Old 08-15-2012, 09:45 AM   #43
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Originally Posted by Sccabrz192 View Post
Tom, we ran 245 A6s on my car at the divisional on the 7" wheel, the tire was certainly pinched, and the sidewalls were rounded out a bit. Initial turn in was a bit more vague and with being camber challenged (oe alignment) outer shoulder wear was noticable after 3 race days (2 with codriver on asphault, 1 on concrete). You can get away with it on an A6 based on the sidewall construction, but I wouldn't bother on a street tire. Probably best to go for a 225 on a 7 wide.
Thanks, good to hear as that's where I was going to start next month. I appreciate the info. I'm curious how tire wear is long term for stock with camber bolts with and without a larger FSB. I am expecting pretty good wear for RTR.
PS - Is this Rich or Tim?
TomR
ABQautoxer is offline   Reply With Quote
Old 08-15-2012, 10:04 AM   #44
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Tim, I codrive the events with Eric Malone, who usually drives a STX RX8.
I cant really comment on overall tire wear at this point as I have not done any significant testing yet. I have a plan to develop 2 different base concrete setups, 1 which sacrifices a little overall grip for better tire wear and another for ultimate grip.
P.S. If you were asking about the Rich who also drives ASP, he drives a Yellow GXP.
Sccabrz192 is offline   Reply With Quote
Old 08-15-2012, 10:15 AM   #45
des
des's Avatar
I'm on my second set of 235 Dunlops. First set took 100+ runs and could easily have gone 100 more, but I wanted the 40 series for Nats. Wear evened out pretty nicely after the bolts. We watched temps pretty closely, watered early and often and swapped front-to-rear once. When I gave them to another driver,he couldn't tell which had been on the front.
des is offline   Reply With Quote
Old 08-15-2012, 10:20 AM   #46
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Did you ever flip them?
Old 08-15-2012, 10:36 AM   #47
ABQautoxer
ABQautoxer's Avatar
I bet not. our 83 run dunlops on the RTA WRX still don't need to be flipped quite yet.
TomR
Old 08-17-2012, 08:38 PM   #48
simpleisbest
Senior Citizen
Drives: Scion FR-S
Well I got the car aligned with the stock crash bolts.
Was able to achieve (with me sitting in the car):
FRONT
Camber: -1.25 (L/R)
Toe: 0
Caster (non-adjustable): +5.3 (L), +5.5 (R)
REAR
Camber: -1.25 (L), -1.5 (R)
Toe IN (Total): 1/8"
Should I be concerned with the rear camber measurements not being equal?
The car does not seem to track to the left, as far as I can tell...Supposedly the alignment tech was not able to find any play of adjustment in the rear to even things out...
simpleisbest is offline   Reply With Quote
Old 08-17-2012, 10:10 PM   #49
ABQautoxer
ABQautoxer's Avatar
It's not the end of the world if they aren't even. It won't pull because the toe is correct. Also I assume this was measured without you in the car so the question is what is it with you in the car? My car appears to have similar rear (more in the passenger side) though I have yet to have a chance to loosen it all up and see what I can get.
TomR
Old 08-18-2012, 12:01 AM   #50
autoXracer
Drives: 2013 WRB BRZ
What is the next best option after the 235 40 17? How do the 215 40 17 Dunlops compare? I didn't find a lot of info on this size. I know the taller tire would help at Nats' type courses, but wouldn't having the stiffest (shortest) sidewall help at local races?
autoXracer is offline   Reply With Quote
Old 08-18-2012, 12:28 AM   #51
ABQautoxer
ABQautoxer's Avatar
Why would you want shorter OD and narrower tires for Nats courses on a car that does 60mph in 2nd and has room for more? I would run 225/45/17, 235/40/17 or 245/40/17 if it mounts.
TomR
Old 08-18-2012, 12:59 AM   #52
simpleisbest
Senior Citizen
Drives: Scion FR-S
Thanks for the input! Yup, those measurents are with me in the car.
Hopefully Toyota issues some rear crash bolts eventually.
Old 08-18-2012, 01:01 AM   #53
ABQautoxer
ABQautoxer's Avatar
There will never be rear crash bolts, the rear is a shock not a strut so the same adjustments don't apply. For stock class, much like the STi/WRX, we'll be SOL on rear adjustment other than loosen/wiggle/tighten and toe.
TomR
Old 08-18-2012, 01:14 AM   #54
autoXracer
Sorry if I wasn't clear. What I meant was the taller OD is needed for NATS. but what's best for local autox where if you have shorter courses (where you would want to pickup more speed)?
I guess 225/45/17, 235/40/17 would still be the answer, because the wider tire helps with grip.
Old 08-18-2012, 11:12 AM   #55
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I went with 215/45/17s so I could square off the tire to the wheel as much as possible for the stiffer sidewall. Also, at least with the RS3s, there is 3lb per tire difference once you hit 225. Im not running Nats or anywhere close.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 10-28-2012, 12:34 AM   #56
gmookher
I too had a great track day, blew away miatas, s2000's and much more in the corners...the 215's+light weight wheels+tune+intake/exhuast=power that outclasses other 2.0 NA
I think if you want to be fast into the corners, keeping unsprung wight down, diameters, and correct afr are key, more tire is NOT the answer
have crash bolts, but really there is no way around getting the plates, the caster correction is priceless for fast left right transitions at speed
alignment, rtr, stock class
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 03:25 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
