Old 10-09-2012, 03:05 PM   #15
NemeGuero
http://heatedseatkits.com/
NemeGuero is offline   Reply With Quote
The Following User Says Thank You to NemeGuero For This Useful Post:
einzlr (10-09-2012)
Old 10-09-2012, 04:35 PM   #16
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by NemeGuero View Post
Originally Posted by Jason952 View Post
Much easier and cheaper to use one of these:
Rostra
I've had them in any cars and work great...the brz switches look as cheap as these so no worries, or mount them out of sight
Thanks for the heads up guys but I'm not exactly trying to do this the easy or cheap way
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-09-2012, 04:39 PM   #17
einzlr
Drives: several
Thanks for this! The website includes the instruction sheets. So you do need to pull the seats apart, makes sense. I can't really work on cars much where I live, but my mechanic could do this easily enough.
einzlr is offline   Reply With Quote
Old 10-09-2012, 09:27 PM   #18
NemeGuero
Just use the OEM switches but those are higher quality than the OEM suby stuff for sure. That site provides a lot of OEM manufacturers.
Old 10-09-2012, 09:55 PM   #19
Jason952
Yes, rostra is the oe supplier for most factory option heated seats. The point of them is not they are easy and cheap but that they work better while saving money and time trying to chase random factory parts. I'm going with the dual switch model!
Jason952 is offline   Reply With Quote
Old 10-16-2012, 09:33 AM   #20
xcelir8brz
Drives: 2013 BRZ Limited
FWIW -
Just as a heads up, my 2013 Subaru BRZ Limited Passenger Heater Switch is broken. I literally flipped it about 5-7 times this morning for the first time and it became soft/unresponsive. I found this post and it helped. I also did a shitload of searching to find out these switches are made by Nissan and can be found on Ebay. I just spent $25 on a replacement switch. Average cost is about $25-$28 used or $50 shipped new. Ouch. The stock switches IMO are not high quality.
Oh, and compared to other cars I've owned, the seat heaters in this car are 'decent' only if the thermostat (any chance you know where it is located?) stays on longer than it does not.
And another BTW - I tried the drivers heat seater last week for the first time, was hot for some time, then smelled something burning, and then it got cold. Now, for some reason it doesn't seem to get as hot as it used to and definitely not as long. I sat in the passenger seat this morning and it took a long time to get hot, and then the damn switch broke.
Ugh!
xcelir8brz is offline   Reply With Quote
Old 10-16-2012, 10:05 AM   #21
CaptainSlow
CaptainSlow's Avatar
If you're dead set on doing it, I would suggest buying the components and taking the seats and the parts to a shop that specializes in automotive upholstery to have them install everything correctly. The last thing you want to do is struggle with removing a seat skin only to rip something, break something, have something bunch up, move, etc. It's a pain in the ass, and would be worth the cost to have a professional do it for you.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-16-2012, 10:56 AM   #22
NYNOMAD
Drives: BRZ WRB LTD MAN
Mine just dont stay warm - anyone know where the thermostat is and if its adjustable?
NYNOMAD is offline   Reply With Quote
Old 12-04-2012, 07:03 PM   #23
xcelir8brz
I thought they were shit. Then two weeks of continued use broke something in and now they are good.
Old 02-07-2013, 07:31 PM   #24
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
How did it end up turning out? Are you happy with the result? Are there no additional parts besides the heating elements and switches?
I'm installing JDM leather/alcantara covers in my car and if your install went well I was going to duplicate
1010110 is offline   Reply With Quote
The Following User Says Thank You to 1010110 For This Useful Post:
Sco2355 (02-07-2013)
Old 02-07-2013, 08:56 PM   #25
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
If past (Subaru) history applies to this car, none of the wiring for the seat heaters are there. You'll have to fab up all the wiring.
ZC6BRZ is offline   Reply With Quote
Old 02-13-2013, 07:57 PM   #26
kndonlee
Yea i looked at the wiring diagrams and the wiring harnesses are definitely not modular. Getting heated seats or the fual climate controls would be a huge electrical maze to wire up from scratch.
Though building a custom harness should be possible, the question is where can we get the ends without spending $800 on a new harness.
kndonlee is offline   Reply With Quote
Old 02-14-2013, 10:38 AM   #27
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by enjoi23 View Post
It would have been cheaper to buy a BRZ and then transform it into an Fr-s, then to transform an FR-s into a BRZ.
Please do explain, other than the headlights which cost a lot OEM. please do explain
Old 02-14-2013, 10:44 AM   #28
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
So if you want heated seats, auto climate control, HID, keyless start, alcantara, it's more expensive to retrofit these parts on top of a fr-s than it would be to buy badges and a front bumper for a BRZ
Block Heaters for those that might need them smbrm CANADA 17 07-22-2014 05:56 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
