Old 08-27-2012, 06:57 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Thumbs up Looking for a good oil filter?
http://www.icbmotorsport.com/jdmhoheoilfi1.html
These are awesome and work on our cars. Highly recommended. Surpasses OEM quality and that of many aftermarket.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Kinzo (09-03-2012)
Old 08-30-2012, 07:47 PM   #2
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
comes in my favorite color too! what makes these so much better than the rest?
TennisHsu is offline   Reply With Quote
Old 08-30-2012, 08:12 PM   #3
gmookher
http://www.bobistheoilguy.com/forums...Number=1855050
Old 08-30-2012, 09:08 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Here's my recommend 3 step process:
1: Read this article:
http://www.joegibbsracingoil.com/tra...h/filters.html
2: Buy these high-quality inexpensive filter: PL14460 ($5.76)
[ame="http://www.amazon.com/Purolator-PL14460-PureONE-Filter-Pack/dp/B000E8P78I/ref=sr_1_1?ie=UTF8&qid=1346371606&sr=8-1&keywords=PL14460"]Amazon.com: Purolator PL14460 PureONE Oil Filter, Pack of 1: Automotive[/ame]
3: Change oil filter often (because it's easy), about every 2-2.5k miles. Change oil every 5k miles.
The Following User Says Thank You to rice_classic For This Useful Post:
Tristor (05-10-2018)
Old 08-30-2012, 10:08 PM   #5
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
How does it surpass OEM filter quality when its from the same manufacturer as the OEM oil filter...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 08-30-2012, 10:55 PM   #6
gmookher
the blue painted filters are frams
the black made in japan subaru filters are not fram
Old 08-30-2012, 11:10 PM   #7
rice_classic
Because if you believe it's real, then that makes it real.
Old 08-31-2012, 02:17 AM   #8
empower-auto
Kouki-Monster
Because it's made to a higher spec than the OEM filter. The OEM filter only has to meet a certain specification.
This isn't to say the same company can spend some more dollars and offer something even better.
Rich Anderson
EMPOWER AUTO
Old 08-31-2012, 03:02 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Do these versions have the same bypass pressure? Subaru has a specific spec which is higher than most. I'm going to stick with my Subaru black Tokyo Rokis and a filter mag.
The only change I might consider is to a Canton cartridge filter..
Old 10-19-2012, 12:06 AM   #10
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Changing our oil filter is absurdly easy, so I'm considering changing my filter every oil change AND every mid-oil-change. Perhaps oil change at 5-6k miles and filter change every 2.5-3k miles. Is this just pointless overkill? Thoughts?
Phaedrus29 is offline   Reply With Quote
The Following User Says Thank You to Phaedrus29 For This Useful Post:
Old 10-19-2012, 01:51 AM   #11
rice_classic
You described exactly what I'm doing.
Oil every 5, filter every 2.5.
Oil every 3 in the summer when I'm at the track instructing or playing.
Old 10-19-2012, 02:07 AM   #12
OrbitalEllipses
Drives: Attitude
I believe those PL14460 filters don't have an anti-drainback valve.
Old 10-21-2012, 04:40 AM   #13
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Originally Posted by ICB Motorsport
and raises oil pressure by about 5 psi
I find this claim hard to believe. Better filters can keep it more constant but increase it 5psi??
The HAMP oil filter will last longer and filter better than any other filter on the market.
Also another big claim to make.
SXE10 is offline   Reply With Quote
Old 10-21-2012, 06:05 AM   #14
D1cker
Drives: B9 S4/ND2
Just get the OEM tokyo roki filters. You can get a 6 pack on ebay for $39.99 shipped (6.65 each!)
D1cker is offline   Reply With Quote
Oil Filter Hayashi Hawaii 2 02-20-2013 01:07 AM
WTB: TRD oil filter 86_ZN6 Engine, Exhaust, Bolt-Ons 0 08-26-2012 01:50 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
Oil Filter Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 05-23-2012 10:53 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 04:35 PM
