AVOturboworld
Old 10-05-2012, 02:30 AM   #757
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I would be very happy with 250hp. At that level the motor should last a while too.
jdzumwalt is offline   Reply With Quote
The Following User Says Thank You to jdzumwalt For This Useful Post:
drifter (10-05-2012)
Old 10-05-2012, 02:41 AM   #758
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Originally Posted by AVOturboworld View Post
Looooong day on the road, but about halfway to Subiefest and 86fest.
Do actually have some updates... First day of tuning had it's issues, of course, but we did reach 240whp/222ft/lbs of torque with just 4psi of boost. 240whp was reached at 6800rpm, and peak torque was reached about 3000rpm. For comparison, we started at about 160whp/140ft/lbs, so in a general sense, we already reached our first goal (80whp gain).
It's by no means final figures, as this is by no means the end of tuning. Just getting a feel for the engine and setup right now, then we'll start ramping things up a bit. By no means is 4psi the limits of the turbo or engine, we are just cautious about this and going over everything carefully.
Very much liking the sounds of this... !!
OjiGeorge is offline   Reply With Quote
Old 10-05-2012, 02:56 AM   #759
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Paul, thanks for the update, I hear your congregation claps out loud )
we all consider these numbers as just on-going, but even they are imprezzive !
3K peak torque is same as stock 3K, so that should by no means be less street driveable
pls tell us you got rid of that torque_dip with your ball-bearing precious and gained a flat torque_valley to the redline instead?
I know your approach is stepping very cautious, so I see your warm care in this and thankful for that, but ...
God I wish you could make this kit reaching 300whp on 93, keeping stock injectors (I guess they max out at ~8-9 psi with safe AFR's) and most everything stock
AFAIK ECUTek allows 5 different maps for BRZ\86 ECU, so I'd just love to have 3 maps:
0) boring fuel economy mode \ safe suburbia cruising on a doubtful fuel
1) daily driven face smiling @4psi 240whp
2) having evil fun @8psi 300whp with all that launch controls, flat foot shifts, auto blipping & stuff
also as soon as you make your mind on ByPass\BOV options, let us know please
thumbs up AVO!
MSTiFK8R is offline   Reply With Quote
Old 10-05-2012, 06:26 AM   #760
r0ma
Drives: WRX
sounds awesome, also 240hp on 4psi with a quick tune, seems the UEL header is working just fine, I guess all the groupies were wrong.
r0ma is offline   Reply With Quote
Old 10-05-2012, 07:57 AM   #761
subatoy
subatoy's Avatar
Drives: subatoy
I would be happy staying with those numbers!
Those seem like the most even torque to HP ratios I've seen.
exciting! the car finally has usable torque!
subatoy is offline   Reply With Quote
The Following User Says Thank You to subatoy For This Useful Post:
Old 10-05-2012, 09:11 AM   #762
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I just had a cargasm... 222 TQ @4 psi???? Damn man.... WOW!
Old 10-05-2012, 09:48 AM   #763
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
same here i've been looking for impressive torque numbers not a high hp dyno queen and here it is i can't wait for everything to be finalized.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Sportsguy83 (10-05-2012)
Old 10-05-2012, 10:27 AM   #764
2forme
The torque might go down if they shift the power band up with tuning. But yea, that's a lot of torque. Might have to get a clutch upgrade with that much power.
Old 10-05-2012, 11:19 AM   #765
AVOturboworld
Going back on the road. Saw the dyno pic last night, and my apologies, have no way here of uploading them. Some further tuning on the standard map sensor and going to 5psi saw about the same torque, though coming in a touch earlier, and power increased to 248-249whp at 7000rpm. The hp curve looks like, uh, well, it's not a curve. I think somebody laid down a ruler on the dyno screen. Torque curve has a sharp climb from low revs to 3k, then plateau's for a while. A long while.
From 1500 revs onwards, there is a good 20 ft/lbs more torque than stock, that turbo must really be coming in early. I want this on the AVO USA FR-S right now!
The Following 5 Users Say Thank You to AVOturboworld For This Useful Post:
Apex Chase (10-05-2012), Bonburner (10-07-2012), civicdrivr (10-06-2012), kidgogeta (10-05-2012), Sportsguy83 (10-05-2012)
Old 10-05-2012, 11:24 AM   #766
JoeBoxer
JoeBoxer's Avatar
Tell them to leave it alone that sounds perfect.
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
diss7 (10-05-2012), subatoy (10-05-2012)
Old 10-05-2012, 11:26 AM   #767
fenton
Thanks!
Please try and get a pic of that dyno i think this is the kit that everyone is waiting for. Take a pic with your cell phone if you have to
On another note, does the engine have to be lifted to install this turbo in such a remote location?
fenton is offline   Reply With Quote
Old 10-05-2012, 11:39 AM   #768
subatoy
subatoy's Avatar
Drives: subatoy
yeah don't touch it!!!
Old 10-05-2012, 12:36 PM   #769
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Very exciting! Sounds like you might be nearing perfection here.
Jeff86 is offline   Reply With Quote
Old 10-05-2012, 12:46 PM   #770
subatoy
subatoy's Avatar
Drives: subatoy
AVO, do you know how much the drift office charges to install your kit?
are you guys afeliated? do they do the installation for free when you buy this awesome kit?!
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
