Old 10-20-2012, 10:59 PM   #1
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Pioneer AVIC-X940BT confirmation
Hello all,
I have been trying to do research on what is specifically needed to install an aftermarket radio. I plan to do the X940BT. After searching this is what I have come to the conclusion of needing below. Can others with this headunit or any other aftermarket headunit confirm this all is correct and everything that I need? If so my total is only 570 i
[ame="http://www.amazon.com/gp/product/B008I5S4AW/ref=ox_sc_act_title_5?ie=UTF8&smid=A9UC26ZLPAXH1"]Parking Brake Override Bypass Fully Automatic Video in Motion Pioneer Extra Wire with OEM Pin and Tool Kit[/ame]
[ame="http://www.amazon.com/gp/product/B0002BEQJ8/ref=ox_sc_act_title_4?ie=UTF8&smid=A232DEXWNE9181"]Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker[/ame]
[ame="http://www.amazon.com/gp/product/B000K52CY2/ref=ox_sc_act_title_3?ie=UTF8&smid=ATVPDKIKX0DER"]Metra 95-8202 Toyota DDIN Multi Dash Kit[/ame]
[ame="http://www.amazon.com/gp/product/B004W34BBK/ref=ox_sc_act_title_1?ie=UTF8&smid=ATVPDKIKX0DER"]Scosche LSAAB Antenna Adapter for 2002-Up Dual Lexus[/ame]
FR-Shadow is offline   Reply With Quote
Old 10-21-2012, 12:34 AM   #2
ike44
Drives: Whiteout FRS
Have you checked to make sure the dash kit will fit and is the right size?
Down in the Classifieds there is this that are made to fit the FR-S and dont require any trimming/cutting. Might be a non-issue though if you already made sure it will fit.
ike44 is offline   Reply With Quote
Old 10-21-2012, 01:33 AM   #3
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Did you search this radio and see if anyone has done it on other cars? I'm not sure, but I read that some radios now use navigation to tell if the car is moving and cuts off video. It might just be the JVC/Kenwoods. I don't remember.
JimmyMac is offline   Reply With Quote
Old 10-21-2012, 05:37 AM   #4
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
That parking brake bypass technique (adding a new wire to a "secret" bypass pin on the HU's RCA harness) works for the AVIC-X940BT.
Here's a better antenna adapter to use: Metra 40-LX11. FR-S needs the BLUE power antenna wire (for the antenna booster amplifier). BRZ does not (Subaru puts that wire on the power/speaker harness).
SVXdc is offline   Reply With Quote
Old 10-21-2012, 09:23 AM   #5
encity5
encity5's Avatar
I have the x940bt and used all the pieces you listed cept for the bypass
I just followed this video foe the bypass
http://m.youtube.com/#/watch?v=8HL5p...%3D8HL5pkAKkkA
But the wire you have thee seems like it can work too.
And ike44 is correct that you do need to modify that metra 95 8202 dash kit, I used a hacksaw. But it looks like other options are coming out.
encity5 is offline   Reply With Quote
Old 10-21-2012, 12:40 PM   #6
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
no need to waste money on the bypass, its very simple to just move the mute wire to a different slot on the connecter and ground it out.
check out AVIC411.com for tons more info on the pioneer radios
Flat Black VW is offline   Reply With Quote
Old 10-21-2012, 12:46 PM   #7
FR-Shadow
FR-Shadow's Avatar
Yeah thats what I was seeing in the video. Ill probably do that now. Thanks.
Old 10-21-2012, 12:59 PM   #8
FR-Shadow
FR-Shadow's Avatar
Ok when i searched that atenna adapter on amazon it did not look like the one you linked to on the metra website. Has anyone else used this atenna adapter?
Old 10-21-2012, 01:02 PM   #9
encity5
encity5's Avatar
I havent used that antenna adapter but im curious to see what makes it better than the scosche LSAAB that you listed originally.
im using the scosche LSAAB without any issues to radio reception. But im not sure whats the difference within these adapters.
Old 10-21-2012, 01:04 PM   #10
FR-Shadow
FR-Shadow's Avatar
Me either, after searching the forum for a while the LSAAB seems to be the atenna adapter to go with.
Old 10-21-2012, 03:03 PM   #11
SVXdc
SVXdc's Avatar
The Scosche LSAAB has an extra leg that you won't use (the one with the black plug). See pictures in my post here (also see my post #10 later in that thread).
Old 10-21-2012, 06:35 PM   #12
FR-Shadow
FR-Shadow's Avatar
Ok I bit the bullet and purchased the following--
Pioneer AVIC-X940BT - 526.89 shipped--Amazon
Beat-Sonic BH1 Stereo Installation Kit - 43.07 shipped- Beat-Sonic
Metra 40-LX11- 14.99 shipped- Sonic Electronix
Grand total is 584.95 for a way better radio than BeSpoke at 845. I saved 260.05 that I now can spend on something else for the FRS.
Old 10-21-2012, 07:57 PM   #13
encity5
encity5's Avatar
Nice don't forget any additional butt connectors or soldering tools you might need if you don't already have. Wire strippers, crimp tools, zip ties, etc
Good luck!
Old 10-21-2012, 08:00 PM   #14
ike44
You got an effing deal on that Pioneer. MSRP is $1k. I have no idea why Amazon is pricing them so low, but I am certainly not complaining.
I am actually thinking about picking one up for myself. Let us know how your install goes.
Help with after market Pioneer AVIC X940BT jimgfl Electronics | Audio | NAV | Infotainment 23 12-22-2012 11:58 AM
Canadian BRZ Factory Pioneer AVIC-X9310BT jjkerr626 Electronics | Audio | NAV | Infotainment 2 09-15-2012 02:21 AM
x940bt wiring help encity5 Electronics | Audio | NAV | Infotainment 10 08-31-2012 05:08 PM
