Old 10-04-2012, 11:35 PM   #225
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by Opposed View Post
That is completely untrue and a very old myth. It is very well know that a 3" exhaust on an N/A 4 cyl does in fact NOT lose power or torque. If anything, you gain both of those all across the power band. Most N/A Hondas are running 3" systems that gain more power than their 2.5" counter parts. Just ask Fullblown about how much better S2K's run with 3" systems.
Sorry, that is not untrue. An "exception" to the rule is not the "norm". And I'm sure you "gain" in comparison to stock. But I doubt you gain from a 2.5 system to a 3 on a 2.0L 4banger as being the normal case. I see no evidence of that to call that the norm.
SnapOv3st3r is offline   Reply With Quote
Old 10-05-2012, 12:08 AM   #226
Opposed
Drives: 2013 Asphalt FR-S
Just a quick google search: here's a K20 dyno 2.5" vs 3.0". The 3.0" made power over the 2.5" over the entire power band.
http://forums.clubrsx.com/showthread.php?t=583274
I could show you many more dyno's, but I don't want this to get way off topic.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-05-2012, 12:36 AM   #227
SnapOv3st3r
Go back and read my post again and because I think you missed the context of it. This is not a new thing you know. It's a pretty common understanding.
Side note: Thread in link list...
Stock from valve cover to oil pan
RBC manifold
11" intake with velocity stack/filter combo
Tri-Y long tube header
3" Thermal exhaust
Tuned with K-Pro on my shop's dyno
Hardly just a 3 inch exhaust thrown onto a 100% stock car.
To be honest, it only needed another 5% fuel all over generally speaking. VTEC engagement moved down alot, too, so the high cam VTC map needed ALOT of adjustment.
- Derek
Ummm...yea.
Old 10-05-2012, 05:58 AM   #228
brian_c_m
brian_c_m's Avatar
Drives: Toyota 86 - Silver High Spec
Forgive the novice question but is this kit working with the standard compression ration or has something been done on the engine to lower compression?
If the compression ration is std, is this a concern at all or is the boost low enough for compression not to be an issue?
Thanks
Brian
brian_c_m is offline   Reply With Quote
Old 10-05-2012, 08:26 AM   #229
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Thanks
Brian
This stage 1 kit does not state anything about replacing engine internals... just bigger injectors / fuel pump. I don't see anything worrisome about this amount of boost on this high compression motor (properly tuned of course). As I was trying to say earlier, I ran 16psi successfully for three years on a high compression 4 cylinder import on pump gas with zero issues. Yes, the compression on this motor is higher, but this is really not a crazy amount of boost.
Jeff86 is offline   Reply With Quote
Old 10-05-2012, 12:47 PM   #230
NemeGuero
manifold pictures, please?
NemeGuero is offline   Reply With Quote
Old 10-06-2012, 07:00 PM   #231
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Anything new going on with the car?
Tansey86 is offline   Reply With Quote
Old 10-07-2012, 12:02 AM   #232
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
I heard the 3" exhaust in person yesterday and it sounded amazing. It was a very deep rumble, no rasp or nasal tone. I didn't get a chance to closely inspect it but I told Joe the next time I'd get a better look at it.
Way to go LJ and the team!
BRZerhood & FR-Society
Chupacabra is offline   Reply With Quote
Old 10-07-2012, 11:51 AM   #233
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
What people need to understand is the amount of new technology going into casting processes/forgings and coating and piston design allowing us to run higher compression stock engine with some decent boost without worry. Back in the day you were dealing with worse designs and powdercast rods blowing up with adding just 50hp. Today is much different. Good for us!
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 10-07-2012, 07:03 PM   #234
FullBlown
FullBlown's Avatar
Drives: Scion FRS
http://www.ft86club.com/forums/showthread.php?t=19206 :happy0180:
FullBlown is offline   Reply With Quote
Old 10-08-2012, 10:20 AM   #235
bakerr6
Drives: 2013 raven black fr-s
looks good, I'm almost 99% sure this is the kit I'm going to go with now. Let me know when you have pricing worked out for e85 and launch control. I am just waiting to see what else is coming out during SEMA.
bakerr6 is offline   Reply With Quote
Old 10-16-2012, 02:15 PM   #236
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We are working on packages to trim the cost of the kits for those who don't want all the bells and whistles. For example, we will have a kit that consist of a 38mm wastegate, t3 housing, and the standard gt28 turbo. The kit will still make 300-400hp easily.
Old 10-16-2012, 02:44 PM   #237
NemeGuero
This. I like this.
Where are the pics of the manifold??
Old 10-16-2012, 04:01 PM   #238
FullBlown
FullBlown's Avatar
Drives: Scion FRS
we will have them up tomorrow.
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
