Old 10-11-2012, 11:24 AM   #15
CBR600RR
Drives: Raven Black
Don Accellerated blew something in his tranny after he smoked two clutches,
Old 10-11-2012, 12:20 PM   #16
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Yeah, but that was because he caught air...
kmbkk is offline   Reply With Quote
Old 10-11-2012, 12:30 PM   #17
CBR600RR
Drives: Raven Black
^correct so not necessarily because of the 400hp+
Old 10-11-2012, 12:54 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
you're gonna have to tear apart the block to replace the piston rings you fried. Ringland issues have been prominent in Subaru's. Usually #4.
Old 10-11-2012, 01:06 PM   #19
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
If I recall correctly, the ringlands in this engine are a wee bit beefier. But my money's on the rods/ringlands.
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
finch1750 (10-11-2012)
Old 10-11-2012, 01:15 PM   #20
drifter
Drives: truck and old car
Originally Posted by VSGTS14 View Post
the piston rings. a factory subaru rod is pretty damn strong, for them to fail is very rare.
it's always the piston rings....or the heads will lift, since the motor wasn't designed for the boost.
but what do we know, subaru may have built this thing strong as hell knowing that they failed with the sti's stock block on later models and knowing the aftermarket world was going to turbo the poop out of the car.
Not having any experience with this.. would it be fair to say there would be much less chance of this happening to a ...say...AVO stage 1 turbo which would minimize booste to about 50 or 70 hp? (I believe that was at 5 psi)
thanks.
drifter is offline   Reply With Quote
Old 10-11-2012, 01:17 PM   #21
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Whatever breaks, were gonna need the mad scientist to rip it apart and rebuild it.
Tansey86 is offline   Reply With Quote
Old 10-11-2012, 01:37 PM   #22
cobrabyte
cobrabyte's Avatar
Crawford's bandsaw'd piston:
http://www.facebook.com/BRZClub/posts/407849379278427
Looks considerably more beefy than the EJ pistons.
Old 10-11-2012, 03:02 PM   #23
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
Headgaskets? seems to be the most likely failure point (as designed to be)
dsmx17 is offline   Reply With Quote
Old 10-11-2012, 05:11 PM   #24
finch1750
finch1750's Avatar
Idk why I keep clicking thanks instead of quote today. Lol
Anyway, could be true. Though Subaru rods are usually pretty solid. Either way I think Full Blown will be the ones to give us the answer in due time. 500+ HP. Damn....
Old 10-11-2012, 05:49 PM   #25
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
thanks.
as soon as you add a turbo kit, you're putting that motor under new stress and your pistons rings are sure to blow way faster than a factory motor.
but we haven't seen anything blow yet.
VSGTS14 is offline   Reply With Quote
Old 10-11-2012, 07:27 PM   #26
xwd
I believe on NASIOC Crawford mentioned the ring lands were almost twice the diameter of the EJ257 ones.
The key to all of that is tuning and staying away from detonation, it's what kills EJ257 ring lands, not necessarily boost pressure. All this high HP builds are making power on E85, it will be interesting to see how much reliable power folks get on 91/93 and how long the motors last.
I'm going to say rods or bearings, maybe head gasket. I'm hoping not rods because that can cause fairly catastrophic damage depending on what happens.
Old 10-13-2012, 07:27 PM   #27
Cyrious G
Pro Tire Killer
Cyrious G's Avatar
Drives: 2013 Scion FRS
Im interested to see if the trans will hold up to any more than 400whp.
Cyrious G is offline   Reply With Quote
Old 10-13-2012, 07:33 PM   #28
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
I'm going to say head studs will stretch somewhere approaching 500wtq, lifting the heads, and blowing the gaskets.
TheRipler is offline   Reply With Quote
If the ft86 fails... Sea1monkey2 Other Vehicles & General Automotive Discussions 33 07-16-2011 05:57 AM
Top Automotive Fails of 2009 S2KtoFT86 Other Vehicles & General Automotive Discussions 8 01-28-2010 07:13 PM
