Old 10-24-2012, 10:23 AM   #435
travace
travace's Avatar
Drives: Scion FR-S
got my new fuel pump and my chirps are gone
they were supposed to replace my ECU but the one they got didnt work or they dont know how to get it to work.
travace is offline   Reply With Quote
Old 10-24-2012, 10:25 AM   #436
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by jadewbj View Post
But isn't it preventative? So how does that make sense? How can you have a case if you are supposed to do it before the issue happens?
Yea i dont understand either...we all know they are aware of the issue but still no tsb issued and it sucks because the symptoms come before the cel so if you dont have a cel they just tell you to go away and wait till it comes on...my fuel pump is being changed first before they work on the cel because thats the process they were told to follow...we all know that the hpfp wont fix the cel but thats the first step they are taking to fix the cel..and what sucks is the the ecu's are on back order so i have to wait till they say its ok to order the ecu so this problem might not be fixed till like jan and thats just unacceptable
brichard0625 is offline   Reply With Quote
Old 10-24-2012, 10:31 AM   #437
dawnst3ar
Drives: 2013 MT FR-S Asphalt
no more chirps since picking it up last night. Will let you all know if that changes...
dawnst3ar is offline   Reply With Quote
Old 10-24-2012, 11:12 AM   #438
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Just dropped my car off. I said I got three issues: backlight condensation, Chirping from the HPFP and a ticking noise around the engine. They've taken it in and said it should be an hour or two and they'll complete diagnosis. Ill update you guys on what they come back with.
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 10-24-2012, 11:44 AM   #439
HunterGreene
Hail Magnet
HunterGreene's Avatar
Backlight--known issue, will replace taillights
Chriping--known issue, will replace HPFP
Ticking--normal part of the DI system.
Old 10-24-2012, 12:20 PM   #440
Kochinopride
They just called me to say they're replacing the backlight but couldn't produce the chirp or tick... Heading over to see if I can reproduce it for them... Not feeling good about this.
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 10-24-2012, 12:24 PM   #441
Kochinopride
My ticking is awfully loud. Like hear it across the street loud. Is that normal? Also I did have my FR-S tuned. Could that cause the tick and squeak?
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 10-24-2012, 01:09 PM   #442
HunterGreene
Hail Magnet
I guess it depends on what the tune did--anything is possible. Would have been handy to know that. And with the squeak, are you referring to the chirp at idle, or is it something else?
Old 10-24-2012, 01:16 PM   #443
Kochinopride
Chirp at idle... I couldn't reproduce the ticks but the squeak they heard. I popped the hood and they said its the LW pulley I installed. They say that's causing all the ticks and chirps. They told me the pulley and tension pulley have too much vibration. They're ordering the tail light but say they can't hear anything wrong with the HPFP... When you dip your head above the engine you can clearly locate the noise sourcing from the right of the engine and at the HPFP... They said they don't hear it... Seriously??? I'm getting frustrated. I'm going to another Toyota Shop because they've dealt with LW pulleys and didn't blame that!
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 10-24-2012, 02:26 PM   #444
shotizzle
First 86
shotizzle's Avatar
Drives: Scion FR-S Whiteout MT
here at the service center at Desert Toyota.... not looking good :/ they don't seem to be aware of the issue.... it's gonna be a long day :/
shotizzle is offline   Reply With Quote
Old 10-24-2012, 06:15 PM   #445
Little_Red_FR-S
Drives: 2013 Firestorm FR-S
My car is going to the dealership on Friday morning to get the HPFP fixed and the hopefully the ECU reflashed. The idle dropping is getting pretty bad.
Little_Red_FR-S is offline   Reply With Quote
Old 10-24-2012, 06:22 PM   #446
TRD_86
Drives: 2013 86 white
Has anyone get replaced at Longo with the new HP fuel pump yet? They told me they never done one yet. I'm waiting for them get to know the car or at least done couple of car first.
TRD_86 is offline   Reply With Quote
Old 10-24-2012, 06:49 PM   #447
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
They replaced mine and it all went away no more idle dip no more chirps... then they came back and Toyota said that they will not fix it again. So I called Scion USA and they are now helping me get this problem fixed. If this happens to you it's best to not argue with them and just call and make a complaint they will assign you a case manager to ensure it gets done right.
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
FRSBRZGT86FAN (07-09-2013)
Old 10-24-2012, 10:33 PM   #448
Pake1
Drives: SWP Premium BRZ
Any SoCal owners take this in for their brz? I'd like to take one in with no bs the first time.
Pake1 is offline   Reply With Quote
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 12:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 10:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
