Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-07-2012, 01:01 AM   #15
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
gahh all these cars do this. very annoying because my girlfriend can use the satnav while i drive.
Surok is offline   Reply With Quote
Old 10-07-2012, 02:34 AM   #16
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Anyone know if the circular 'vents' will allow fresh air to go through to the cabin? or do you have to wind down the windows...
stevo_12v is offline   Reply With Quote
Old 10-07-2012, 02:44 AM   #17
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
yeah you can, cycle air within the cabin, or flow through from outside or you can wind down your window. :P
davey90 is offline   Reply With Quote
Old 10-07-2012, 02:50 AM   #18
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by Palmy View Post
Wait, what?
What features get frozen?
Entering address and calling someone are the two I notice.
Nardi330 is offline   Reply With Quote
Old 10-07-2012, 04:08 AM   #19
tibsy92
tibsy92's Avatar
Drives: Toyota 86 GT Thunder Silver MT
Tachometer indicator needle movement function when starting
the vehicle
When the engine switch is turned to “ON” position (vehicles without a
keyless access with push button start system), or the push-button
ignition switch is turned to “ON” mode (vehicles with a keyless access
with push button start system), the tachometer indicator needle points
to the highest value once and then quickly returns.
■Changing between activated/deactivated
Step 1 Press the “ODO/TRIP” switch repeatedly until the setting
screen is displayed.
Step 2 Each time the switch is pressed and held, the function
changes between activated/deactivated.
“S-on”: Activated
“S-oFF”: Deactivated
This is from the BRZ manual; I am assuming it is the same for the 86.
Ok for the 86 if no one has brought it up..
Put key in ACC not ON.. then press odo trip 4 times and you get G-off.. hold odo trip and it goes G-on......
Haven't figured what it does tho..
Edit: my bad it's a shift indicator for mt according to user manual.. tells you when to shift up for efficient driving.. beeps 3 times
Toyota 86 GT Thunder Silver MT - 22.06.12 ♥
tibsy92 is offline   Reply With Quote
Old 10-07-2012, 04:26 AM   #20
Skorov
Skorov's Avatar
Drives: 86 GTS White
Haha! I was about to say... "Did I just get trolled?" Cos my AT doesn't have that option in Odo/Trip menu.
Skorov is offline   Reply With Quote
Old 10-07-2012, 04:52 AM   #21
st162celica
Drives: 86 GTS Manual - Tornado Grey
Tacho sweep would have been nice.
I dont like the gts sat nav. Dont really want sat nav anyway.
All i wanted was rca outputs, quick response, and fast turn on for a head unit. I got none of those 3.
Another question.
After i turn off the car and open the door some annoying beeping noises start then i close the door and they stop, open again and it doesnt beep. Any way to turn the beeps off !!!
Love my push start, just get annoyed having push it a few times to get acc or radio to turn on, press it one extra time and u have to cycle back through again to get the radio on, then wait for the unit to boot up again.
Annoying, just sayin.
st162celica is offline   Reply With Quote
Old 10-07-2012, 05:33 AM   #22
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
I heard catback exhaust systems won't effect warranty, but what about catless systems?
yomchi1989 is offline   Reply With Quote
Old 10-07-2012, 05:38 AM   #23
st162celica
All catless exhausts are illegal on the road. Its there for a reason. . . Im sure it would affect waranty too.
The fine is about 10k for this sort of thing isnt it ? I had a blocked egr valve on the celica and found out i would have copped a massive fine if the car was epa? (polution) Tested ?
Old 10-07-2012, 05:38 AM   #24
tibsy92
tibsy92's Avatar
I think it's pretty cool for a mt to have this.. now I can attempt to get some more mileage in bumper 2 bumper... and with my local bp having no fuel for a whole week is a worry :/
Old 10-07-2012, 05:40 AM   #25
tibsy92
tibsy92's Avatar
Wouldn't the ecu also chuck a fit?
To put a higher flow cat converter on my previous vw they said I'd need a reflash.. hence voiding warranty all together..
Old 10-07-2012, 06:02 AM   #26
Nardi330
Nardi330's Avatar
Drives: 86
Catless header is likely to throw a CEL and void warranty. Catless front pipe shouldn't throw a CEL but is still likely void warranty.
Flashing ECU to stop the CEL will definitely void warranty.
Old 10-07-2012, 06:06 AM   #27
yomchi1989
n00b
Cheers. Well I am pretty keen on the HKS hi-power spec L exhaust. Does anyone know if this is a catback?
Old 10-07-2012, 06:21 AM   #28
stevo_12v
Yeah it's a catback.
Random pictures thread! switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 8545 04-10-2020 01:58 AM
Random Gifs Thread travace Off-Topic Lounge [WARNING: NO POLITICS] 2 09-02-2012 01:56 PM
Random Sports Thread S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 27 05-03-2012 03:54 PM
Random Picture thread WheelFast Other Vehicles & General Automotive Discussions 2 01-16-2012 02:28 AM
