Old 10-14-2012, 09:17 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Perrin Rear Shifter Bushing Install
This DIY guide can be used for other vendor's bushings. I decided to purchase the Perrin based on my good relationship with @PERRIN_Chris.
@cobrabyte, @post_break and myself had a good time replacing bushings around our gearboxes. Much appreciation for the lift and garage space! Good times learning about our cars. @cobrabyte was also a good hand model LOL
Before we start, lets do some feedback. Out of all the mods I've done, arguably the best mods you can do are
+ Gearbox fluid change ($60 - http://www.ft86club.com/forums/showthread.php?t=19218)
+ Rear shifter bushing ($40)
+ Transmission bushing ($40 - http://www.ft86club.com/forums/showthread.php?t=19782)
It's very inexpensive, and goes a long way to remove the notchiness in the gearbox. For me fluid alone wasn't enough to remove notchiness, cold and warm. Shifting also felt very sloppy. Downshifting 3-2 was impossible without feeling that ball breaking cringe that makes you cry alone in the corner.
Now these things are possible. Throws are precise and the gear lever just goes where you want it to go. Notchiness/crunch noises are pretty much gone.
Not hard to install if you have a lift. Could be a challenge on jack stands. This $130 goes a long way to improve your confidence and precision in shifting. Talking about night and day difference.
@PERRIN_Chris: My only negative feedback was that washers were not included in my package. Not using them, the polyurethane started to eat your bolt head! Luckily we undid the bolt and found washers lying around in the garage. @post_break also did not have washers in his package, he used a few leftovers from my headerback install.
I do not have any knowledge about if this helps automatic transmissions. I am not responsible for any damage as a result of this modification. Remember to be safe!
Installation Steps
Raise the car. A lift makes this 100x easier, but if you use stands, please lift the entire car onto stands to keep it level. Refer to @GrimmSpeed DIY here http://www.ft86club.com/forums/showthread.php?t=10111
20121012-PerrinRearShifterBushingDIY-01 by VictorN07, on Flickr
Service manual diagrams for reference
20121012-PerrinRearShifterBushingDIY-02 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-04 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-03 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-05 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-06 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-07 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-08 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-09 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-10 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-11 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-12 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-13 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-14 by VictorN07, on Flickr
20121012-PerrinRearShifterBushingDIY-15 by VictorN07, on Flickr
Finished!
F1point4 is offline   Reply With Quote
Old 10-14-2012, 09:40 PM   #2
GodSays
GodSays's Avatar
Drives: Beater
I have the Perrin bushing and personally I think the inner diameter of the whole is too big which could result in actually a sloppier shift. I won't install mine.
GodSays is offline   Reply With Quote
Old 10-14-2012, 09:54 PM   #3
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks!
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-16-2012, 10:25 PM   #4
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
doing this ASAP.
Jive Turkey is offline   Reply With Quote
Old 10-16-2012, 10:40 PM   #5
gmookher
what are you basing this on if you havent installed it? mine went on snug, and improved feel.
what do you believe the ID should be?
Old 10-16-2012, 11:30 PM   #6
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
subbed
ProjectD is offline   Reply With Quote
Old 10-17-2012, 12:22 AM   #7
luxmn
First FR-S
Drives: Whiteout MT FRS
I was waiting for this DIY. Thank you! did you take a side by side comparison photo?
luxmn is offline   Reply With Quote
Old 10-17-2012, 12:51 AM   #8
drew935
Auto Salon Works
drew935's Avatar
Drives: wrb
One side of the ID hole of the bushing that you slide on is bigger than the other end.
This is the same install for the WRX and STI and it does clean up the sloppy feel.
drew935 is offline   Reply With Quote
Old 10-17-2012, 01:14 PM   #9
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Great review! The kits are supposed to come with 2 washers, sorry about that! I'm having all of those kits checked to make sure they're in there.
PERRIN_Chris is offline   Reply With Quote
Old 10-20-2012, 04:48 AM   #10
JJGraphiX
Drives: FR-S Asphalt 6MT
So let get this straight... you bought it, received it, then took it out of the package only to say "yea that hole is too big" and set it aside only to come tell us about this miraculous discovery you've made?
Thank you so much.
The part works just as advertised and is a quality piece. I even got both washers
JJGraphiX is offline   Reply With Quote
Old 10-31-2012, 04:56 AM   #11
SleekMachine
SleekMachine's Avatar
Drives: Whiteout
I installed this like 30 mins ago and I don't like it at all.
The shifter now makes excessive noise - whenever I put it in gear there is now a winding noise. Also, at low rpms you can hear this winding noise. In cabin noise is obnoxiously loud.
When I downshift the winding noise increases significantly and has an extremely large amount of resistance compared to stock; as if I am forcing the gear in. At one point I was worried that I was damaging the gears, so I left it in neutral and braked.
Maybe I'm the only one with this issue, but I'm going to get it removed.
Also, Yes I have it in the correct orientation.
SleekMachine is offline   Reply With Quote
Old 10-31-2012, 05:07 AM   #12
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Sorry to hear that, bro
I definetely love my Perrin rear shifter bushing and there is no extra NVH noticed in a month time... Just pure shifting pleasure
MSTiFK8R is offline   Reply With Quote
Old 10-31-2012, 05:17 AM   #13
SleekMachine
Drives: Whiteout
Yea me too. I was so excited.
Old 10-31-2012, 07:39 AM   #14
Panman
Panman's Avatar
Drives: 86 GTS
Did you support the gearbox with a jack/lift during install?
Are you sure the driveshaft/propshaft was bolted back in correctly?
This sounds nothing like a bushing issue - I'd get a professional to check it ASAp
Panman is offline   Reply With Quote
diy, perrin, rear shifter bushing
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 06:18 PM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 04:48 PM
