Drives: 13' WRX
Cusco Braces Review
So I started my day yesterday with the intentions of getting my windows tinted and oil changed/car serviced. Got the tint done, very happy with the results, and made my way to the dealership. Long story short, while the car was being serviced I ended up buying several Cusco parts and made plans to buy the rest at a later date. This is to serve as a write up based on my personal experience with the parts so far. Enjoy.
Parts CUSCO Front OS Type Strut Bar w/Master Brake Cylinder Stop CUSCO Rear Side Crossmember Powerbace CUSCO Front Crossmember Powerbace Install Very simple and straight forward despite the lack of English on the direction. The pictures help orientate yourself and do a good job of helping visually spot the mounting points of each product. CUSCO Front OS Type Strut Bar w/Master Brake Cylinder Stop By far the easiest piece to put on the car. Just simply remove the strut tower bolts, back out the brake stop bolt to make room for install, loosen the adjustment on the strut bar, drop on the aligned holes, tighten each one snug, check fitment and then tighten all the way down. CUSCO Rear Side Crossmember Powerbace These two pieces were pretty easy to install as well. You can figure out the mounting points from the pictures. CUSCO Front Crossmember Powerbace For this piece you will have to remove the skid plate and plastice piece underbody panel in order to install it. Both pieces fit perfectly back over it. Be sure to take pics of it before buttoning everything up. Driving Impressions WOW! What a difference in feel, response, and body roll. I can really feel the road now when turning in and the car just seems to stick, even with these Prius tires. Turn-in response is immediate and tight, takes the little bit of slop in the front end that the car had completely out. Bodyroll is almost non existent! It will be gone once I get the rest of the pieces and coilovers. Thanks for reading, leave comments and questions! Last edited by Unleashed; 10-06-2012 at 05:03 PM. |
#2 |
Gotta love Cusco, they really went all out on the FRS parts. Great write up!
#3 |
im going to assume that is all the placebo effect because im pretty sure none of that stuff affects the body roll in the least
#4 | |
Drives: 13' WRX
I respectively must disagree with you. If all these braces reduce chassis flex, it's going to reduce the affects of body roll, or feeling of body roll. Either way the cornering ability is severely increased! |
#5 |
yeah this is one of those topics where the community is split in two. im glad you like the products. the responsiveness might change but body roll itself is primarily a function of spring rates and the distance from the roll axis and the cog.
#6 |
Drives: White Out FR-S
#7 |
F Z1LLA
Drives: Lexus IS-F Series 2
I have all these installed also., in addition a rear strut brace. As far as making a real difference, I can't say for certain, but even if it's marginal, it"s better than the opposite.
Brake stop on front brace I definitely feel a difference in braking. If nothing else, gotta love the eye candy! ![]() Sent from my GT-I9300 using Tapatalk 2
2URGSE |
#8 |
Drives: 13' WRX
#9 |
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#10 |
Drives: 13' WRX
#11 | |
#12 |
Drives: 13' WRX
I forgot to take pics of the back, I'll do it when I install my Invidia Catback and wheels later this week. |
#13 | |
Drives: 2013 Asphalt Scion FRS
agree to disagree? ![]() Thanks for supporting me in my performance sales venture @ Unleashed, can't wait to try out the coilovers. |
#14 | |
Because compromise ®
Drives: Red Herring
Hypothesis : If there were benefits of a tower brace then the manufacture would have installed one.
I am suggesting that strut braces are relatively inexpensive to make, very little in the way of cons (the only thing i can think of is extra weight). I am also suggesting there would be more benefit in fitting higher durometer bushings as I think there would be more flex in the bushings than in the chassis. I would like to see the results of this: Quote:
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 05-26-2015 11:39 AM |
| Carbing Chassis Braces | ttknf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 08-14-2012 05:04 PM |
| Coilovers, swaybars, chassis braces and more! | No Limit Motorsport | Brakes, Suspension, Chassis | 0 | 08-05-2012 11:31 AM |
| strut tower braces made out of bamboo?!? | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 04-02-2010 01:27 PM |
