Old 10-07-2012, 04:34 PM   #1
dale.m
Captain Slow
dale.m's Avatar
Drives: 2013 Firestorm FR-S
Are my accessory jacks plugged in?
Now I know the best way to tell if the usb and 1/8th jack are plugged in is to pull them out of the jack, but before I do that I'd like to diagnose the issue I am having. I had the dealership I bought my FR-S from install the BeSpoke head unit into the car. The bluetooth integration works fine, however when I try to plug my iPhone 4s into the accessory port using the usb cable, nothing happens at all. The phone dosen't charge, the BeSpoke or multimedia source are not selectable options on the head unit when browsing sources. The only options I have with my phone plugged in are am/fm radio and bluetooth. I do have the app installed on my phone. Did the dealership forget to plug the accessory jacks back in, or is this just normal operation. If so, how do I get the BeSpoke and multimedia sources to work. Thanks guys!
Dale.
Flying and Driving.
dale.m is offline   Reply With Quote
Old 10-07-2012, 07:29 PM   #2
paaji
paaji's Avatar
Drives: BA Falcon, GT86 on order
Pull the head unit out and check. A few cars have been delivered in this state.
Sent from my GT-P1000 using Tapatalk 2
paaji is offline   Reply With Quote
The Following User Says Thank You to paaji For This Useful Post:
dale.m (10-09-2012)
Old 10-08-2012, 08:45 AM   #3
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
When i first got the car I pulled my BRZ radio to do some work behind it. When I put it back together my USB and Aux did not work, pulled the radio back out and the plug for these two had fallen down behind the A/C controls so I didnt see it when plugging everything back up. Probably a similar situation, should be an easy fix.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
dale.m (10-09-2012)
Old 10-09-2012, 12:14 AM   #4
dale.m
Captain Slow
dale.m's Avatar
I pulled it out and the gray cable that comes from the accessory jacks was not plugged into the headunit. Instead, there was a similar short grey cable that was plugged into the jack that had a different female connecter on the end of it. I searched for a mate, but there was none. After I plugged in the cable from the accessory jack and removed the cable that was originally in the slot, the ipod and pandora functions began to work.
I am having a new problem now. When I try to load up the bespoke source, an error message pops up that wants me to check my video connections or contact a service tech. Any ideas of what the issue might be now?
Thanks guys!
Flying and Driving.
No more Kicker sub dealer accessory? MrH Electronics | Audio | NAV | Infotainment 14 02-27-2013 09:45 PM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
STi's newest accessory!!! Godzpeed Off-Topic Lounge [WARNING: NO POLITICS] 7 07-08-2012 01:21 AM
FIRST 86 Intial Accessory Options GodSays Scion FR-S / Toyota 86 GT86 General Forum 18 05-04-2012 08:04 PM
Partial Accessory Pricing MrBRZ Scion FR-S / Toyota 86 GT86 General Forum 1 04-25-2012 12:02 AM
