Old 10-08-2012, 01:44 AM   #57
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Coheed View Post
The 6262 is a lot cheaper. Even my BB unit is way cheaper. Can't beat the GT center section, but the 6262 doesn't utilize cooling lines.
I prefer the design of the precision turbines to the higher trim GT T350 turbine. Seems a better match to the compressor size. Call me crazy, but I think a GTX3576r would be sick.
Both turbos are awesome, can't go wrong with either.
For a street kit I think the gtx3582r would suffice.
Tansey86 is offline   Reply With Quote
Old 10-08-2012, 01:53 AM   #58
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We've use both precision and garrett turbos with great success. We chose to go the garrett route on this project because we use them in our GTR builds and love the way they respond.
The goal with this car wasn't to see if we can make the most power. It was to build a kit that can be slightly altered for all types of driving/racing.
FullBlown is offline   Reply With Quote
Old 10-08-2012, 02:18 AM   #59
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Originally Posted by subatoy View Post
this is awesome, congrats!
I feel so much better about the 5psi I'm planning on running on my car!
I was thinking the same. Wish there was more long term data.
RedRocket is offline   Reply With Quote
Old 10-08-2012, 02:21 AM   #60
Tansey86
Tansey86's Avatar
Well then congrats, youve obviously hit the nail on the head.
Old 10-08-2012, 02:23 AM   #61
os86
Drives: 2jz
Great results Full blown!!
Will you continue to test this kit and see how long it survives?
The real question is how much power can be sustained long term.
This however confirms running 300 - 350 hp would be ideal for daily/ track use and should be enough to blow some of other cars.
nice one
os86 is offline   Reply With Quote
Old 10-08-2012, 05:21 AM   #62
KamalT
Drives: Pearl 86 GT
Congrats on the power.
If you where choosing a motor for mountain and twisty roads and maybe circuit work, which setup would you use. These setups seem more for drag and high speed run.
Good job on the setup.
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 10-08-2012, 05:38 AM   #63
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Too bad the tracks are all closed here. I can see this running 10's when it's dialed in. We still have stock suspension and tires on the car lol
I know a track where we could test this.
TheRipler is offline   Reply With Quote
The Following User Says Thank You to TheRipler For This Useful Post:
LeeMaster (10-10-2012)
Old 10-08-2012, 05:47 AM   #64
os86
Drives: 2jz
To be very honest, the gt35r will be laggy on this motor, as mentioned the power will be uptop but laggy down low.
I would stick with the gtx2871 which will turn 86 into a response machine
Old 10-08-2012, 05:53 AM   #65
Baker
Baker's Avatar
Drives: Orange gt manual
Time 4 twins :P
Very impressed Cant wait to see the others to respond.
1uz cressida with ems 8860 one day to be S/C (last rwd (car) toyota preduced in australia). And now a Gt 86 some day to be turbo
Baker is offline   Reply With Quote
Old 10-08-2012, 06:21 AM   #66
Visconti
Drives: 05 STi
About time someone stepped up.
Now get that queen off the dyno and show is track times...
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
DanVIIIVI (09-08-2013)
Old 10-08-2012, 06:21 AM   #67
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
This shit is CRAZY!!!!!!! GREAT JOB!!! fucking right!! Guess the HP race is gona be between Yall and Don over at AP
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-08-2012, 06:22 AM   #68
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
WELL said sir!!!!!! Don and everyone looking to make max power out of this FA20 will sure be tempted to start!!!
Old 10-08-2012, 07:32 AM   #69
Calum
That Guy
Drives: 2013 asphalt FRS MT
Track times can vary so much they are even less reliable then dyno numbers. There's three tracks within a four hour drive of me. The same car, same driver, same setup and similar weather will yield about .70 second difference from the fastest to the slowest track.
Different drivers, different suspension setups, different tracks and different weather could easily add up to give a full second difference.
Also, Don has been very tight lipped about the setup of his car so even if they did bother to go to the same tack on the same day they still wouldn't know if the comparison was apples to apples or not.
These threads are about making power, and these guys are now making the most.
The Following User Says Thank You to Calum For This Useful Post:
Baker (10-08-2012)
Old 10-08-2012, 08:13 AM   #70
cruzinbill
Drives: Argento 6spd FR-S
I knew someone would ask for this haha. We are more focused on making these kits for now.
Someone had to do it, ofcourse its not needed at this point but i still got my money on 750 stock internals.
Did you guys ever post a link of your stage 1 kit? Im still not seeing it anywhere. would be nice to compare prices/kits with others.
cruzinbill is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 10:32 PM
Full FR-S Interior Part Out Evasive Motorsports Interior Parts (Incl. Lighting) 22 01-06-2013 12:17 AM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 10:32 PM
5 Axis FULL BODY KIT?? TRD86 Southeast 7 06-19-2012 10:38 PM
