Old 10-22-2012, 05:14 PM   #225
RYU
RYU's Avatar
Drives: really slow...
I posted this on a different thread. Hope it helps.
Here are my before and after alignment settings.
SETUP:
RCE Yellows (20mm drop, 250#/250#)
Front OEM Crash Bolts
Rear Whiteline Eccentric Bushing kit
My goals for this street/occassional_track car is -1.5 camber and 0 toe all around per RCE recommendations. Caster is whatever it's at...
After Lowering on RCE Yellows with OEM height and OEM alignment (i.e. Before alignment): No driver
Rear
camber Right -2.2, Left -1.7
Toe 0
Front
camber Right -1.7, Left -1.0
toe "close to 0"
After Lowering on RCE Yellows and after alignment @ West End: Driver's weight in car, approx 190lbs
Rear
camber -1.7/-1.7 (was aiming for -1.5 so a bit disappointed here but -1.7 was the max +camber we could achieve)
toe 0
Front
camber -1.4/-1.4 (was also aiming for -1.5 so close enough)
toe 0
I usually like running a bit more front camber so when coilovers arrive next year lowering the ride height should get me a bit more camber. I need to find a better option for the rear though. As I go lower i'd like to dial out more of that neg camber.
Oh, the rear camber bushing install wasn't that bad at all but not something i'd like to do in my garage w/o an air hammer.
Hope this helps some of you folks. The RCE Yellows are quite good.
RYU is offline   Reply With Quote
Old 10-22-2012, 11:03 PM   #226
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Argh...so as I said I had that shop install the Whiteline bushings today. I was just under the car and saw this:
Very upsetting...the metal there looks chewed up. I'm not sure how/why that happened during the bushings install and alignment. Any thoughts on the seriousness of this and how easy it would be to fix?
Phaedrus29 is offline   Reply With Quote
Old 10-22-2012, 11:06 PM   #227
cnk
Drives: '13 DGM BRZ Limited
That does not look like work from a "reputable shop" as you wrote earlier. That looks like some hack job by a shade tree mechanic.
Old 10-22-2012, 11:16 PM   #228
Phaedrus29
Phaedrus29's Avatar
Agreed, very disappointed. The shop is called R/T Tuning in Lansdale, PA. From what I've heard, they have a great reputation and I had to wait over a month for my appointment. Not pleased.
Old 10-22-2012, 11:17 PM   #229
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Holy Moly
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-22-2012, 11:58 PM   #230
RYU
RYU's Avatar
I'm very sorry you had to fall victim to this. They must have went to town on the air hammer there. Why? I have absolutely no idea why... It's completely asinine.
That is part of the frame unibody they screwed up there. There are few things you can do... I would take it to a reputable classic car restoration shop. They need to strip that section and properly gusset it. Welding will be involved. They will then need to treat and paint again probably with some kind of bedliner material. It's not a lot of surface area so it looks a lot worse than it is. That section is weakened though so there might be grounds for a lawsuit here. I don't like to sue people but this is just wrong.
Old 10-22-2012, 11:59 PM   #231
gmookher
they mauled your car
Old 10-23-2012, 12:05 AM   #232
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Are you guys being serious? Its fine, you get what you pay for; sand it down and spray it. :happy0180:
Lawsuit?
chulooz is offline   Reply With Quote
Old 10-23-2012, 12:09 AM   #233
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Are both sides like this?
Old 10-23-2012, 12:12 AM   #234
Phaedrus29
Phaedrus29's Avatar
Originally Posted by chulooz View Post
...you get what you pay for....
Well I waited over a month to go to what was supposed to be a good shop. They charged $105/hr and said after they really "should" have charged $115/hr.
No, only one side is like this, in just this spot.
Old 10-23-2012, 12:14 AM   #235
chulooz
Registered you sir
chulooz's Avatar
I would just avoid them now and cut your losses. I wouldnt put my car in their hands again.
Old 10-23-2012, 12:17 AM   #236
JoeBoxer
JoeBoxer's Avatar
Wow that's dealership labor rate pricing and if anything they should have quoted more hours not a higher rate but since they didn't do it right anyways i would demand my money back. Speak to the manager/owner and also check and see if they are a member of the BBB.
Old 10-23-2012, 01:07 AM   #237
RYU
RYU's Avatar
Lawsuit?
LOL Holy Sh*t...
I would not want to buy a used car from you. Who knows what you don't think is a big deal.
The Following 2 Users Say Thank You to RYU For This Useful Post:
mike2100 (10-23-2012), whataboutbob (10-24-2012)
Old 10-23-2012, 08:29 AM   #238
mike2100
mike2100's Avatar
Drives: 23 BRZ
LOL Holy Sh*t...
Add one more to the bucket of reasons not to buy used!
mike2100 is offline   Reply With Quote
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
