View Poll Results: How is manual tranny in traffic?
Orgasmicly great 18 30.00%
Decent 18 30.00%
Shot me now! 6 10.00%
Who cares about traffic, it's all about the twisties! 18 30.00%
Voters: 60. You may not vote on this poll
Old 10-22-2012, 10:55 PM   #15
FRiSson
Drives: FR-S MT
Originally Posted by jmaryt View Post
"overdrive" IS a gear! in 6-speed 5-speed,and 4-speed manual gear boxes,6th,5th,and 4th are overdrive gears respectfully,in ALL manual gear boxes! '"generally",5th,4th,and 3rd gears in respective gear boxes are "direct drive" gears 1 to 1, and ALL gears below those gears are "power" gears,or acceleration gears!
Not always, I had a 4-speed transmission built in the 60's. It had a separate electric overdrive unit that was on the driveshaft behind the transmission. I could deploy it in any gear, but realistically I only used it on 4th. But "overdrive" normally refers to a gear in a transmission that is less than a one-to-one ratio. The FR-S has a true 6-speed transmission, though apparently it was developed from an 8-speed Aisin unit used in Lexi.
FRiSson is offline   Reply With Quote
Old 10-22-2012, 10:55 PM   #16
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
I hate traffic
mRdeMs83 is offline   Reply With Quote
The Following User Says Thank You to mRdeMs83 For This Useful Post:
RPhong (10-25-2012)
Old 10-22-2012, 11:15 PM   #17
jmaryt
Drives: 2012 honda civic ex
Originally Posted by Jive Turkey View Post
its a 5 speed box with a 6th overdrive gear essentially. its not a six speed like the STi has is what i'm saying. its the same trans that was in the newer gen LGT
yes this is correct! overdrive IS less than 1 to 1,however are you sure the 6th gear in the brz/frs is NOT an overdrive? i think you'll find it is!
jmaryt is offline   Reply With Quote
Old 10-22-2012, 11:25 PM   #18
DarkSunrise
DarkSunrise's Avatar
How would you feel if I told you the STI has 2 overdrive gears?
1st 3.636
2nd 2.235
3rd 1.521
4th 1.137
5th 0.971
6th 0.756
Does that make it a 4 speed with 2 overdrive gears?
The Following 6 Users Say Thank You to DarkSunrise For This Useful Post:
ill86 (10-23-2012), JTM (10-23-2012), Linseal (10-25-2012), sierra (10-23-2012), slawdio (10-25-2012), SMOKETREES (10-26-2012)
Old 10-23-2012, 10:44 AM   #19
JTM
Drives: 2013 FRS-6MT Argento
On topic:
I hate traffic, but the FRS is fine for commuting; the clutch is nice and light, first is low enough to inch forward in heavy traffic without throttle input, and second is good down to ~5mph. I really appreciate the light clutch pedal since I used to commute with manual Frontier and before that was a manual F350.
Off Topic:
-I'm really noticing a trend with the former/current Civic owners on this board.
-Overdrive used to be a range box you could add to the tailhousing of your transmission and it had a drive ratio less than 1. Now it is used to refrence any gear with a drive ratio less than 1.
-The twins have a True 6speed
-Jive Turkey might be jive, but he's still a turkey.
-False gears are more closely associated with Automatics. Some auto manufactures will use a TCU (transmission control unit) to control the lockup of a torque converter to create the sense of an extra gear.
