Old 10-21-2012, 11:42 AM   #43
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
ID say this Nokian Hakkapeliitta R used them once before on my older 95 325is in 1 foot of snow went better uphill in snow storm then a 4wd truck with basic all seasons :-D Nokian ftw
DanoFA20 is offline   Reply With Quote
Old 10-21-2012, 11:47 AM   #44
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
what do you think about the fitment of what i said above with the miro 111's
Originally Posted by Foobar View Post
It'll work. Just pay attention to your speed - as you may think you're following the speed limit but you're actually going over.
Also, the gearing ratio is changing, as I mentioned. You will have a taller effective gearing ratio, so expect worse acceleration. On the other hand, if you wanted lower engine speed at highway cruising, you'll get a bit of that.
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 10-21-2012, 12:45 PM   #45
Foobar
SLO NO MO
Foobar's Avatar
I think others have used those sizes but it's not clear to me if they were on stock suspension or not. Size by itself isn't always an indicator of how if will fit. Each wheel model has its own characteristics and I'm not familiar with the Miros. That's an aggressive size to be sure. Back should be okay I think. The fronts are usually what you have to worry about. As well as big brake clearances if you need that.
Sent from my Nexus 7 using Tapatalk 2
Old 10-21-2012, 11:56 PM   #46
ScionFR-S
ScionFR-S's Avatar
bump
Old 10-21-2012, 11:56 PM   #47
ScionFR-S
ScionFR-S's Avatar
i have seen one car with that fitment and same rims using i believe 1 inch drop or 2 in... not sure but hopefully fitment will be good on stock height
Old 10-22-2012, 11:45 PM   #48
ScionFR-S
ScionFR-S's Avatar
bump
Old 10-23-2012, 12:07 AM   #49
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Miro's should fit without problems (depending on tire of course). it's not THAT aggressive.
dori. is offline   Reply With Quote
Old 10-23-2012, 09:00 AM   #50
Foobar
SLO NO MO
Foobar's Avatar
Someone else reported rubbing with that size but only at full lock. Again, it will depend on the specific tire of course. Some are thicker than others despite the same reported size.
Old 10-23-2012, 12:03 PM   #51
ScionFR-S
ScionFR-S's Avatar
im looking at yokohama s.drives should i go with a 245/35 tire to be safe then?
Old 10-23-2012, 12:24 PM   #52
Foobar
SLO NO MO
Foobar's Avatar
I honestly don't know - I'm not sure what was causing the rubbing. Check the wheel fitment sticky and click on the 18x8.5 / +45 box on the matrix to find the post where someone had that combo. Maybe you can reach out to the OP directly to see what his thoughts were on how to mitigate the rubbing.
The Following User Says Thank You to Foobar For This Useful Post:
ScionFR-S (10-23-2012)
Old 10-23-2012, 01:02 PM   #53
ScionFR-S
ScionFR-S's Avatar
awesome thanks alot !
Old 10-24-2012, 08:22 AM   #54
ScionFR-S
ScionFR-S's Avatar
Bumppppppp
Old 10-24-2012, 05:50 PM   #55
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Here is my winter setup. I got some 16" Subaru Legacy wheels running 205/60 R16 Bridgestone Blizzaks WS-70. I live in Colorado, and our winters are pretty brutal.
VietnamPhenom is offline   Reply With Quote
Old 10-24-2012, 06:29 PM   #56
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I just placed an order from tirerack for General Altimax Arctic's in 205/55/16 with a set of ghetto fabulous steelies. As much as I dislike winter, this setup has me pretty excited for snow.
If anyone's curious, ran me $710 shipped (mounted and balanced).
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
nyc, performance winter tire, treadlife, winter tires
JRP's Winter Tire special for FR-S/BRZ Stav Canada Classifieds 5 01-25-2013 08:30 PM
wet weather MikesFRS Southern California 1 10-09-2012 01:17 PM
Winter tire Dub666 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:32 AM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 08:33 AM
Need some help picking a winter tire... jm1681 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-29-2012 01:14 PM
