Old 10-28-2012, 01:26 AM   #1
CharlieChaos
Drives: FRS
WRX Sti turbo on frs?
Will a stock turbo kit from an Sti work on an frs? Friend of mine wants to know if its possible. I don't know a ton about turbos but he was curious if he could swap turbo and ECU to frs. Sorry if this sounds weird he explained it much better.
_____________________________________________
http://genometuning.com
http://www.BlackHandGaming.com
CharlieChaos is offline   Reply With Quote
Old 10-28-2012, 01:34 AM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
D3 makes a turbo kit that looks much like an STi in terms of placement the EJ257 turbo header, up-pipe and downpipe would not fit as the FA20 engine's dimensions are smaller and the space to put them is pretty tight. as for the turbo it would be okay maybe. you wouldn't need to swap the ecu. ECUTEK software and a tuner can tune the factory ECU to work with a turbo.
FreshFRS is offline   Reply With Quote
Old 10-28-2012, 07:11 AM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Also the engine is much much closer to the firewall then a Impreza
Silverdub is offline   Reply With Quote
Old 10-28-2012, 08:40 AM   #4
Opposed
Drives: 2013 Asphalt FR-S
Look up Crawford Performance, their turbo kit uses an STI turbo.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-28-2012, 11:32 AM   #5
CharlieChaos
Drives: FRS
He has a salvage yard and if a rear ended Sti came in he wanted to try to swap it over to my car. Would that be a huge pain in the balls to do what would I need to change out
Old 10-28-2012, 12:09 PM   #6
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Custom up-pipe, and downpipe if you want it in the same spot as an STI might want to go to a smaller lithium battery and heat-shield, have to run oil lines for the turbo, turbo blanket and wrap the up and downpipes to avoid melting anything in the engine bay. other than that an intercooler, piping, BOV, and a place to put the maf sensor
Old 10-28-2012, 12:20 PM   #7
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I honestly don't think it's worth the effort. The EJ257 and FA20 are pretty different. You would be better off selling the sti longblock and just buying a kit.
industrial is offline   Reply With Quote
Old 10-28-2012, 12:43 PM   #8
Opposed
The Greddy drift FRS has done the swap, but they said some major work had to be done. Also, the FA20 so far is handleing just as much, if not more WHP than the FJ, so your better off just purchasing a turbo kit of your choice if that's what your after.
Old 10-28-2012, 01:59 PM   #9
chutrain
chutrain's Avatar
Drives: WRB BRZ
There are also much better turbos than what came on STIs. The VF turbos are good at spooling quickly, but they start to lose steam up top.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-28-2012, 03:18 PM   #10
xwd
The turbo or the engine? The turbo requires lots of custom piping, mounting, have to figure out how to get oil and coolant to it, have to figure out how to intercool it, need to tune the ECU for it.
Swapping the engine would require a different front crossmember, you'd have to figure out how to mount the steering rack, you would need a new transmission or a custom bellhousing to mate the engine to the existing transmission, completely different ECU and wiring, fuel system, etc.
Better off saving your money and buying a kit unless you have a lot of fabrication skills and know-how.
AVO Turbo Kit for Oz 86drift Australia Classifieds 52 04-14-2013 01:25 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 12:58 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
