Old 07-18-2012, 03:41 PM   #15
MrFRsLa
MrFRsLa's Avatar
Drives: 2012 Camry SE, 95 Honda Civic
Originally Posted by SkullWorks View Post
I get into the limiter more often than I would like because the motor doesn't sound like it is done yet, it is still pulling so strong it is hard to believe you are at rev-limit already.
I'm not sure who told you you want unburnt fuel being flowed through your catalyst, but that isn't the smart move buddy. fuel cut on a NA motor is fine,
It really just feels like the motor wants another 500-1000 RPM to play with
"It really just feels like the motor wants another 500-1000 RPM to play with"
I completely agree with this. Sound wise it seems like it wants to keep coming.
P.S. You finally got your ride Works?
MrFRsLa is offline   Reply With Quote
Old 07-18-2012, 03:55 PM   #16
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by Razz View Post
Wait for the Access Port by Cobb
I will do no such thing,
I am working closely with one of AEM's best to get a Series 2 up and running both the port and DI injectors, I have friends that work at Cobb but it just isn't a complete enough solution for what i have instore for this car.
MrFRsLa,
Yeah I drove it back from Denver on the 3rd/4th of july.
Old 07-18-2012, 04:04 PM   #17
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
On many cars the fuel cutoff "harshness" is relative to what gear you're in when hitting the limiter. The higher the gear the less harsh the cut is.
Old 07-18-2012, 04:18 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Hmm my opinion of the BRZ/FRS fuel cut is that it's damned soft.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
Guff (10-16-2012), rallysrt (03-30-2014), SkullWorks (07-18-2012)
Old 07-18-2012, 04:23 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Slick View Post
^^ this.
Set a lower rpm limit and stick to it.
I hit the rev limiter sometimes as well when I track it and it means I waited too long to shift. Adjust shifting points, done. And you will be faster too.
Faster? That depends. It's not always faster to have an upshift and then a downshift vs just leaving it against the limter for a half second or a second. It's also a lot smoother with two less chances to misshift or upset the car with a bad shift.
In my other cars there are certain turns at any given track that I will just bounce off the limiter at on purpose. I'm sure the same will be true with the BRZ, it has been in autocross already.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-18-2012, 08:50 PM   #20
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Felt about the same as my 05 XRS did with the 2zz-GE..
CircuitJerk is offline   Reply With Quote
Old 10-16-2012, 06:42 PM   #21
omgwtfbbqsauce
omgwtfbbqsauce's Avatar
^ YES!
omgwtfbbqsauce is offline   Reply With Quote
The Following User Says Thank You to omgwtfbbqsauce For This Useful Post:
Surok (10-17-2012)
Old 10-16-2012, 08:47 PM   #22
TuxedoCartman
Drives: '13 86
Originally Posted by clayrush View Post
I don't tend to do this on a regular basis, but I have het the limiter a fue times and it seems like it cuts in harsh compared to other cars I have driven. Almost like the car applies the breaks. I was just wondering what others opinions on this are. thanks
...BRAKES!!! It's spelled, "brakes"!!! B, R, A, K, E, S... brakes!!! "Breaks" is what would happen to your engine if you DIDN'T have a rev-limiter!!!
Ahh.... that made my inner grammer Nazi happy. Now, what were we talking about?
TuxedoCartman is offline   Reply With Quote
The Following 2 Users Say Thank You to TuxedoCartman For This Useful Post:
jm1681 (10-17-2012), wrxgoose (11-25-2012)
Old 10-16-2012, 10:56 PM   #23
Im_SPEED
Drives: FRS hot lava
Originally Posted by hankster View Post
or set the rev indicator with beeper ON so you hear it and don't have to actually see it?
I dont get how anyone can hear it its sooo quite
I agree i bounce off it all the time when i autocross i agree its very soft
Im_SPEED is offline   Reply With Quote
Old 10-16-2012, 11:00 PM   #24
Synack
Boosted
Synack's Avatar
Drives: Sideways
Go with ProEFI Start at 45 secs
[ame="http://www.youtube.com/watch?v=2n9wJiQecFs"]Scion FR-S Turbocharged - D3 - YouTube[/ame]
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
dori. (10-19-2012)
Old 10-18-2012, 04:58 PM   #25
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Your as bad as my girl friend. She is known to hit people for saying they have "seen" something.
I use the speak to text on my phone a lot for typing. I tend not to proof read it.
Back on subject..... The limiter does not seem as harsh as it did a fue months back. Either it has changed or I am use to it now.
clayrush is offline   Reply With Quote
Old 10-19-2012, 06:49 AM   #26
grodenglaive
Drives: asphalt FR-S
That wasn't my experience; I found the limiter is very abrupt compared to my Cooper S. You could ride the limiter for over a second and the car would not even slow down, it just stopped accelerating. The first time I hit the limiter in the FR-S, the deceleration was so quick, I thought something broke. Mind you, I was in 1st gear at the time.
Actually, now that I think about it; the MINI is nearly out of torque when you get near the redline, while the FR-S is deep in the power band. That would explain the difference I feel when it hits the limiter.
grodenglaive is offline   Reply With Quote
Old 10-19-2012, 02:33 PM   #27
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
Last time I was at Cobb they told me they stopped R&D on the Zx6s. Couldn't ge that much out of the engine so they quit.
Linseal is offline   Reply With Quote
Old 11-25-2012, 01:14 PM   #28
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
def is soft, my last car if i hit the limiter, my chest would be against my seat belt. I kinda wish this car was set up like my last car stock.
stock Redline at 7800 rpms, fuel cut at 8450 rpms.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Top/Speed limiter for the 86? DriftEightSix AUSTRALIA 4 09-12-2012 02:53 AM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-02-2012 12:54 AM
FUEL JDMSushi AUSTRALIA 23 07-19-2012 12:01 AM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 11:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-03-2010 12:05 AM
