock cat be added to the pipe with the resonator
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 10-31-2012, 12:48 AM   #11
matsayswhat
Drives: '13 SWP BRZ LTD
That interior shot of the collector... Wow! Very nice!
matsayswhat is offline
Old 10-31-2012, 02:25 AM   #12
JDLAutoDesign
Drives: 13 FRS
Thanks guys. Ill update this once we get it all welded out.
Old 10-31-2012, 02:04 PM   #13
JDLAutoDesign
Drives: 13 FRS
Added some underside shots up top
Old 10-31-2012, 02:23 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
ballpark pricerange?
xjohnx is offline
UEL Header Development 86drift Engine, Exhaust, Transmission 77 07-07-2016 02:45 AM
SRT Header Back Exhaust System Intro Piricing Swift Racing Technologies Engine, Exhaust, Bolt-Ons 51 09-25-2012 11:00 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
