Old 10-16-2012, 10:53 AM   #2619
UncleFester
Alrighty
If your missing something , e85 tune, 100 octane tune, Crawford AOS or having issues with the tune file not flashing please fill this form out.
Please fill this form out ONLY if you have a 6 Speed.
Visconti Tuning Request Form
Still no cable or tunes for my auto. Guess that will be another form?
UncleFester is offline
Old 10-16-2012, 10:58 AM   #2620
gms
gms's Avatar
Drives: Toyota GT 86
Alrighty
Still no cable or tune for MT. But located in Germany. Not possible to choose in form.
What is to do here?
gms is offline
Old 10-16-2012, 11:17 AM   #2621
Yruyur
Yruyur's Avatar
No cable = missing proecu kit
Yruyur is offline
Old 10-16-2012, 11:32 AM   #2622
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Form filled out!
Gregory Gawaran is offline
Old 10-16-2012, 11:33 AM   #2623
xjohnx
Grip>Slip
xjohnx's Avatar
John's watching the form for updates. No need to post here after completing it.
xjohnx is offline
Old 10-16-2012, 11:42 AM   #2624
gms
gms's Avatar
Missing ProEcu Kit... I know...
Can't choose location "Germany" or "somewhere else in the world"...
Is the Form just for US and Canada????
gms is offline
Old 10-16-2012, 11:44 AM   #2625
xjohnx
Grip>Slip
xjohnx's Avatar
For the most part. Just enter a US state and in the comments section include your actual address.
xjohnx is offline
Yruyur (10-16-2012)
Old 10-16-2012, 12:01 PM   #2626
Calum
That Guy
Drives: 2013 asphalt FRS MT
Ok, I did some playing and here's my findings.
Flat Foot shit work if you have the gas matted. Lift even the tiniest bit and you bounce off the rev limiter.
Map switching works. Pull lever back toward driver, wait until tach points to number corresponding to map I'm presently running. Push lever up or down to change maps, and pull lever toward me again to set the map.
Auto blip is not rev matching, as I understand it. I've had the car blip once and I wasn't paying full attention to where my feet were so I don't yet know what I'm doing wrong. I've tried many times to do what I've seen in the video. Feelin' a little stupid about this one.
Launch control doesn't seem to work. I've tried in all four maps and every time I just bounce off the rev limiter. I'm wondering if there's more to this, such as some way to turn it on within the map. But that doesn't seem to fit with everything else.
A/F and tank % are working, just not correctly. My cluster reads in liters/100 kilometers. If I do the conversions from L/100km's to mpg(US)the numbers work properly. As it is, I just filled up and I'm showing 2.4 which would equal 98% fuel in the tank. Under WOT I'm showing 18.4-18.8 which is 12.7-12.5 air fuel ratio.
@Visconti, if you or if ECUTEK needs a Canadain cluster, to test conversion software, shoot me a PM.
Last edited by Calum; 10-16-2012 at 12:20 PM. Reason: shitting grammer got slightly better
Calum is offline
The Following 2 Users Say Thank You to Calum For This Useful Post:
JPxM0Dz (10-16-2012), LeavingNormal (10-16-2012)
Old 10-16-2012, 12:12 PM   #2627
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Calum View Post
@Visconti, if you need a Canadian cluster, or if ECUTEK needs a Canadain cluster, to test conversion software, shoot me a PM.
the clusters should be the same, just a matter of whether it's in KM/h or MPH mode, no? i can try to verify on my way back to work from my lunch break by switching to metric.
xjohnx is offline
Old 10-16-2012, 12:19 PM   #2628
Calum
That Guy
No, it always reads in liters / 100 kms. I can change from km/hour to miles/hour, but that doesn't change the fuel consumptions read out. Trust me I tried.
Calum is offline
Old 10-16-2012, 12:30 PM   #2629
xjohnx
Grip>Slip
xjohnx's Avatar
ahh. in that case, good eye! i'm sure John will be in touch regarding this and a couple other minor bugs in the near future.
xjohnx is offline
Old 10-16-2012, 12:44 PM   #2630
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I'm gonna keep harassing you post a video flash how to
2URGSE
JPxM0Dz is offline
Old 10-16-2012, 12:45 PM   #2631
xjohnx
Grip>Slip
xjohnx's Avatar
i was going to but then someone else said they were on it.
xjohnx is offline
Old 10-16-2012, 12:48 PM   #2632
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
Hawaiian said he's got a video already just needs to put it together and post it.
LeavingNormal is offline
The Following User Says Thank You to LeavingNormal For This Useful Post:
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
