Old 10-10-2012, 12:08 PM   #15
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Originally Posted by RYU View Post
For all you guys asking Where, How-To, etc...
Please read this before asking specific questions
http://www.motoiq.com/magazine_artic...cion-fr-s.aspx
So that's saying the Sti brakes limit the tires you can put on it?
"CulbyJack"
gmanculb is offline   Reply With Quote
Old 10-10-2012, 12:13 PM   #16
RYU
RYU's Avatar
Drives: really slow...
"CulbyJack"
You mean the wheels due to caliper clearance?
Dude, you're scaring me...
RYU is offline   Reply With Quote
Old 10-10-2012, 12:14 PM   #17
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Yea It just didn't come out right. Lol
"CulbyJack"
Old 10-10-2012, 12:29 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Wheel clearance issues for big brakes like brembos is nothing new though. Just need the right offset and width
Old 10-10-2012, 12:33 PM   #19
Do Boy
Turbo FR-S
Do Boy's Avatar
Send a message via ICQ to Do Boy Send a message via AIM to Do Boy Send a message via MSN to Do Boy Send a message via Yahoo to Do Boy
So I need 08+ rear brembos to do the rear brakes?
Do Boy is offline   Reply With Quote
Old 10-10-2012, 12:41 PM   #20
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
No idea, but these are going to be arguably worse performing than stock considering they were designed for a different car.
Thats why david was recommending going with a kit designed for this car.
blu_ is offline   Reply With Quote
Old 10-10-2012, 12:57 PM   #21
Do Boy
Turbo FR-S
Do Boy's Avatar
I have just the fronts on right now. I can tell you this they don't perform worse .
I'm going to attempt the rear tonight with the 04s I have and see what happens.
Old 10-10-2012, 01:03 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Do Boy View Post
The rear isn't worth it or the whole setup in general? BC these brakes for me are free.
I meant if you had to buy them. The pricing makes it a bit pointless for most people who just need more heat capacity in the rotors (the main point of bigger rotors for me, and many others).
Depends on your goals.
BTW did you switch the bleeders or are the calipers installed wrong? (differential bored calipers...)
As for the rears, they will be a lot harder because of the parking brake stuff I'd guess but I haven't done it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-10-2012, 01:04 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by empower-auto View Post
FYI to some people .. you can buy reman'd STi calipers for CHEAP .. and often they come loaded.
Where? I never found any cheap ones on ebay so that info will help others for sure!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-10-2012, 01:10 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Balance is possibly screwed up but most wouldn't notice especially on the street. I was talking more from an expense perspective. When I last checked ebay (months ago) the whole setup, once rebuilt, would cost 2-2.5k if you had to buy everything new (minus calipers, used then rebuilt for those) and I'd want the backs if I did the front to try to maintain balance.. and then hopefully the BMC will be sized appropriately too.
Haven't done it though so who knows. I'm going with the Essex kit since it gives me a lot more cooling and heat handling up front and keeps the balance.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-10-2012, 04:49 PM   #25
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
If you install the whole front and rear STi Brembos, I would think that if you upgrade the master cylinder that it'd be much better as opposed to stock master cylinder. After all, you've got 12 pistons total to move on the Brembos as opposed to 4 pistons total on the stock calipers. Yes, the pistons are smaller on the Brembos, but still they have a lot more volume overall with the added pistons. I wonder if the STi brake master cylinder bolts on? Has anyone tried?
Mark Slide Squad is offline   Reply With Quote
Old 10-10-2012, 05:45 PM   #26
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Is there a difference in the calipers from the current STI or the last STI?
TouchMyHonda is offline   Reply With Quote
Old 10-10-2012, 07:19 PM   #27
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
The BRZ has a massive master cylinder for its size. I have a feeling it may be as big, if not perhaps even bigger than the STI. I wish someone can led me their STI to compare and measure.
ps. I'm in the process of rebuilding a set of Brembos (have front and rear), etc.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 10-10-2012, 11:57 PM   #28
yo$hi
yo$hi's Avatar
Drives: 2013 WRB Subaru brz
The front brakes literally bolts right up no questions asked. . . . I did the install personally and all I can say from experience is that this is by far the most painless thing I've ever done. I've taken dumps that were Harder to do then this swap... we haven't had a chance to do the rears yet but if it's anything like the fronts, outs should be a quick swap. We test drove the car after the swap and from a 70-0 under hard breaking the abs kicked in and worked great and we came to a very quick halt.
The only real concern's are these.
1.) clearance due to the size of the brembos. Do boys offset was Damn near perfect in the front and has plenty of room in the back.
2.) switching the calipers to make sure the bleeder screw is pointing up so you can bleed the system. On the sti the calipers are on the back of the rotor while the frs/brz are facing the front. So you have to take the right side brembo off the sti and put it on the left side of your frs/brz.
yo$hi is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