-When comparing Transmission gearing it is also important to look at the axle ratios, where an STi is 3.90 the BRZ/FRS is 4.10
JTM is offline   Reply With Quote
The Following User Says Thank You to JTM For This Useful Post:
Tomzilla (10-24-2012)
Old 10-23-2012, 11:19 AM   #20
gily25
Drives: Silica BRZ 6MT
Driving BRZ as my DD, 30 minute drive turned to 45-55 based on traffic, rolling traffic out of the city, rolling traffic into the city. The car is so light and nimble there is no effort in moving it along just by letting the clutch in/out as noted above.
gily25 is offline   Reply With Quote
Old 10-23-2012, 08:46 PM   #21
matthewl
Drives: FR-S white 6 speed
When I decided to get a FR-S, an automatic was available immediately & the 6 speed was about 6 weeks out (I later got the 6 speed in a week). My girl friend accused me of being a wimp for even considering an auto. I waited - got a 6 speed - love it - and her. However, I told her that I would curse her a** the first time I was stuck in NYC rush hour traffic. Hasn't happened yet - we'll see.
matthewl is offline   Reply With Quote
Old 10-23-2012, 08:57 PM   #22
lastsnare
^_^
Drives: 2013 BRZ Galaxy Blue Silica
Not to derail the thread (this is probably good discussion for another thread, and maybe already is),
but I found this article specifically talking about the FR-S/BRZ transmissions and where they came from.
Just because there was some discussion about it.
He calls it an "...AZ6-derived TL70 manual..."
Hopefully the info there is factual.
http://kaizenfactor.wordpress.com/20...n-or-is-scion/
Okay, carry on
2004 WRX sedan Java Black Pearl (manual)
2013 BRZ Galaxy Blue Silica (manual)
lastsnare is offline   Reply With Quote
Old 10-23-2012, 09:35 PM   #23
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Both are good if you want to save more has get the auto it's that simple
Get whatever makes you feel better and don't get influence by others. The end of the car it's sexy on the outside I don't care if you have auto, grandma or naked men inside its still a sexy ride.
Sent from my iPhone (switching to android soon)
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 10-24-2012, 12:37 PM   #24
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I say it's great in traffic IF you do the 2 min clutch pedal adjustment so you're not 2 feet off the floor to engage. I have it flat with the brake pedal and it's PERFECT. But stock my knee was almost in my chest. I also had no problem with my 2002 jetta manual in traffic (1.8T)
Khyron686 is offline   Reply With Quote
Old 10-24-2012, 01:16 PM   #25
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
have to be honest,don't believe i have ever seen a gear box with 6 "power gears!"
generally one of 'em is an "overdrive" gear! and the next lowest is "'direct drive" 1 to 1
just sayin'
With enough torque, any gear can be a "power gear".
TheRipler is offline   Reply With Quote
Old 10-24-2012, 02:23 PM   #26
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Originally Posted by wrxgoose View Post
edit: i apologize if this seems rambling, been drinking, and will edit this post if i can't understand it when i sober up
LOL WINNING!!
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 10-24-2012, 09:58 PM   #27
jmaryt
yes! this is essentially correct,because some cars (muscle cars) for example,CAN "pull a dead horse" in just about any gear,however for the sake of ''clarity",i am referring to the "gear" ratios of 5th,and 6th gears.these gears,
"generally" are NOT considered power gears, because of the "ratios" BUT as you mention,and i agree,if a car has enough torque,then you STILL can ACCELERATE strongly,WITHOUT "lugging" the engine in 5th ,or 6th,however ya do have to have a "ton" of torque to accomplish that, again,"without" bogginig the motor! cars that come to mind are corvettes,camaros, mustangs,cobras,and mopar products! ie: chargers,and challengers. massive v-8's all
Old 10-24-2012, 10:28 PM   #28
TheRipler
Reap the BReeZe
Turns out, it even works for a Subaru flat-4 with 600wtq.
Want to test drive Manual FR-S or BRZ... Ann Arbor Nourdmrolnmt1 Great Lakes 5 11-25-2012 10:42 PM
How to drive manual pezzie AUSTRALIA 35 08-17-2012 08:41 AM
new manual driver: does this destroy my tranny? Saibot Engine, Exhaust, Transmission 45 07-13-2012 07:20 PM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 06:28 PM
Manual tranny takes another step into oblivion madfast Other Vehicles & General Automotive Discussions 76 03-06-2012 09:40 PM
