Old 10-10-2012, 03:23 PM   #29
xcelir8brz
Drives: 2013 BRZ Limited
Wowowowowow! Subscribed!
xcelir8brz is offline
Old 10-28-2012, 12:40 AM   #30
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Watching... for MAF placement answer? lol!
soros151 is offline
Old 10-28-2012, 04:38 AM   #31
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
As proven by the turbo guys - no need for a "built" motor at 400hp, maybe for 550hp but no way at that low power level lol
Toyota 86 test driver
Tradewind is offline
Old 10-28-2012, 05:02 AM   #32
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
That looks freaking awesome!
TOTO_86 is offline
Old 11-15-2012, 03:57 PM   #33
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Dialed in at 225.5 whp and 182lb-ft after tuning, currently equipped with HKS GT Supercharger on the motor with factory internals. The original baseline on this car was 153.9 whp and 128lb-ft completely stock.
Evasive Motorsports is offline
Old 11-15-2012, 04:16 PM   #34
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Those are good numbers from a mustang dyno. Any charts to post?
uspspro is offline
Old 11-20-2012, 06:08 PM   #35
Evasive Motorsports
Will have some soon after HKS is fully done with the R&D for the US cars.
-Randy
Old 12-20-2012, 03:25 PM   #36
Evasive Motorsports
Kit should be out in spring!
The Following User Says Thank You to Evasive Motorsports For This Useful Post:
stoneman155 (12-25-2012)
Old 12-22-2012, 06:39 PM   #37
Evasive Motorsports
Great Read from http://www.garagefrs.com/
HKS GT Supercharger: Part 2
Keisuke Morita Tunes Our FR-S On The Dyno At Evasive, Coaxes A Nearly 30-percent Jump In Peak Power
By Bob Hernandez
December 17, 2012
We left off from Part 1 of this story having installed HKS’s GT Supercharger kit in Garage-FR-S’s project car. The intercooled system shoves a few psi of boost pressure into the intake but necessitates a proper tune before it can be used to its fullest potential, primarily to tweak the included F-CON iS piggyback fuel and ignition timing controller.
We went back to Evasive Motorsports to use its Mustang dynamometer, the same dyno we’ve been testing on throughout this upgrade odyssey. Keisuke Morita from HKS manned the laptop, seeking out the best parameters to milk the most out of the blown 4U-GSE boxer motor while keeping it drivable.
After a couple hours Morita-san did just that, in the process making gains – some robust – throughout the rev range.
The biggest jump in horsepower happened between 5,400rpm and 6,250, where it peaked at 201hp, a gain of about 50 over stock. The largest peak gain was at 5,940rpm, where the FR-S picked up some 55 horses.
Torque showed similar improvements, the system surprisingly eliminating the dip we saw early in the power band in nearly every dyno session up to now. A fat bump is situated between 5,100rpm and 6,360, maxing out with 176 lb.-ft. at 5,520, a gain of roughly 50 lb.-ft.
In terms of percentages, the kit makes in the ballpark of 28 percent more power. While some may frown at the peak numbers of 201hp and 176 lb.-ft. of torque, things should be kept in perspective.
For starters, HKS wants to make sure everyone understands the kit is still in development, with ours one of only a few in use. Further tuning and even pulleys that provide still more boost are on the horizon.
Secondly, the blower is irrefutably making the FR-S more powerful, and therefore improving its critical power-to-weight ratio. The manual transmissioned RWD Scion weighs 2,758 lbs., making its stock p-to-w around 17.7lbs. per horsepower (lbs./hp). The power made by the supercharger lowers that figure to 13.7lbs./hp, giving our FR-S a power to weight similar to that of the much respected Mazda RX-8, among other sports cars.
Old 12-22-2012, 06:53 PM   #38
Calum
That Guy
Drives: 2013 asphalt FRS MT
British Racing Green on a Japanese car. No.
All jokes aside, the build looks good.
Calum is offline
Old 12-23-2012, 04:58 AM   #39
Tradewind
What was the boost pressure achieved for this dyno test/result?
Old 12-24-2012, 02:49 PM   #40
sw20kosh
Drives: 2013 Black FR-S
Judging by that torque curve, the restrictor is really holding it back in the top end with that plummeting curve. It drops ~50 ft lbs from peak to readline... not very appetizing.
The flip side is it is generating a bit more torque in the mid rpm range vs. Vortech's non restricted kit. (You have to account for the variances in dyno readings. Ie in perrin's dyno his bone stock torque curve is reading ~20 more Tq than in this dyno. Best to look at the delta between stock and SC along the RPM band.)
sw20kosh is offline
Old 12-24-2012, 03:54 PM   #41
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
That green is so sexy. I will one day paint my car Imperial Jade Mica damn it.
Gregory Gawaran is offline
Old 12-26-2012, 01:52 PM   #42
Evasive Motorsports
7psi
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
HKS Supercharger Style Forced Induction 75 08-06-2012 02:25 AM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-27-2012 11:42 PM
