Old 10-16-2012, 10:38 AM   #85
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by -max- View Post
Tires are 255 star specs and running 35 front 33 rear. No fsb. Only mods are the Kws with the stiffer spring on the front and rear whiteline camber bushings.
Should add that this is a relatively low grip surface. Pad is very new.
What offset wheels? Any rubbing?
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 10-16-2012, 10:43 AM   #86
-max-
Drives: Firestorm FRS
17x9 Offset is 43, no rubbing at all.
-max- is offline   Reply With Quote
Old 10-16-2012, 11:26 AM   #87
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I agree with a bit stiffer front bar. FWIW, it looks like we are about 2 weeks away on the 22mm hollow I've developed. I would not do a stiffer rear. A bigger rear bar will simply make pulling an inside rear tire up easier.
As for the other stuff. Again, I can't spout off about my stuff publicly. However, I am not running that much camber in front, and more in the rear and I get great front wear. I'm on 17x8 245 R-S3's.
Sam Strano is offline   Reply With Quote
The Following User Says Thank You to Sam Strano For This Useful Post:
Scooby South (10-16-2012)
Old 10-16-2012, 11:45 AM   #88
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I'm surprised you need more pressure at that camber and spring rate. Did you try turning the front compression down? Also, low grip lots are like driving the rain. Everything softer usually works better.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-16-2012, 12:03 PM   #89
Sam Strano
Sam Strano's Avatar
Originally Posted by Scooby South View Post
I would definitely consider the KW's...LIFETIME warranty should do it.. Talk to Sam at Strano Performance...I hear he can get a smoking Deal on these... PM him or Call ...
I absolutely love them... Nothing against any of the other brands.. just my opinion of course..
Any other Questions LMK
Bill
Yep, I'm not allowed to publicly tell anyone the pricing but it's pretty damned good and it is less than what you see "advertised" around. If I had the price up it'd have to be the same because it's what I'm advertising. I'm not advertising the actual price I sell for though. Only catch, you have to ask me.
I use KW's on my car, Bill has his set he got here. ABQautoxer just got some for his car here too.
Old 10-16-2012, 12:09 PM   #90
ABQautoxer
ABQautoxer's Avatar
Definitely call Sam. I saved a lot of money and got the base settings I needed to save me time. They shipped the same day I ordered them and I just got a call they were delivered.
TomR
Old 10-16-2012, 12:16 PM   #91
-max-
First thing I did was lower everything. It helped, but I could not get it where I think it should be.
Old 10-16-2012, 12:18 PM   #92
ABQautoxer
ABQautoxer's Avatar
While not the end all of shock tuning advice, this chart is pretty good if you are less experienced with it.
EDIT: Also, how low are you? Do you have tophats that give you more caster?
TomR
The Following 4 Users Say Thank You to ABQautoxer For This Useful Post:
autobrz (09-06-2013), BRZranger (10-16-2012), Scooby South (10-16-2012), simpleisbest (10-16-2012)
Old 10-16-2012, 02:42 PM   #93
-max-
Forgot that I have the whiteline camber/caster plates.
I think I'm at 13 1/4" front 13 1/2" rear, hub to fender. I think the lowest recommend is 12.5".
Old 10-16-2012, 04:55 PM   #94
-max-
Just ordrered your bar! Hope it makes it in for my next event.
Old 10-16-2012, 05:28 PM   #95
Sam Strano
Sam Strano's Avatar
Looking like we are about 2 weeks from they showing up at my shop.
Old 10-17-2012, 01:45 AM   #96
ABQautoxer
ABQautoxer's Avatar
I won't know if those measurements are what I would use or not until probably this weekend. However did you corner balance? Just wondering maybe it turns better in one direction? I would think it would work well unless the lot just sucks.
TomR
Old 10-17-2012, 07:13 AM   #97
-max-
Not corner balanced yet. Seemed to act the same in either direction.
Old 10-18-2012, 08:02 PM   #98
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Chomping at the bit, also have my order in.
Evil86 is offline   Reply With Quote
My BRZ ST* Autocross build Scooby South Tracking / Autocross / HPDE / Drifting 848 08-14-2018 11:20 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
1st Autocross w/ my FR-S MarkRacerX FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 06-24-2012 10:55 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
