Old 10-15-2012, 09:46 PM   #2563
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
Got the tune uploaded, idled for 5mins (not sure if needed but what the heck why not), restarted and idle for a few mins, then drove for 15-20mins. During the first 10 secs of idle, i had 2 or 3 minor backfire, not sure why that happened but it didnt' reoccur. All is well.
Initial impression on STG1 v1.07:
  • Off the line throttle response under normal driving seems to be dulled down a little. It felt better after some miles. May improve after a while.
  • Mid-high range definitely pulls harder, especially mid! Felt very similar to my old 08 Si K20 (in a good way. ie rev happy) with bolt on and ECU tuned , but with more torque!
  • Very odd but it even sounds different (louder) at WOT in mid and high. Airaid intake was already on the car.
  • STG1 Tune feels awesome.
Time for some datalogging and few hours of track time on Wednesday.
Hopefully John will still look at my data in 6months since my car will be in storage this week.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline
Old 10-15-2012, 10:03 PM   #2564
Carwhisperer
Drives: A lot of supercars.
Very nice review, suprised how noticable the gains are even with the STG1 Tune. Very impressive. I'm just under 10k miles, with just perrin crank pulley, and a front strut bar. But the stock intake has settled in and actually has a whistle to it at 5k rpm+. I'm waiting for K&N to come out with one. Very nice review again.
Carwhisperer is offline
Old 10-15-2012, 10:06 PM   #2565
Yruyur
Yruyur's Avatar
There is K&N. I just get a trd which is pretty much the same. Yes this stg 1 makes the car entirely different joy to drive.
Yruyur is offline
Old 10-15-2012, 10:10 PM   #2566
dabocx
dabocx's Avatar
Drives: Scion FRS
Is the stock flash you included still the original stock flash i bought the car with in june or is the more recent one?
Taking in the car on Saturday for the idle dip issues and im going to flash back to stock for that.
dabocx is offline
Old 10-15-2012, 10:19 PM   #2567
Chokeefrs86
Drives: 04 350z 05 xb
Originally Posted by Foobar View Post
This is how I confirmed: ignition on the ON position, engine not started. Pull on the cruise control lever until you see the tach flip to 1K. Now push the cruise control lever up to cycle to 2K, 3K, and 4K, then push down to cycle back to 3K, 2K, and 1K.
If this works for you, then you've got map switching, and therefore the rest of the new RaceROM goodies.
Note that you can switch maps even while the engine is running, it's just easier to see the 1K tach setting with the engine off since it starts from 0. If you did it while the engine was idling, you're already right around 1K.
Got it working thanks foobar..
Chokeefrs86 is offline
Old 10-15-2012, 10:21 PM   #2568
cruzinbill
Drives: Argento 6spd FR-S
Anyone know how to set the rpm for the LC?
cruzinbill is offline
Old 10-15-2012, 10:25 PM   #2569
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
John sent me the wrong tune also
Lee358 is offline
Old 10-15-2012, 10:28 PM   #2570
xjohnx
Grip>Slip
xjohnx's Avatar
once you've got the clutch down and the gas floored it should default to 4k RPM limit if i recall. to adjust that, limit, just move the cruise control stalk up or down.
xjohnx is offline
Old 10-15-2012, 10:28 PM   #2571
Yruyur
Yruyur's Avatar
Up on the cruise control. There are YouTube videos on it.
Yruyur is offline
Old 10-15-2012, 10:29 PM   #2572
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Press clutch to the floor...hold gas to the floor and once it starts bouncing use the cruise control stalk up and down to adjust the rpms
brichard0625 is offline
Old 10-15-2012, 10:35 PM   #2573
cruzinbill
hmmm mine does not. I have tried all the maps. it revs all the way up. Only thing that appears to work is the autoblip. FFS doesnt seem to do anything either. ive tried from 3k all the way to 7k, just over revs.
Old 10-15-2012, 10:36 PM   #2574
jpit
Drives: Subaru BRZ
I'm getting a message saying that the ROM is not customized for my vehicle. Seems to accept the stock flash. Just got my ECU back from the UK and they installed a standard ROM. Hope that isn't the problem.
jpit is offline
Old 10-15-2012, 10:42 PM   #2575
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I am all tuned up now. Fuel level in map 1 doesn't want to work and just shows 2.3-2.4 even tho I just filled my tank. John's tune wore a couple mm off my brand new winter tires so I will be looking for some compensation or a refund LULZ.
Apoc is offline
Old 10-15-2012, 10:45 PM   #2576
Yruyur
Yruyur's Avatar
Did they put your vin on the new ecu. I think the tunes are locked down to vins on the ecu. Stock may not have that.
Yruyur is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
