#1037 |
Scrape Master
Drives: Goal: Oldest FRS State Side
yes they already said they are going to dyno the car running US gas.
#1038 | |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
BONKRS for life
#1039 | |
Drives: 2012 Toyota 86 GT (Black) :)
#1040 | |
I Love custom Turbo kits
Drives: Limited BRZ
#1041 | |
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Sent from my Galaxy Nexus using Tapatalk 2 |
#1042 |
Drives: BRZ WRB
Seeing limits of stock MAP sensor as 5psi, help me to understand:
these 250whp and 222ft/lbs are being reached with what exhaust exactly? I've seen this car has your catback - what about the other parts? ( front pipe, etc ) The reason why I ask is I will be having an aftermarket front pipe & mid pipe & rear section - so which numbers could I be hoping for staying with stock MAP sensor ? I mean will the more freeflow exhaust help in squeezing more power, despite staying on the same 5psi limit or not? I'd love to have something closer to 300whp\250ftlbs thanks! Mike |
#1043 | |
Drives: 2006 Subaru LGT
#1044 | |
Drives: 2013 Asphalt FR-S
And I believe their numbers were made with their exhaust.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#1045 |
#1046 | |
Drives: BRZ WRB
I'm just eager to see the options ) Seems like 8 psi sensor will be a bless I know these numbers were reached with AVO's manifold, " shorty overpipe", midpipe&muffler But there was nothing said reg the FRONT PIPE - was it catless or catted or left stock by some chance? BTW, the exhaust section on the AVO shop is still empty, so that's why I ask http://www.avoturboworld.com/avoshop...t-c-95_96.html |
#1047 |
#1048 | |
Also how can it not be a mechanical they stated it has no wires connected. I am not a electrical engineer but in order for power to get from a battery/alternator there has be at least two wire going to electric motor power and ground. This is why I am looking for clarification on the detail of the scavenger pump. Including location of the actual pump details of the wiring locations of the oil reservoir which I believe is mounted to the left of the turbo. |
#1049 | |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | MSTiFK8R (10-18-2012) |
#1050 | |
The oil pump is mechanical, fully. And that's the final detail we will unveil when we are at SEMA. It's the most unique feature of the kit, and one of the reasons it's going to be so reliable. |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
