Old 10-25-2012, 10:57 PM   #113
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Originally Posted by Want.FR-S View Post
I must be querying the wrong road then:
https://maps.google.com/maps?q=Atwoo...12484&t=h&z=15
I failed to see where the twisty road. Can you show me where exactly the twisty road?
BTW, route 33 is where Bunta and Takumi hang out.
https://maps.google.com/maps?q=Mount...Mt+Haruna&z=14
on my map zoom down as far as possible and follow 213 north of the location all the way up to 28A or B which ever you choose thats just one of hte many amazing roads i have youd really have to drive on them. I will upload a video of the roads soon i guess to show you
Mohonk Mountain House, New Paltz, NY here s another, type that in the maps thats a mountain pass its fun as hell and has claimed mannnny cars
DanoFA20 is offline   Reply With Quote
Old 10-25-2012, 11:23 PM   #114
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
The road indeed has a very good view and I can imagine driving on that road is a pleasure drive. However, that road is not twisty enough road.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 10-25-2012, 11:34 PM   #115
DanoFA20
Shift Down
DanoFA20's Avatar
its not like hairpin hell its insane short low speed mid speed corners ill shoot some videos in a day or so when they rain clears out and show you them they have some mean corners. that can only been seen in person or video.
Old 10-26-2012, 01:17 PM   #116
cantaloupe
Drives: brz
How do you go faster starting from a stop? I feel like if I want to be smooth, everyone accelerates so much faster than me starting from a light. And if I rev too much in first, it's harder to shift into second.
cantaloupe is offline   Reply With Quote
Old 10-26-2012, 02:10 PM   #117
jarviz
jarviz's Avatar
Drives: Raven FRS MT
you don't... it's the car lol. It's just not that strong coming from a dead stop unless you push it a little harder.
I think if I apply the same amount of pressure on the throttle to my 04 corolla, it would move faster than the FRS.
jarviz is offline   Reply With Quote
Old 10-26-2012, 02:40 PM   #118
einzlr
Drives: several
Looking forward to that; TIA!
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
The Following User Says Thank You to einzlr For This Useful Post:
DanoFA20 (10-28-2012)
Old 10-26-2012, 03:22 PM   #119
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Video for setting the shift light (didn't see anyone post it embedded)
[ame="http://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
The Following 2 Users Say Thank You to DjDATZ For This Useful Post:
ApoNono (10-26-2012), Eightysexy (10-28-2012)
Old 01-12-2013, 11:48 PM   #120
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Decided to necro this thread instead of starting a new one.
I've a few questions for the seasoned MT drivers out there, mainly touching on how to drive in a smooth and stable manner for the enjoyment of passengers, as I give a fair amount of lifts to my friends:
1) Smooth upshift - every time I shift, I always see my passenger's head lean forward. I've narrowed it down to when I push in the clutch (smoothly) to shift at around 3-4k rpm, the engine breaks a bit so naturally the head leans forward. I've remedied this at the moment by granny shifting at 2k rpm and it seems to be alot smoother. I've also tried not quite fully letting go of the gas until I've reached the friction point but this technique has a higher chance of slipping the clutch.
How do you guys shift smoothly around 3-4k rpm (which is more ideal than granny shift) without any movement from the passenger?
2) Spirited shifts - I've found when shifting up around 5-7k rpm, there is a rather large lurch when I let go of the clutch in a fast manner (while adding gas at friction point). But when I slow down the clutch movement, I get that sound when you're slipping the clutch. Which way is better for the transmission or is there no such way when driving that hard?
3) Clutch wear - the dreaded clutch slippage/glazing/$$$. I'm always mindful not to slip the clutch and make full use of the dead pedal. However when puttering around a shopping centre parking or general creep mode, is it fine if I keep the clutch at friction point without adding gas? Or to minimise wear, should I be either fully clutched or at friction + adding a little gas to make it creep some more?
Thanks in advance.
enouf is offline   Reply With Quote
Old 01-13-2013, 12:17 AM   #121
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
slipping the clutch is ok. actually you will need to do it in many situations.
riding it (keeping your foot on the pedal at all times) is another story and a bad idea
1) you're fine, just keep driving
2) shift faster (but try not to miss the gate)
3) in that situation try to be fully in gear. you'd be surprised what speeds you can be in 1st and 2nd
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
enouf (01-13-2013)
Old 01-13-2013, 12:42 AM   #122
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Another thing you can do is when you think you're almost ready to shift, rev it out a bit. The extra flywheel momentum will make the revs not fall as fast and in turn make the change smoother.
thejevans is offline   Reply With Quote
The Following User Says Thank You to thejevans For This Useful Post:
enouf (01-13-2013)
Old 01-14-2013, 04:49 AM   #123
mooshoepork
Drives: Hilux
dumb question, but I'm driving a manual light truck at the moment (a ute for those aussies) and my knee is annoying me. Getting kinda tired of pushing in the clutch. No idea what it is.
When you're driving, where do you put your leg? rest it on the clutch (but not depress) or move it to the side?
mooshoepork is offline   Reply With Quote
Old 01-14-2013, 10:13 AM   #124
thejevans
thejevans's Avatar
You NEVER rest your foot on the clutch. There should be a spot for it to the left of the clutch. Put it there. As for your knee, you may want to readjust your seat or start doing some squats at the gym.
strat61caster (01-14-2013)
Proper 2 bucket wash method CU2MIKE Southern California 45 09-27-2012 07:15 PM
Is this a bad way to stop when driving manual? artizhay Engine, Exhaust, Transmission 39 09-21-2012 04:32 AM
daily driving and heel-toe method denverizzles Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 03:51 PM
Best Manual transmission driving techniques? rawbz Other Vehicles & General Automotive Discussions 24 05-23-2012 12:15 PM
