Old 10-11-2012, 12:16 AM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Pulled battery for 5 minutes, now massive gas pedal slop
I really don't know what to say about this. I was experiencing rough idle issues, no code, and figured pulling the battery to let the car go back into relearn mode may help the issue.
Anyways, I just took it for about a 20 mile drive around town and was driving like an idiot. Missing downshifts, almost stalling off the light. I couldn't figure out what was wrong. Then I tried to rev the engine at the light. Much to my amazement I now have about 2 inches of dead gas pedal.
How the hell do I fix this? Before if I so much as let my foot rest on the gas pedal the RPMs would climb. Now I need 2 inches just to get them to start crawling up...
[ame="http://www.youtube.com/watch?v=gU9lSIvnSjw"]FRS Pedal slop - YouTube[/ame]
post_break is offline   Reply With Quote
Old 10-11-2012, 12:46 AM   #2
CMOS
Drives: 2012 FUJI Z
Try rebooting again, see what happens, if you got a scangauge or equivalent, make sure the throttle position looks right. Throttle is supposed to work off differential voltage so there should not be issues with that or we have another massive recall situation since the reverse of your condition would be unintended acceleration. Might be your computer messing up the voltages or not engaging at proper voltage level then trimming back thinking the sensor is set further out.
CMOS is offline   Reply With Quote
Old 10-11-2012, 12:49 AM   #3
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
After resetting the ECU you're also normally supposed to let the car idle for at least ten minutes without any throttle. The mapping needs to relearn the atmosphere.
I'm not sure if this still stands for newer cars.
TOMIMOTO is offline   Reply With Quote
Old 10-11-2012, 01:00 AM   #4
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
@TOMIMOTO is correct. When you first start the car, the throttle needs to relearn its position at idle. DBW cars do not have the Idle Air Control valve found on cable throttles. The IAC lets a little air through while the throttle is fully closed. DBW always leaves the throttle cracked open a bit at idle.
Reset again, and let it idle for ~5min. It should settle in, and you'll get your throttle back.
TheRipler is offline   Reply With Quote
Old 10-11-2012, 01:00 AM   #5
gmookher
its about two mins
Old 10-11-2012, 01:34 AM   #6
CBR600RR
Drives: Raven Black
The music makes it impossible to hear the engine rev. Why the useless music?
Old 10-11-2012, 01:48 AM   #7
post_break
post_break's Avatar
The stock exhaust is on the car, the engine was not revving at all, idled the whole time.
Old 10-11-2012, 01:50 AM   #8
post_break
post_break's Avatar
I let the thing run for 10 minutes before leaving, and nearly stalled it out of my parking spot (but didn't realize this was the case). I also own a 2011 mustang and this is the same procedure. Pull battery for 10, reconnect, let idle for 10. Usually it's a good thing to do once and a while. I'm regretting it this time.
Old 10-11-2012, 02:02 AM   #9
Those Meddling Kids
Drives: 2013 SWP BRZ limited
Normally Subaru DBW does a check at key on and will set codes for any abnormal operation. I would try unplugging the negative again, hitting the brake pedal a few times and then reconnecting. Upon turning the engine back on listen for the throttle blade opening and closing at first key on.
Those Meddling Kids is offline   Reply With Quote
Old 10-11-2012, 02:12 AM   #10
Yruyur
Yruyur's Avatar
2 minutes then a little driving around. Its normal as the ecu has to learn. When doing the Visconti tune we all experienced it. After 50 miles or so all was well.
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
Have you been pulled over yet? shire1976 AUSTRALIA 47 09-23-2012 07:44 AM
pulled the trigger after 22 minutes. robbins226 Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 12:55 AM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 07-01-2011 12:58 AM
Richard Hammond (Top Gear) predicts Toyota FT-86 will be massive success Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 36 03-20-2010 02:23 PM
