Old 10-08-2012, 02:48 PM   #85
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by TouchMyHonda View Post
I have a feeling that 8.5 wouldn't be a problem at all with springs an retainers.
dont forget accelerated is pushing 9k rpms on the stock valve train at 400+ whp
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
tripjammer (10-09-2012)
Old 10-08-2012, 03:06 PM   #86
Kids Heart
Kids Heart's Avatar
Drives: 2013 BRZ Limited SWP
Has one blown up yet? Besides D1 HKS
Kids Heart is offline   Reply With Quote
Old 10-08-2012, 03:18 PM   #87
Opposed
Drives: 2013 Asphalt FR-S
Not from boost that has been reported yet...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-08-2012, 03:53 PM   #88
jkonquer
Drives: 2005 Subaru STI
so im guessing this FA20 is a far better engine than a ej20 or 25?
WRX engine will never get anything close to that in a stock form, not to mention such a high rpm.
jkonquer is offline   Reply With Quote
Old 10-08-2012, 04:03 PM   #89
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
seems like it's finally better built. the EJ has been around forever. subaru had to at least replace it with something stronger. 06 and up just seemed so problematic.
don't forget, 04 and 05 sti's were holding 400-500whp for a while on pump gas on the stock internals. eventually the boost killed them.
it's all a matter of time. the FA will hold, but not forever. i give them a couple thousand miles before they pop.
VSGTS14 is offline   Reply With Quote
Old 10-08-2012, 04:03 PM   #90
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The ej20 and ej25 dont have this compression thats why. If you drop the compression down to where the wrx motor is, youd see the same numbers, or similar.
Tansey86 is offline   Reply With Quote
Old 10-08-2012, 04:41 PM   #91
subatoy
subatoy's Avatar
Drives: subatoy
What?! the high compression ratio is the worst case for the PSI this car is running. so this car holding that amount of boost is really impressive.
subatoy is offline   Reply With Quote
Old 10-08-2012, 04:47 PM   #92
Tansey86
Tansey86's Avatar
I was talking about why the FA20 is making more power in stock form. I agree its very impressive and actually very surprising, but they are using e85, I doubt this car would last more than a few pulls with 93 and more than 10psi
Old 10-08-2012, 04:49 PM   #93
Opposed
He meant power wise. An EJ20 with 20 lbs of boost will make less power than the FA20 because it has lower compression from the factory. Part of the reason the FA is making good numbers on specific boost levels is because of its higher compression. Think about it though, Subaru knew that it was going to run high compression with direct injection. And in order to make a production engine withstand years and miles of running with that high of compression and high RPM's they had to have made it strong for those reasons alone. Kind of like how diesel engines are built strong because of the hight compression they have to withstand.
The Following User Says Thank You to Opposed For This Useful Post:
Tansey86 (10-08-2012)
Old 10-08-2012, 04:53 PM   #94
Tansey86
Tansey86's Avatar
Thank you for understanding.
Old 10-08-2012, 04:59 PM   #95
subatoy
subatoy's Avatar
Drives: subatoy
why would 93 oct. make it worst for this engine to hold boost?
Old 10-08-2012, 05:00 PM   #96
Tansey86
Tansey86's Avatar
Detonation. The octane rating in e85 is much higher(like race gas) and allows you to run higher boost on higher compression without detonation. Thats why companies are making low compression pistons so not everyone needs to run e85 or race gas to have high psi high power builds
The Following User Says Thank You to Tansey86 For This Useful Post:
sho220 (10-09-2012)
Old 10-08-2012, 05:23 PM   #97
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by Calum View Post
True, but you can also get a good idea of how much power they are making by measuring how much power they are making, with a dyno. Oh wait... :happy0180:
Man, I'm really in a mood today. I hope this comes off as funny sarcastic not ****ish sarcastic.
Right, but my point was that dyno numbers can be easily manipulated. You can't change what a car runs in the 1/4.
Ranatsu is offline   Reply With Quote
Old 10-08-2012, 05:27 PM   #98
Opposed
Beside weather, and driver, and altitude, and tires...
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Full FR-S Interior Part Out Evasive Motorsports Interior Parts (Incl. Lighting) 22 01-05-2013 11:17 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
5 Axis FULL BODY KIT?? TRD86 Southeast 7 06-19-2012 09:38 PM
