#57 |
Grip>Slip
#58 |
Not sure, Mr. SVXdc has been quite for the last few days, probably work related. All you'll need is the two pin to RCA kit and your choice of camera kit. Again, something without guide lines, or can be disabled.
2013 BRZ Preimum #452 - Sterling Silver
#59 | |
Drives: 2016 Toyota 4Runner Trail Premium
UPDATE: As of this morning (9/6/12) I have sent payment to SVXdc for the FT rear camera RCA cable. Last edited by sure74; 09-06-2012 at 10:39 AM. Reason: update on member response |
#60 |
Long Distance Driver
![]() That used to be my friends 86, really loved sitting in it. Sold to 21st century downstairs.
#61 |
Grip>Slip
#62 |
Drives: 2013 Subaru BRZ
it was from my OP when I took a cig break from working on my camera and that was parked downstairs. I know the kid who owns it and he also has a mint unmolested supra.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#63 | |
Drives: 2013 BRZ Limited
Note: I only tried this with the phone lockout above 5 MPH. Any thoughts? |
#64 |
Not sure, nav is the same unit so I would think this works for both. Mine is a premium 6mt but I don't see why it would work differently.
Build Thread:
#65 |
SLO NO MO
Limited 6MT here and the toggle switch on pin 17 works for me. I didn't test it with phone, but I tested it with entering navigation address. The nav settings menu also undims while moving if I toggle it off.
#66 |
Drives: ISF
Excellent work!!
1993 MR2 Turbo - Red
1996 Supra Turbo - White 2011 ISF - Mercury Metallic / Black Suede 2013 Scion FR-S - Firestorm Red 2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery) |
#67 |
WiKKiD Large Penis
Drives: 2001 Audi TT Quattro "BT 300+Whp"
Awesome great job
#68 |
SLO NO MO
Just tested the pin 17 bypass with DivX video on demand - I started the video while I was parked, then I started moving. The video cut out, sound remained on. I flipped my toggle switch and the video was once again available. Note that I also grounded pin 15 on the 16-pin harness to bypass the e-brake.
| The Following User Says Thank You to Foobar For This Useful Post: | mike18 (11-20-2012) |
#69 |
I decided to swap out the switch that I had installed to see if that solved my problem. I cut the old switch out, and wired in a new one. Tomorrow morning on my way to work I'll try this out to see if it solved my problem. Looking at the pictures earlier in the post I did in fact use the ping/green wire and cut and tapped it appropriately. If this switch doesn't work, I'll have to remove the deck, check my soldered connections and reassemble. And if that doesn't work, maybe because I am 6AT instead of manual? Or Radio Version? I'll report back tomorrow my status.
Thanks! |
#70 |
SLO NO MO
Those of you who installed toggle switches on the VSS wire, I'm curious as to where you put your switch - mine's on the panel right next to the interior light dimmer/HID level knobs. There was a blank spot to the right of those two, not sure what Subaru/Toyota had planned for that spot, but it was a perfect spot for my speed sensor toggle switch. If I ever need to go back to stock, I can just swap that one little panel out.
| DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders | Nitro | DIY (Do-It-Yourself) Guides | 42 | 07-02-2016 11:10 AM |
| Name that spoiler! (SOLVED) | WingsofWar | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 12-06-2014 01:22 PM |
| BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
| how I solved my gilrfriend's problem with headrest angle | alexmotrix | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-08-2012 08:00 AM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
