Old 10-07-2012, 09:58 PM   #15
diirk
diirk's Avatar
Drives: 4Runner
I've used my OEM jack a couple times now with no issues. I actually like it. It's pretty quick for a scissor jack.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-07-2012, 11:42 PM   #16
Marrk
Drives: Honda Fit
Originally Posted by FRiSson View Post
Who has the room to keep a hydraulic jack in the trunk? Not to mention having it shift around during hard maneuvering? No thanks.
Indeed. That post is ahead in the Stupid Post Sweepstakes.
Marrk is offline   Reply With Quote
Old 10-09-2012, 06:15 AM   #17
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Bottle jacks aren't particularly large, and it's not terribly difficult to affix to something such that it doesn't move about as you drive.
Brett
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 10-09-2012, 06:57 AM   #18
JDMenrique
DEEEERP
JDMenrique's Avatar
The person who posted this on FB has put a picture of the jack up. I can log on to it cuz on im a goverment computer. Ill post it once i get home.
JDMenrique is offline   Reply With Quote
Old 10-09-2012, 10:11 AM   #19
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Keep a jack stand or two in your car at least. The scissor jack should be able to get it up, but I have not and never will trust one. Hell, I put my tire under the car even when I have jackstands. I mean, can't hurt. Lol
Old 10-09-2012, 12:33 PM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
This thread is worthless without pics
The OEM emergency jack is standard issue that’s been in cars for as long as I’ve been alive.
Hell, back in Russia this was the ONLY jack I ever knew of, I have personally used such a jack about 6 times on a variety of vehicles ranging from lightweight eight Ladas to Dodge Caravans.
I have already been required to use it on my FRS when I blew out a tire catching a 1mm allan key on the freeway.
The jack must be placed in a specific zone under the car along those vertical rails, perpendicular to the road, on level ground
Although it has been done in more adverse conditions… :/
Some of this fear mongering is unfounded. Would I just lay under the car on the freeway under severe crosswinds twiddling my thumbs? No. Hell I wouldn’t even do that if the car was on proper jackstands, freaks the shit out of me.
But for quick roadside repair of deflated wheels the jack works and IS reliable.
And if you think the jack in the Scion/Subaru is scary, go look at the one they (used?) to put in Volkswagens.
Old 10-09-2012, 12:37 PM   #21
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
I used mine a couple weekends ago, the car sat on the emergency jack for near 30 minutes without a hiccup. Easy to use and quick compaired to other's I have used (the low clearance helped).
5hairpins is offline   Reply With Quote
Old 10-09-2012, 03:48 PM   #22
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Hachivic View Post
This. That's what i learned in school. Happend to me before when i jacked up the car on a windy day. Car was shaking heavely and fell of the jack onto the wheel.
I got a flat tire on my Murano SUV on bridge. wow shaking so badly on bridge. as soon as i raied up enough, this emergency jack just fell. thank god i didnt even start taking out my wheel. i just called road assistance.
it's good to carrying hydraulic jack but it's heavy and big.
unless it's flat surface and safe to work on,
Old 10-09-2012, 03:57 PM   #23
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
This pretty much shows how german over engineers things that should be kept simple and reliable.
Rayme is offline   Reply With Quote
Old 10-09-2012, 05:53 PM   #24
JDMenrique
DEEEERP
JDMenrique's Avatar
here's the pic.
Here's the link: https://www.facebook.com/photo.php?f...type=1&theater
Again, im not trying to meddle in anyones business but if the guy had an issue with a piece of equipment im just trying to pass the word.
Old 10-09-2012, 05:59 PM   #25
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I used to use Dodge/Chrysler emergency jacks (they had a 19mm hex drive on the end of the screw) along with a cordless drill or impact to jack my car up at autocrosses to swap tires. They usually lasted about a season before they failed or appeared to be unsafe to use. I'd just buy another for $10-20. I'd always make sure to be on a flat, hard, level surface, I would never get under the car when just supported by the emergency jack, and most of the time I was dealing with rather lightweight cars. Back then the Neon I raced weighed 1990 lbs.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-09-2012, 06:25 PM   #26
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by JDMenrique View Post
here's the pic.
Interesting... is there any other ppl had same problem w FR-S/BRZ emergency jack?
Old 10-09-2012, 07:16 PM   #27
Foobar
SLO NO MO
Foobar's Avatar
here's the pic.
Looks like it was raised too high and then the car pushed against it sideways. Not sure how it did that with three other tires on the car.
Old 10-09-2012, 07:19 PM   #28
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
keep in mind you're never supposed to over-extend the jack, you only need to lift the car a hair off the ground so the wheel can be pulled off/on.
i'm no engineer but when you turn what is supposed to be a rhombus into a straight line (that pivots on the bottom point no less) you'll get instability
again there is more to this story
just like the people who use torque wrenches to untorque things, or overtorque things with normal wrenches then think everything is fine if their torque wrench clicks when they "check" it... and the list goes on.
$10 Jack Buddies blalor DIY (Do-It-Yourself) Guides 24 10-20-2017 07:16 PM
usb/3.5 jack relocate + usb charger BRZranger Electronics | Audio | NAV | Infotainment 22 11-13-2012 10:42 PM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 01:53 AM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
Jack Spots? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-11-2012 09:09 AM
