Old 10-23-2012, 11:33 AM   #15
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
is it like this?
http://www.ft86club.com/forums/showthread.php?t=19308
if it is, continue in that thread.
MODS can you merge the threads?
Old 10-23-2012, 11:50 AM   #16
CBR600RR
Drives: Raven Black
Originally Posted by Spartan65 View Post
You have the Beep set to on when the Redline pops up?
right now I am guessing this - because it is almost inaudiable(sp) when at redline
Old 10-23-2012, 12:04 PM   #17
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I have a similar noise and it doesn't seem to be related to the other thread.
It sounds like a muffled horn and it only happens when driving/shifting aggressively. My buddy has an FR-S and he heard the sound in my car and said 'WTF?' He doesn't have the same issue in his car.
cobrabyte is offline   Reply With Quote
Old 10-23-2012, 12:09 PM   #18
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
guys i think the bright red shift light accompanying the "horn" noise would be a give away lol. This is more likely a clutch/transmission issue. Are you completely off the gas before you depress the clutch? I know it sounds trivial but i have no idea of your experience level.
RandomHero is offline   Reply With Quote
Old 10-23-2012, 12:16 PM   #19
cobrabyte
cobrabyte's Avatar
I have the shift beep disabled and I know what that sounds like. This is not that sound. It sounds like air squeaking past the throttle body butterfly or something like that.
Old 10-23-2012, 12:36 PM   #20
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
I hate tracking down strange noises This could be ANYTHING! In the back of my head im wondering if its the noise generator malfunctioning? I know its all suction based but maybe something broke in that big black vibrating valve thingy (for lack of a better term). Seeing as this may be a suction based noise?
Old 10-23-2012, 12:39 PM   #21
cobrabyte
cobrabyte's Avatar
It's not the noise generator in my car. I removed that thing the first weekend I had the car.
I'll try to track down the noise... been on my TODO list for a while.
Old 10-23-2012, 01:00 PM   #22
CBR600RR
Drives: Raven Black
Maybe it is your clutch peddle squeeking (or making a harmonic "woot") when you depress it quickly to shift?
Old 10-23-2012, 01:03 PM   #23
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i can maintain the noise by slipping the clutch (throttle and clutch modulation), easiest to do on a highway/constant speed.
Old 10-23-2012, 02:35 PM   #24
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
For me it never happens when depressing the clutch to shift out of gear, only when releasing the clutch to shift into gear.
enigmaaron is offline   Reply With Quote
Old 10-30-2012, 12:49 AM   #25
clzzical
Drives: BRZ Limited 6MT SWP
Originally Posted by enigmaaron View Post
Is it the sound in the video below? The other thread didn't sound like they were describing what I have but your description did. I get this with just the right amount of slip.
Not sure if it helps but I noticed something: your gear indicator takes a while to show up, much longer than in my car. Related issue?
clzzical is offline   Reply With Quote
Old 10-30-2012, 01:58 AM   #26
chate
Pharmasaurus Magnificus
chate's Avatar
I get this noise in my car too, and i've noticed my gear indicator takes a while,much like video, how long is it supposed to take before the number displays? Is it instant for you?
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
Old 10-30-2012, 07:56 AM   #27
enigmaaron
enigmaaron's Avatar
For me it doesn't show until you are completely off the clutch so it may just be a side effect of the condition since to cause the noise you have to be at least partially on the clutch. Is that how it works for you guys, no indicator until the clutch is fully released?
Old 10-30-2012, 08:45 PM   #28
clzzical
It's not instant, and does not show until clutch is released. I think it takes about a 1.5sec to 2sec to appear, but whatever the time is, it is definitely not as long as in the video.
I'll try to get a video later today for you.
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 01:12 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
