Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-07-2012, 07:23 AM   #29
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
How long is a piece of cheese?
Old 10-07-2012, 08:04 AM   #30
Cappuccino
Drives: 2012 Tornado Grey Toyota 86 GTS
Originally Posted by st162celica View Post
All catless exhausts are illegal on the road. Its there for a reason. . . Im sure it would affect waranty too.
The fine is about 10k for this sort of thing isnt it ? I had a blocked egr valve on the celica and found out i would have copped a massive fine if the car was epa? (polution) Tested ?
Pretty sure its 15k but you do get a warning first time round...but I can see that warning being thrown out the window on a brand new car.
Originally Posted by tibsy92 View Post
Wouldn't the ecu also chuck a fit?
To put a higher flow cat converter on my previous vw they said I'd need a reflash.. hence voiding warranty all together..
ECU on modern cars can actually relearn....wouldn't throw any warning signs ECU would just compenstate for the extra flow. No different to running a Hi Flow Cat. Obvisiouly to get the most out of it a tune is recommended. But the smell of fuel can be pretty annoying on a daily.
Cappuccino is offline   Reply With Quote
The Following User Says Thank You to Cappuccino For This Useful Post:
tibsy92 (10-07-2012)
Old 10-07-2012, 08:17 AM   #31
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Also, does zinc coating really help rust forming on rotors? I know Stoptech do zinc-coated rotors to help prevent rust. I'm gonna get some Hawk "low low dust" pads.
yomchi1989 is offline   Reply With Quote
Old 10-07-2012, 08:21 AM   #32
crimespree
Drives: 86
it is very different. depends on the car but most modern cars have at least a pre and post cat 02 sensor, if the readings are not within spec then the car will eventually throw an error, high flow cats need to actually work if they are to avoid this.
crimespree is offline   Reply With Quote
The Following User Says Thank You to crimespree For This Useful Post:
Old 10-07-2012, 08:26 AM   #33
Cappuccino
Good point! Use to having cars with just one sensor before the cat.
Old 10-07-2012, 09:46 AM   #34
dangerfield
dangerfield's Avatar
Drives: Toyota 86 GTS 6AT (Tornado Grey)
I have had no issues with my GPS on the 86 and I use it everyday.
Richard BRZ comes with an Eclipse stereo instead of the Fujitsu Ten that is found in the 86
Eclipse = Fujitsu Ten. Same unit, maybe slightly different model at the very most
dangerfield is offline   Reply With Quote
Old 10-07-2012, 10:25 AM   #35
70NYD
70NYD's Avatar
Drives: RX8 S1
Yes while it's in storage
When you use your breaks, this coating is rubbed off in the part where the pad touches. This part will not get rusty while in use because of the way it works. The rest (where pad doesnt touch) will be coated and. It get surface rust (this is only so it doesn't look ugly and rusty)
70NYD is offline   Reply With Quote
Old 10-07-2012, 10:28 AM   #36
70NYD
70NYD's Avatar
Drives: RX8 S1
Originally Posted by Nardi330 View Post
Catless header is likely to throw a CEL and void warranty. Catless front pipe shouldn't throw a CEL but is still likely void warranty.
Flashing ECU to stop the CEL will definitely void warranty.
What you mean by careless header? Does this car have in-header cats (not uncommon im just not sure)
Oh and as for the purpose of 2 o2 sensors, basically the rear one is there to tell you when the cat dies lol
Old 10-07-2012, 03:01 PM   #37
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
What? In-header catalytic converter? I don't believe you, name one.
Palmy is offline   Reply With Quote
Old 10-07-2012, 03:58 PM   #38
Cappuccino
Suzuki Cappuccino comes with a Cat in the down pipe/header from the turbo and also a cat after the down pipe.
There are plenty especially turbo cars to pass emissions.
Old 10-07-2012, 04:03 PM   #39
Cappuccino
They use a different model then pretty sure it's a higher spec model
Old 10-07-2012, 04:47 PM   #40
Nardi330
Nardi330's Avatar
Drives: 86
There is a cat on the header just after 4->2->1. Our car has 2 cats, the other is on the front pipe.
Nardi330 is offline   Reply With Quote
Old 10-07-2012, 04:53 PM   #41
Sutty
Sutty's Avatar
Drives: Sonic Blue 86 GTS 6AT
Twice as long as half of it.
Where does the white go when snow melts?
Sutty is offline   Reply With Quote
The Following User Says Thank You to Sutty For This Useful Post:
monkie (10-07-2012)
Old 10-07-2012, 06:03 PM   #42
Draco
Drives: Honda CRV
Has anyone gotten themselves a space saver to replace the glue in their newer 86s? Will basically any random one work ie FIT or are there some considerations to be made?
Draco is offline   Reply With Quote
Random pictures thread! switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 8545 04-10-2020 01:58 AM
Random Gifs Thread travace Off-Topic Lounge [WARNING: NO POLITICS] 2 09-02-2012 01:56 PM
Random Sports Thread S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 27 05-03-2012 03:54 PM
Random Picture thread WheelFast Other Vehicles & General Automotive Discussions 2 01-16-2012 02:28 AM
