Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-19-2012, 06:24 PM   #1
ChocolateNick
Drives: Sonic Blue GTS AT
GTS GPS maps out of date.
I was driving around Point Cook yesterday and found many of the streets don't exist on the map. Does anyone know how to update the maps?
Just relax.
ChocolateNick is offline   Reply With Quote
Old 10-19-2012, 06:48 PM   #2
Skorov
Skorov's Avatar
Drives: 86 GTS White
I would also like to know. It's missing some of the newer Safety Cameras as well.
Skorov is offline   Reply With Quote
Old 10-19-2012, 07:26 PM   #3
crimespree
Drives: 86
new sd card from toyota is the obvious answer...
not sure if they can be obtained using other means?? anyone?
crimespree is offline   Reply With Quote
Old 10-19-2012, 08:22 PM   #4
ChocolateNick
I am researching other means.
Just relax.
Old 10-19-2012, 09:17 PM   #5
Sutty
Sutty's Avatar
Drives: Sonic Blue 86 GTS 6AT
I contacted Toyota the other day about this.
Their response was:
Thank you for your email, please contact your local Toyota Dealership via their service department for information sat nav updates, these software updates are not covered by Toyota.
Thank you for contacting Toyota Customer Experience Centre
Kind Regards,
Robert Marsh
Customer Experience Consultant
Toyota Motor Corporation Australia
So contact your Toyota Service Dept about something that aren't covered by Toyota. Makes sense. Not got around to contacting service dept. yet.
Sutty is offline   Reply With Quote
Old 10-19-2012, 09:21 PM   #6
70NYD
70NYD's Avatar
Drives: RX8 S1
What brand is the GPS/maps in the car?
I a sure with that + 10 minutes of looking online you can find how/where to update your maps
70NYD is offline   Reply With Quote
Old 10-19-2012, 10:46 PM   #7
crimespree
Drives: 86
http://www.toyota.com.au/yaris/featu...h-audio-system
This is the system. I have spent a lot more than 10 minutes looking... Please take 10 and show me
Old 10-19-2012, 11:24 PM   #8
Bounce
Drives: I
You did it wrong! The nav system is pioneer AVIC-F840BT, unfortunately the .au site only offers support in the form of a pdf manual.
Where as the .eu site has firmware updates etc.
So you probably really need to get Toyota involved
Bounce is offline   Reply With Quote
Old 10-19-2012, 11:55 PM   #9
crimespree
Drives: 86
ummm.... you did it wrong...
the system i have from a GTS is the one I posted above!
same as the one from the toyota 86 .au website
at the bottom of this page.....
http://www.toyota.com.au/86/features/interior
Old 10-20-2012, 12:20 AM   #10
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
I took out my Manual and flicked it through. the maps are made by NAVTEQ. Which are the same developers that made maps called 'iGO' and 'NAVMAN' for my previous car (Suzuki Swift).
hope that helps now to look for updated maps
davey90 is offline   Reply With Quote
The Following User Says Thank You to davey90 For This Useful Post:
Skorov (10-20-2012)
Old 10-20-2012, 12:30 AM   #11
Bounce
Drives: I
Sorry got confused seems there's a heap of different types depending on region, thought the BRZ/GTS had the same but again it varies.
Old 10-20-2012, 04:41 AM   #12
crimespree
Drives: 86
I had a quick play today, couldn't even duplicate the original Toyota SD card that it came with....
"other means" don't look great
Old 10-20-2012, 04:45 AM   #13
70NYD
70NYD's Avatar
Drives: RX8 S1
If maps are made same for navmen, means they would more that likely be same format.
See if I had a GTS I would do this for you, probably in a day, but since I don't, all you get is my thought process in how I would get to the answer
Now if you find that format and get a new map, stick it on a sd card, and put it in to the nav unit, there has to be a map slot somewhere if not there is map update option somewhere in software using the standard sd/USB slot. It's either that or it takes maps of the DVD/cd (less likely as this is old method circa 05~)
There has to be a way to update maps, be it under setting in the unit, or starting the unit in update mode. I can't test any of this, but the method has to be simple, remember, dealerships have to do this so it has to be doable by a 10 year old :p
Edit
So there is a SD card slot!
What you mean you couldn't duplicate it?
Did you view it on the pc with view hidden files/folders? There will be a file/cluster that id's it
Old 10-20-2012, 04:52 AM   #14
crimespree
Drives: 86
Mate I don't even have my 86 yet!
The unit seems to read directly from the sd card. To update maps you just put in a new sd card.
Somehow it knows the duplicated card is a copy and won't boot. The copy has the same files and structure as the original.
Must have some form of protection....
I even tried dumping new 2012 iGo maps onto the copied card (folder structure matched) but still didn't work.
I'm not game to mess with with the original toyota sd card...
Pin your BRZ/FRS Location on Google maps! ShoGun Scion FR-S / Toyota 86 GT86 General Forum 137 02-12-2019 07:00 PM
Pin your BRZ/FRS Location on Google maps! ShoGun BRZ First-Gen (2012+) — General Topics 84 04-16-2014 12:50 PM
Canyon maps of California Calidrifter Southern California 1 06-28-2012 10:19 PM
Navi track maps chitownwrx Electronics | Audio | NAV | Infotainment 0 06-14-2012 12:23 AM
Possible date for revealing of price and release date CSSM Scion FR-S / Toyota 86 GT86 General Forum 200 03-22-2012 04:12 AM
