Old 10-14-2012, 01:22 PM   #29
einzlr
Drives: several
Originally Posted by enjoi23 View Post
you're right there aren't hills. but there are highway ramps to get onto other highways that go pretty high and inclined. AND they have traffic at times. I wouldn't need to use it all the time, but I just want to be prepared for when I do.
Very smart!
You've gotten some good tips in this thread. Are you starting to catch on what it is you need to practice?
I learned how to start on a steep slope by watching my father do it in San Francisco (on streets like the one that goes up to Lombard like someone here mentioned lol). Use the handbrake to hold the car. Carefully let out the clutch and get on the gas til just past the engagement point and you can feel the car fighting the handbrake. Then start slowly easing off the handbrake. So you're balancing three things at once: clutch, gas, handbrake. If you can, find a *slightly* sloped empty street to practice, then move on to steeper slopes. That would be the ideal case to learn; unfortunately the world isn't really set up like that so you have to do the best you can lol
einzlr is offline   Reply With Quote
Old 10-14-2012, 01:28 PM   #30
einzlr
Drives: several
Originally Posted by Gen View Post
Just practice on this.
Where is that?
Old 10-14-2012, 01:34 PM   #31
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
It will come with time. I remember pulling out of certain parking lots here in Houston was terrifying at first. Learning exactly where the clutch grab point is and stopping being afraid of hills kind of go hand and hand.
I just hold the brake with my right and release the clutch until I feel it grab just enough to take the engine rpm down without stalling, then I quickly slide my foot off the brake and onto the gas and accelerate normally. I have never tried the handbrake technique because I haven't needed it here in Houston.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 10-14-2012, 03:04 PM   #32
themadpants
Drives: .
Originally Posted by einzlr View Post
Very smart!
This is actually the technically correct way to hill start. The best kind of correct
I used to instruct drivers in South Africa, where most people drive manuals, and a hill start is actually part of your test (along with alleyway and parallel parking) on a controlled course at the DMV.
ANY rollback is an automatic fail, as it is unsafe and you are not in control of your car.
Oh, and people talking about burning out your clutch? If you are concerned about that on a hill start, your revs are far too high!
Practice makes perfect, and the above method is definitely the textbook method.
Flame suit on!
themadpants is offline   Reply With Quote
Old 10-14-2012, 05:27 PM   #33
Jwong
Drives: fr-s
you could try using the e brake method
Jwong is offline   Reply With Quote
Old 10-14-2012, 06:24 PM   #34
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I just 'catch' the car with the clutch (after letting go of the brake) then add RPMs. usually the amount you slip the clutch isn't any more than a normal start on level ground.
dori. is offline   Reply With Quote
Old 10-14-2012, 11:44 PM   #35
jmaryt
Drives: 2012 honda civic ex
I'm pretty good at driving standard, but the slopes still are nervewrecking for me. I was wondering how you guys go about driving up slopes.. and slopes in traffic. I get the whole parking break thing, but I feel like that would burn either my clutch or break if I keep doing that up a slope during traffic. . .
Originally Posted by Vladror View Post
find yourself a quiet uphill road and practice till you get it, that's how my dad taught me 20 years ago...
the concept is quite easy but it really does take a lot of practice: you need to find the spot where the engine 'holds' the car, with the clutch fully engaged.
if your RPMs are too low, the car will stall, if too high, it will lunge forward.
the mistake that most people make is that they try to prevent either by using the clutch to compensate, and that's what will burn it in the long run.
the amount of RPM you need will vary on the steepness of the slope, so that's a matter of experience but in this car 2500 RPM should be more or less all you need in most situations. Once you get the right revs, you can release break and clutch at more of less the same time as the clutch will grip when the handbrakes stops gripping.
So remember, use your throttle to control the car, not the clutch. When done well a hill start requires as much clutch engagement as a normal gear shift.
Originally Posted by frosty86 View Post
i'd rather burn the clutch a little bit instead of backing up into someone's car... so i always use the e-brake to be 100% sure. But that's just me.
this is correct! (throw tranny in neutral) learned this 45 years ago! this eliminates "burning" up the clutch,and properly holds the car on the grade,until you are ready to engage first,and move forward!
jmaryt is offline   Reply With Quote
Old 10-14-2012, 11:45 PM   #36
jmaryt
no need to "slip" the clutch at all!
Old 10-15-2012, 12:29 AM   #37
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by ML View Post
The absolute first attempt I ever had in a manual at 14 was up a hill in reverse in the grass....sideways....with no shoes on....in the snow....and there was a cougar in the car with me.
How did you do Ricky?
raul is offline   Reply With Quote
Old 10-15-2012, 12:57 AM   #38
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Maybe it's just a play on words but you can't help but slip the clutch each time you take your foot off the clutch pedal. How much depends on how well you can handle a manual.
whaap is offline   Reply With Quote
Old 10-15-2012, 12:58 AM   #39
jmaryt
Flame suit on!
no flame here,as this is "dead nuts" accurate! absolutely correct! no need to slip the clutch,and your revs do NOT need to be high to accomplish this! balancing clutch,gas,and e-brake gets it done!
Old 10-15-2012, 02:58 AM   #40
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
I was never told to try the e brake thing when I was learning to drive (I learned on stick). Add to that that it was a truck with a foot ebrake I said forget learning that. So eventually I just got used to timing the release of the brake and clutch and getting on the gas a bit as the clutch starts to engage. When I was starting out I used to look at the revs to see if they were dropping that's when I knew to start adding gas. Just have to practice, I used to practice (and from time to time still do) in our driveway since its a pretty decent incline
00NissanNinja is offline   Reply With Quote
Old 10-15-2012, 04:32 PM   #41
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Originally Posted by be6sti View Post
One last thing in my state anyway if while driving a manual car if you roll back into someone it's actually the other persons fault for not keeping a safe distance. Check into that
Hitting someone from behind is always the driver's fault behind, but you rolling into their car doesn't apply unless they're RIGHT on your tail. However, if you roll into them, it could be argued that it's still your fault.
I get where you're trying to go with this, but NO ONE should rely on this tidbit of information.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 10-15-2012, 11:45 PM   #42
motofan
Drives: 10 VW GTI
Find summer a job in San Francisco or Seattle downtown which includes free parking.
motofan is offline   Reply With Quote
New Manual transmission drivers Q&A garsh0p Engine, Exhaust, Transmission 136 10-30-2014 07:14 PM
Anyone else experienced an oil change ordeal? terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 11-06-2012 03:06 PM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 11:24 AM
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
A few questions for experienced drivers of this class of car Partial Stall BRZ First-Gen (2012+) — General Topics 25 04-17-2012 11:42 PM
