gmookher
Old 10-23-2012, 07:27 PM   #85
gmookher
Originally Posted by 2forme View Post
I gotta say I'm experiencing the same. It's still notchy/grinds if you shift too fast. The oil "feels" thinner than the stock oil, in that the notchyness is not as muted, if you can imagine it being muted.
I'm willing to give it a few more miles, and maybe a cold morning or two, but as it sits right now.... I'm probably going to swap it out at some point in the near future.
Sorry
sucks for you.
Mines SO much better...
Old 10-23-2012, 07:35 PM   #86
2forme
Originally Posted by gmookher View Post
sucks for you.
Live and learn I guess.
Old 10-23-2012, 10:34 PM   #87
developer
Drives: BRZ Limited
Originally Posted by Brzer View Post
I decided to get Motul gear 300 for the rear dif. Any problem with also using it in the manual transmission?
The Motul 300 is good for both the dif and transmission. That is what I am planning on using for both. I haven't seen another BRZ in Portland, just an FR-S.
developer is offline   Reply With Quote
Old 10-23-2012, 10:59 PM   #88
roddy
roddy's Avatar
Drives: '13 Ultramarine
I have played around with the transmission fluid in this car a bit now (as I did with the Mustang), and here are some of my thoughts:
Stock: A fair bit of effort going into 2nd, kind of notchy, and an irritating little crunch occasionally going into 3rd. I know the manual calls for 75W90, but I suspect the factory fill may be thinner.
Redline MT-90 (75W90): Still kind of notchy, but improved. 1-2 is better, 2-3 crunch is gone completely (yay!). As the weather is turning cooler, the 1-2 shift is starting to degrade until the car warms up. This is at temps below about 50F...it's not even cold yet. It is nothing unusual to see temps between -5F to 15F during the winter here. I don't think I would be happy with it as a winter fluid.
Experiment: I wanted to see if the trans liked a thinner fluid, so I got a little silly last weekend and used up some stuff I had laying around. I mixed 1 quart of Redline MTL (70W80), a liter of Honda MFT (not sure of the viscosity, but it's thin), and topped it off with some Amsoil synchromesh (5W30) that I had left over from the Mustang.. WOW! smooth as silk, even first thing in the morning. Damn 3rd gear crunch is back though. Just an experiment...
Pentosin: We shall see. I'm hoping it is a happy medium between the MT-90 and the experiment. I ordered 3 liters today.
Old 10-23-2012, 11:16 PM   #89
KingRohan
Drives: BRZ Sport Tech 6sp
Did you order stateside or in ON?
KingRohan is offline   Reply With Quote
Old 10-23-2012, 11:29 PM   #90
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Anybody think of redline lightweight shockproof?
FreshFRS is offline   Reply With Quote
Old 10-24-2012, 12:25 AM   #91
ziptiespec
ziptiespec's Avatar
Drives: '01 Honda S2000
what pentosin are you using-mtf2?
Yes, the MTF2.
Driving the car today it was a little better. There was only a very small amount of a grind on the drive home. I've noticed that the lower in the RPMs you are when you shift, the worse the 1-2 shift feels. When I shift closer to red line, the sensation is very smooth.
The wife's taking the car tomorrow so I'll get to hear her input as well.
I also received my Whiteline Positive Shift Kit today. I'm just waiting on the Perrin shifter bushing before I take my next step in improving the feel of the transmission.
I think you're right about the notchiness being less muted, that is an apt description in my case as well. I tend to shift - well not slow, but not fast either, and it feels almost as you describe. As I noted above though, the higher in the RPMs that I shift, the smoother it feels.
I hope that the Pentosin balances your 1-2 and 2-3 issues. I've thought about trying Torco MTL or RTF (or a mixture of both) if the Pentosin ends up not feeling right to me. I also have a stockpile of old Honda MTL formulation (red cap) that I've thought about playing with but I think I'll keep that out of the FR-S.
ziptiespec is offline   Reply With Quote
Old 10-24-2012, 01:13 AM   #92
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Grind? I'm 7300 miles in my car including 2 track days. No grind, not once, not at all.
Maybe I'm misinterpreting. What is your definition of "grind"? My definition of grind means the synchro did not synchronize the gear and the engagement teeth were still spinning when the shift collar tried to engage them causing a grind. Is that what's happening? If so you've convinced me to never try anything that's been mentioned above.
Old 10-24-2012, 02:16 AM   #93
Marrk
Drives: Honda Fit
I've never heard of Pentosin or Torco, but that ain't sayin' much.
At the risk of total apostasy, I thought I would mention Honda's MT Fluid. It was always the best choice for the Aisin tranny in the S2000. Might work in the FT-86.
Marrk is offline   Reply With Quote
Old 10-24-2012, 06:44 AM   #94
roddy
roddy's Avatar
The Pentosin? I ordered from my local VW/Audi/BMW specialist. It is in turn coming from B.C.. He said it should be here in a couple of days.
Old 10-24-2012, 06:58 AM   #95
roddy
roddy's Avatar
I hope so too. From what I have read, the old Honda formulation is a little thicker and works better. It works great in the similar trans in the S2000. If you have some and don't like the pentosin, it might be worth a shot. The stuff I had was the new formulation.
Old 10-24-2012, 07:16 AM   #96
roddy
roddy's Avatar
I'm not far behind you in mileage. I don't know if I would call what I am experiencing a full on grind, but your description makes sense. Occasionally on the 2-3 shift (with the OEM lube and the thinner oil I mixed up on the weekend), I get a slight crunch. It slides into gear fine with no resistance, just a slight noise, and I can feel it in the shifter. This only happens under light throttle "normal" driving at 2500-4000 RPMs. Full throttle high RPM quick shifts are no problem. I was actually really happy with the MT-90 until the outside temperatures started getting near freezing overnight. I think it would have become bothersome once the temperatures get really low. If I wasn't driving the car through a cold Canadian winter, I'd have no problem leaving the MT-90 in there.
Old 10-24-2012, 09:29 AM   #97
ziptiespec
ziptiespec's Avatar
I've experienced what you describe above as well as what roddy describes. I didn't have the latter until switching to the Pentosin.
The old formulation (red cap/grey label) would probably work well enough. The new formulation (white cap/green label) hasn't impressed me in either my CRX's or S2000's transmissions.
The Following User Says Thank You to ziptiespec For This Useful Post:
rice_classic (10-24-2012)
Old 10-24-2012, 11:56 AM   #98
Marrk
Drives: Honda Fit
That's odd. The white cap/green label has been much preferred by every s2k owner I've met (IRL or on the forums). I never had trouble with the white cap/green label, either in my s2k or my Fit. In fact, the Fit with that stuff in it is super slick, a real pleasure to drive.
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
