Old 07-17-2012, 09:38 PM   #1
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
rev limiter / fuel cutoff
I don't tend to do this on a regular basis, but I have het the limiter a fue times and it seems like it cuts in harsh compared to other cars I have driven. Almost like the car applies the breaks. I was just wondering what others opinions on this are. thanks
clayrush is offline   Reply With Quote
Old 07-17-2012, 09:39 PM   #2
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
It is unforgiving....you hit it and the car goes "HEY MORON, I JUST TURNED YOUR GAS FLOW OFF"
Pscylo is offline   Reply With Quote
The Following 2 Users Say Thank You to Pscylo For This Useful Post:
flippy (11-26-2012), Ingen (11-29-2012)
Old 07-17-2012, 09:42 PM   #3
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
Yup, I hit the rev limiter a few miles after breaking in. And yes it is pretty harsh.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 07-18-2012, 12:43 AM   #4
clayrush
I wish I could soften it somehow, outside a stand alone cpu.
Old 07-18-2012, 12:44 AM   #5
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
Who you telling!!! I drift this damn thing and I hate when it does that.
Ocho-Seis is offline   Reply With Quote
Old 07-18-2012, 01:52 AM   #6
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
It's aburupt feeling comes from the fact that this is a proper naturally aspirated high compression sports engine. And the compression is high to produce high resistance, and there isn't a heavy flywheel to stop it either. This combined with a light car makes it double harsh. The best way is to remove the limiter altogether, and to be good enough at driving to NOT over-rev the engine.
But with warranty that needs to go on cars and with number of inexperienced drivers who "THINK" they know how to drive, and even some seasoned guys... Factory cars will always have governors to keep it from self destruction as least as possible...
So there isn't really a way to soften this as if something is cut, then compression will slow it down more than a normal engine. Perhaps though, we will one day find a crack to the ECU so that it will fire half the cylinders and "LIMIT" the power output by ignition cycle/sequence, rather than cutting off fuel...and stopping the ignition cycles, making this a bit safer for the engine, and to reduce the bog-down effect.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
The Following 8 Users Say Thank You to Moto-P For This Useful Post:
clayrush (07-18-2012), dattran86 (04-21-2017), Fish (07-18-2012), flippy (11-26-2012), Guff (10-16-2012), sittinSideways (07-20-2015), SpeedR (10-19-2012), TPO (07-18-2012)
Old 07-18-2012, 02:54 AM   #7
clayrush
Thanks for the detailed reply.
I think my biggest problem is that I am used to my Celica GT-S and winding it to 8300 RPM's so I land the RPM's over the 6k VVTL-i mark when i shift. Also I tend not to look at my tach when I am driving aggressively and don't notice the shift light blinking.
also my gt-s has a fairly high compression at
11.5:1 with a lightweight flywheel and i don't get verry much of a slam feeling. But I also wonder if part of that is because the gt-s is at it's top RPM and is at the down side of it's power curve, where the FRS not so much.
Old 07-18-2012, 09:34 AM   #8
harajukukei
Drives: MB c230k
You could try getting a Bee-R rev limiter. It cuts ignition instead of fuel, much safer for the engine.
harajukukei is offline   Reply With Quote
Old 07-18-2012, 12:57 PM   #9
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
or set the rev indicator with beeper ON so you hear it and don't have to actually see it?
hankster is offline   Reply With Quote
The Following 4 Users Say Thank You to hankster For This Useful Post:
Chad86 (03-17-2014), dori. (10-19-2012), Imti (07-18-2012), Nitesh31 (10-14-2012)
Old 07-18-2012, 01:03 PM   #10
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
^^ this.
Set a lower rpm limit and stick to it.
I hit the rev limiter sometimes as well when I track it and it means I waited too long to shift. Adjust shifting points, done. And you will be faster too.
Slick is offline   Reply With Quote
Old 07-18-2012, 01:05 PM   #11
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I sometimes hit the limiter because I'm used to the sound my K20 made approaching 9k rpm and that was my cue. Now I'm like oh.. right!
eriktherod is offline   Reply With Quote
The Following User Says Thank You to eriktherod For This Useful Post:
TheGuyWithTheFireStorm (11-25-2012)
Old 07-18-2012, 01:26 PM   #12
empower-auto
Kouki-Monster
empower-auto's Avatar
How bad is this with the tires spinning? Sounds pretty crippling or a drift car.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-18-2012, 01:57 PM   #13
SkullWorks
Drives: SSM LT MT BRZ
I get into the limiter more often than I would like because the motor doesn't sound like it is done yet, it is still pulling so strong it is hard to believe you are at rev-limit already.
I'm not sure who told you you want unburnt fuel being flowed through your catalyst, but that isn't the smart move buddy. fuel cut on a NA motor is fine,
It really just feels like the motor wants another 500-1000 RPM to play with
Old 07-18-2012, 02:40 PM   #14
Razz
Razz's Avatar
Drives: Fast
Wait for the Access Port by Cobb
Razz is offline   Reply With Quote
Top/Speed limiter for the 86? DriftEightSix AUSTRALIA 4 09-12-2012 01:53 AM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-01-2012 11:54 PM
FUEL JDMSushi AUSTRALIA 23 07-18-2012 11:01 PM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 10:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
