#71 | ||
Drives: several
2. Take 'em slow. Get off the brake once you start turning the wheel. Participate in a car control clinic. (edit: and leave the nannies on)
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale) "Simplicate and add lightness." - Gordon Hooton Last edited by einzlr; 10-23-2012 at 04:54 PM. |
#72 | |
Drives: Sexy Frs Firestorm M/T
Nothing is troubling me yet, Was just curious about putting your car in neutral when in 3rd-or if its best to brake and shift down. My mom always does neutral and well, I don't want to learn anything wrong-just being protective I guess. Also read its best to stay in 2nd as much as you can in traffic, cause 1st will be jerky...I guess that will be something I learn on the road. 2. I read not to brake into a turn, but I also read you should give it gas to help with handling(gain control), but not too much because than you could lose control. wow I sound like such a inexperience loser-haha I need to get out and start driving, I think that's the best way Ill learn. Just don't wanna hurt the 93 junk machine. Its so weird, I felt like such a great driver-but now Its like learning from the start all over again. I always wanted MT since I was 16-I'm excited to learn(get frustrated) and learn some more
#73 | |
Drives: nissan frontier, DGM MT BRZ
Heavy break >>>> Lightly on breaks as turning in >>>> Hit apex middle of turn >>>> As turning steering wheel back to neutral start getting back on the gas Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to Lee358 For This Useful Post: | IntotheOcean (10-23-2012), ZakD (10-23-2012) |
#74 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Ideally you want to brake and be set up before you make a turn and then be able to gradually accelerate out of the turn but that doesn't mean not to brake in a corner if you find yourself in trouble and have no other options. That just means you came in too hot and you are in a more trouble spot than if you had set up carefully. The big thing is to not drive beyond your limits/capabilities and enjoy what you're doing. You don't have to prove anything to any body. If you mess up and wreck you're the one that has to suffer the consequences.
| The Following User Says Thank You to whaap For This Useful Post: | IntotheOcean (10-23-2012) |
#75 | |
Drives: White Out FR-S
For the record, sometimes braking into a turn is what may save your ass from hitting a barrier. Simplest example, there can be people who know everything there is to know about driving stick from reading about it, but without any seat time, he'll never drive it well without practice and muscle memory. |
#76 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
I have been shortshifting lately and unlike my previous car, this one seems to respond much better mpg wise when I keep it at lower rpms. Anything above 40mph is okay for 6th gear, given you don't need to accelerate. I usually rev the highest(about 5-6k) in first gear, then shift sooner and sooner until i'm cruising in 6th at exactly 5mph above the speed limit. haha
My general rule is that it's always better to give your clutch a little slip than it is to release it at the wrong point and jerk your whole engine/transmissioin around. The clutch is much cheaper/easier to replace. As far as cornering goes, you should practice in Forza Motorsport with all assists turned off, including abs. Gran Turismo 5 is also great because it actually has license tests that teach you how to drive and give great pointers. I practice in Forza Motorsport 4 with a Fanatec Racing wheel. Expensive, but worth every penny. There is no feel in the clutch pedal, but it's good for muscle memory regardless.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
#77 | ||
Drives: several
You're not a loser
inexperienced != loser ![]() Quote:
As for your other point, don't try to drive in 1st if you're going more than about 5-10mph; just use it to get started, then get into 2nd. Gear selection is all about engine speed (rpms). Too slow and you stall, too fast and you hit the rev limiter, waste fuel, shorten the life of your engine or blow it up (in the worst case and/or if there's no rev limiter). Quote:
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale) "Simplicate and add lightness." - Gordon Hooton |
#78 |
Drives: Toyota Yaris 1.3
<br />
For the record, sometimes braking into a turn is what may save your ass from hitting a barrier. <br /> <br /> 100% . Though breaking in a turn is generally frowned upon, and you look like a noob, but there are times when it is wiser to do it. Especially if the bend is also on a downhill. But the ideal is to slow down sufficiently before the bend and start accelerating as you negotiate it. Talking about noob, can someone describe exactly how to double clutch ? ![]() Sent from my MB525 using Tapatalk 2 |
#79 | |
Drives: FR-S Whiteout
Basically I always think of it as: If you are steering a lot you shouldn't be using the throttle or break as your tires are near their breaking threshold. If you are gassing or breaking a lot you shouldn't be steering much. Your tires have 100% to give and if you are asking for 70% in steering and 60% in acceleration or breaking you are going to have a bad time. |
| The Following 2 Users Say Thank You to Snozzberries For This Useful Post: | IntotheOcean (10-23-2012), Lee358 (10-23-2012) |
#80 | |
Drives: Raven FRS MT
I learned to drive stick in this car - now I get to reap the benefits of driving through manhattan through rush hour . Still beats driving my AT corolla any day. At least itgives me plenty of opportunities to practice my heel-toes haha. I haven't fishtailed once without intentionally doing it. I don't know how people say they get the back to slide out so easily, unless they drive at +5k rpms everywhere they go, with all traction off...which i don't
| The Following User Says Thank You to jarviz For This Useful Post: | Snozzberries (10-23-2012) |
#81 | |
Drives: several
shift to neutral clutch out rev match clutch in shift into gear back on throttle, clutch out edit: as others have pointed out, in cars with synchros double clutching is entirely superfluous. That doesn't mean you're not allowed to be curious about it, though. Nostalgia ftw! Anyone want to know how to work a rotary phone?
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale) "Simplicate and add lightness." - Gordon Hooton Last edited by einzlr; 10-24-2012 at 05:37 PM. |
| The Following User Says Thank You to einzlr For This Useful Post: | ZakD (10-24-2012) |
#82 |
#83 |
Drives: Toyota Tacoma
Not double clutching like you should...
#84 |
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Just drop the double clutching, we aren't in the 60s anymore.
| Proper 2 bucket wash method | CU2MIKE | Southern California | 45 | 09-27-2012 07:15 PM |
| Is this a bad way to stop when driving manual? | artizhay | Engine, Exhaust, Transmission | 39 | 09-21-2012 04:32 AM |
| daily driving and heel-toe method | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-21-2012 03:51 PM |
| Best Manual transmission driving techniques? | rawbz | Other Vehicles & General Automotive Discussions | 24 | 05-23-2012 12:15 PM |
