Old 09-06-2012, 04:06 AM   #29
RAYSSPL
Drives: bicycle
The factory throttle body @ 3" is huge for the displacement of this engine. It's more than sufficient. The issue that needs to get around is how these things are choked up by 3 catalytic converters.
RAYSSPL is offline   Reply With Quote
Old 10-04-2012, 08:49 PM   #30
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Hey Guys, figured I would help answer some questions.
There is no core exchange required - it's a complete brand new unit. It works with the factory ECU and it requires no additional tuning or modifications.
I have 3 coming in next week. PM me if you want to get one ordered.
-Frank
ModBargains is offline   Reply With Quote
Old 10-04-2012, 09:44 PM   #31
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
http://maxbore.com/ ?
CircuitJerk is offline   Reply With Quote
The Following User Says Thank You to CircuitJerk For This Useful Post:
SkullWorks (10-23-2012)
Old 10-04-2012, 10:18 PM   #32
IShouldStudy
IShouldStudy's Avatar
Drives: 2013 Firestorm FRS, 97 BMW M3
I'm not an expert at the engineering dynamics of throttle bodies but I am a consumer who does a lot of research for the products I buy. I did a fair amount of research when looking to upgrade the throttle body on my 97 m3 (3.2l inline 6) and the percentage of the increase in area was one important aspect. I realize that comparing engines is rather pointless but i wanted to point out the following:
FRS
stock - 76mm
cusco - 78mm
Increase of 2.6%
M3
stock - 63.83mm
Dinan - 66mm +6.46%
Riot Racing - 68mm +11.9%
There are other aspects to BBTB such as smoothness of the chamber and the single vs. dual arm. However an increase of 2.6% makes the part seem more of a bragging right rather than a performance part.
Maybe some of the tuners who having been working with the FRS can tell us if there is any need for a larger throttle body or at what power/modifications point more flow is needed.
IShouldStudy is offline   Reply With Quote
The Following User Says Thank You to IShouldStudy For This Useful Post:
fuddbutter (10-23-2012)
Old 10-23-2012, 02:43 AM   #33
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
If the stock throttle body's O.D. Is 76mm I don't think cusco will make it bigger from the outside. I bet will be the inside instead. Anyone know what's the stock I.D. Of the TB ?
If no one knows, I will pull my TB this weekend and check !
AJ PwR is offline   Reply With Quote
Old 10-23-2012, 02:52 AM   #34
SeattleJeremy
SeattleJeremy's Avatar
Drives: Vibe
Originally Posted by zooki View Post
76mm stock? For 200 HP? Wow. I remember making close to 300 HP in my old 5.0L mustang with a 70mm throttle body. Marketing an even larger throttle body sounds like snake oil to me, unless your going big boost.
Best answer.
76mm is the stock Internal Diameter.
SeattleJeremy is offline   Reply With Quote
Old 10-23-2012, 03:16 AM   #35
showbe
Drives: A nice one
Just curious what kind of gains can be expected from this?
showbe is offline   Reply With Quote
Old 10-23-2012, 08:35 AM   #36
wparsons
wparsons's Avatar
Is it actually 76mm at the throttle plate, or is that the I.D. at the tip of the inlet?? Most 2L engines run WAY smaller TB's than this. Typically 70mm is a huge TB on a 2L.
flickr
Old 10-23-2012, 09:13 AM   #37
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
But Cusco.. it has to be better?
What about if i put a HKS sticker on it? would you pay $2250?
OMGOMGOMGOMG JDM #mustwastemoneycauseitsJDM
I think my post is about as pointless as this product..
Sorry.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following 2 Users Say Thank You to fuddbutter For This Useful Post:
Anthony (07-30-2013), proficience (10-24-2012)
Old 10-23-2012, 11:48 AM   #38
ML
ML's Avatar
Drives: 13 White MT FR-S
Sorry.
Yes.
The Following 6 Users Say Thank You to ML For This Useful Post:
dabocx (10-23-2012), Feighner (05-02-2016), fuddbutter (10-23-2012), Mo707 (10-30-2012), No Limit Motorsport (10-23-2012), soros151 (10-24-2012)
Old 10-23-2012, 07:42 PM   #39
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Originally Posted by ML View Post
Yes.
So good
The Following User Says Thank You to fuddbutter For This Useful Post:
ML (10-23-2012)
Old 10-23-2012, 08:54 PM   #40
gmookher
I sprung for a Dinan OTB for my m3, but it was part of a tuned kit, cai package and software to match it all. The OTB from cusco by itself for that money...pass
Old 10-23-2012, 09:55 PM   #41
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
i heard it was made using Chuck Norris's tears must be good then
FRS-HHH is offline   Reply With Quote
Old 10-24-2012, 01:19 AM   #42
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
http://www.ft86club.com/forums/showt...973#post508973
Measured the TB here. Mostly approximately, but not bad at all.
soros151 is offline   Reply With Quote
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 01:40 AM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 04:24 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 11:52 AM
