AVOturboworld
Old 10-15-2012, 01:47 AM   #953
AVOturboworld
The stock map sensor works on our 5psi build, so no, no reason to add it to the base kit at this time.
The Following User Says Thank You to AVOturboworld For This Useful Post:
OmarGC (10-15-2012)
Old 10-15-2012, 01:50 AM   #954
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Are there plans to offer a ceramic coated header "option" in the kit? I'm not a fan of wrapping the header on a daily driver.
Ravenlokk is offline   Reply With Quote
The Following 3 Users Say Thank You to Ravenlokk For This Useful Post:
drifter (10-15-2012), JoeBoxer (10-15-2012), scyzer (10-15-2012)
Old 10-15-2012, 04:49 AM   #955
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
So people that want to run more boost on the base kit will need to go out and buy a new map sensor? or will you be supplying this options for us.
I want to run around 10psi do you think the base kit could handle this or would I have to look at stage two?
Sorry to badger you even before the kit is released :s
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
The Following User Says Thank You to DriftEightSix For This Useful Post:
scyzer (10-15-2012)
Old 10-15-2012, 06:28 AM   #956
AVOTurboworldJapan
Originally Posted by SnapOv3st3r View Post
Link to the D1 car?
Here You go
http://www.speedhunters.com/2012/03/...he_build_pt_2/
http://www.speedhunters.com/2012/03/...he_build_pt_1/
AVOTurboworldJapan is offline   Reply With Quote
Old 10-15-2012, 06:38 AM   #957
AVOTurboworldJapan
No this will not be a option from the factory. You can request it when you order the kit from AVO USA, Australia ect. They will need to ship the manifold out to a local ceramic coating company to have it coated before we ship you the kit.
Old 10-15-2012, 07:30 AM   #958
AVOTurboworldJapan
We are working with ECUTEK to increase the limit on the stock map sensor from 5 PSI to 7 PSI. Also we are looking in to a higher pressure map sensor for the future upgrades.
The Stage 1 kit ECUTECK Map data will be for a 5 PSi Tune on 91 Fuel
In the future there will be different levels off tunes with option parts, Power filter Carbon air box Ect.
Every day ECUTEK is improving the software so we have more control over the ECU. My target is to have the car run like it was tuned from the factory with tuned Toque and Power and Reliability.
I will be in USA to check the tune on the AVO USA's FRS from the 24th. We plan to do 3000 miles on the road from Seattle to LA then to SEMA then After SEMA back through Utah. Full throttle tuning on a DYNO is only a small part off the tune going from NA to turbo Close loop to Open loop on those Vegas hills to Utah at 90f make,s a good place to get a good tune.
Regards Ross Wilson
The Following 6 Users Say Thank You to AVOTurboworldJapan For This Useful Post:
Calum (10-15-2012), civicdrivr (10-15-2012), MSTiFK8R (10-15-2012), OjiGeorge (10-15-2012), os86 (10-15-2012), scyzer (10-15-2012)
Old 10-15-2012, 07:48 AM   #959
os86
Drives: 2jz
Sounds awesome. Wish had my 86 already
Question regarding factory spark plugs. Will they be fine with stage 1 kit 5-7psi boost ?
os86 is offline   Reply With Quote
Old 10-15-2012, 08:00 AM   #960
AVOTurboworldJapan
So far on my BRZ they are still stock.
The Following User Says Thank You to AVOTurboworldJapan For This Useful Post:
os86 (10-15-2012)
Old 10-15-2012, 08:08 AM   #961
bakerr6
Drives: 2013 raven black fr-s
If anyone wants ceramic coating, let me know. I have a very good friend, whom if I took multiple parts up to him, he would only charge me 5-10% over cost to have it done
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
Calum (10-15-2012)
Old 10-15-2012, 08:58 AM   #962
Calum
That Guy
Drives: 2013 asphalt FRS MT
Regards Ross Wilson
Old 10-15-2012, 09:16 AM   #963
subatoy
subatoy's Avatar
Drives: subatoy
AVO correct me if I'm wrong but it sounds like California people are the only ones that won't need an extra tune after the kit is installed since the map is made for 91 Oct.
subatoy is offline   Reply With Quote
Old 10-15-2012, 10:04 AM   #964
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Question @AVOturboworld @AVOTurboworldJapan, will your included ECUTek flash include all the RaceRom features of ECUTek, like flat foot shifting, Launch Control ETC?
Also, will we be able to purchse the ECUTek license and cable through you?
Also, it would be nice if you guys consider for the Stage 1 tune at least for the USA kits to have an option for 93 (even if as an upgrade $$), because most everyone in USA has 93 accessible (California aside of course), and I would be happy with your initial numbers, and would rather pay you guys to fine tune for 93 than getting a local tuners give me a whole new different tune than yours.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 10-15-2012, 10:17 AM   #965
nix
nix's Avatar
Drives: AVO BRZ
Thanks for the update Ross... stoked to hear that. Will you do an AU tune for bp98 and will you guys provide free updates for new ecutek features/factory ecu updates?
My original plan was getting the local ecutek suby shop to tune it, hopefully with e85 flex sensor if its supported eventually but I guess even if your tune is for 91 it will include the cable and license?
nix is offline   Reply With Quote
Old 10-15-2012, 10:21 AM   #966
Opposed
Drives: 2013 Asphalt FR-S
Sounds like you will have to pay extra for the license at cable. If you have those two items already, then AVO will just send you the base map that is included.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
