Old 10-18-2012, 03:54 PM   #1065
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Ok i got it
the TQ and the HP are BOTH at the crank
now everything is recalculated comparable, see #1058
even much more impressive
MSTiFK8R is offline   Reply With Quote
Old 10-18-2012, 04:16 PM   #1066
buditjoenawan
Drives: Very very slowly
I hope AVO chimes in; but from what I can tell from the chart, the torque is plotted as flywheel BUT the horsepower is plotted as wheel.
Just looking at stock curves:
Torque shows a peak of roughly 160ft-lb
Horsepower shows a peak of 165hp
More math:
At 5000RPM, chart shows roughly 185whp, but at that RPM, torque shows roughly 210w-lb-ft. But calculating for torque based on 185 @ 5000rpm gets us:
Torque = 185*5252 / 5000 which gives us roughly 194.
It also doesn't help that the scale for the two isn't identical. Tuning shops should really adopt some kind of standard way to show these graphs....
buditjoenawan is offline   Reply With Quote
Old 10-18-2012, 04:28 PM   #1067
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I believe both HP and TQ are at the WHEELS. You dyno tune it to measure what it makes at the wheel, why convert it back to flyhweel and then advertise it.
I still wanna know what CR the engine is now. Impressive either way given 91 octane
Tansey86 is offline   Reply With Quote
Old 10-18-2012, 04:39 PM   #1068
buditjoenawan
Aaah, I was referring to the AVO chart, not Crawford. Clarifying for.....clarity....
Old 10-18-2012, 05:04 PM   #1069
AVOturboworld
I know, it's confusing - wait a few days, I'll have the USDM figures on the turbo kit stage 1. That'll have base run vs. turbo run on same dyno/setup.
To clarify, the figures on the avo brz are in whp, but I'm waiting to do the dyno here for figures that are relevant to the US Market (and most other international markets).
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
Calum (10-18-2012), civicdrivr (10-18-2012), Sportsguy83 (10-19-2012)
Old 10-18-2012, 08:23 PM   #1070
Tansey86
Tansey86's Avatar
Any details on what further stages will upgrade?
Old 10-18-2012, 08:50 PM   #1071
Mechazawa
Drives: FR-S, 6MT, White
That is correct, that picture is of an oil reservoir tank.
The oil pump is mechanical, fully. And that's the final detail we will unveil when we are at SEMA. It's the most unique feature of the kit, and one of the reasons it's going to be so reliable.
I'm amazed this thread isn't full of speculation about the nature of the oil pump. I think either AVO found a way to tap into the stock pump's feed side, or they are using engine vacuum. I keep watching this tread looking for new hints.
Mechazawa is offline   Reply With Quote
Old 10-18-2012, 09:30 PM   #1072
2forme
You wouldn't happen to need a test car for that would you?
Old 10-19-2012, 02:26 AM   #1073
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Originally Posted by wcbjr View Post
Seems to be missing the ac lines and the pulley is not stock.
http://rumors.automobilemag.com/file...A20-engine.jpg
The picture you posted is a LHD car. The avo kit is on a RHD car..
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 10-19-2012, 06:38 AM   #1074
wcbjr
Drives: 2006 Subaru LGT
Yeah, they corrected me.
wcbjr is offline   Reply With Quote
Old 10-19-2012, 07:21 AM   #1075
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Ive placed my order
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 10-19-2012, 08:03 AM   #1076
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Ahhhh..... I almost had a heart attack there.... Thanks for clarifying.
Old 10-19-2012, 08:08 AM   #1077
Sportsguy83
Drives: Limited BRZ
Originally Posted by MSTiFK8R View Post
I dared to overlay AVO Stage_1 digits with Crawford build motor & turbo kit
Just to show how straight the power "curve" is and how flat the torque "curve" is with AVO Stage_1 ))
No direct comparison - two different world of approach, not even talking money wise
I hope someone finds this of use
I had not seen the Crawford Dyno sheet, I'm appalled at how the Torque just falls off.
I'm licking my chops for this AVO kit..
@AVOturboworld, do you guys offer 0% interest financing (even if it is say for 6 months or a year) on the kit? Just asking because I'll be able to afford it summer next year, but if I could finance it and pay it off in the summer why not....
Old 10-19-2012, 08:20 AM   #1078
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I'm doing the same thang )
And for the sake of comparison - Crawford is pushing 4 times more boost in it (21psi vs 5psi )
The Following User Says Thank You to MSTiFK8R For This Useful Post:
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
