Old 10-03-2012, 03:29 PM   #29
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Originally Posted by simpleisbest View Post
Just tried this. It both lights came on, so looks like everything is off! I'll try this out next weekend. Thanks!
I tried it and it didn't work for me
RAWR BRZ is offline   Reply With Quote
Old 10-03-2012, 05:50 PM   #30
simpleisbest
Senior Citizen
Drives: Scion FR-S
Yeah, I was having trouble repeating the results.
I went over the procedure again last night.
Start the car with the e-brake ON first.
It worked for me and I was able to repeat it twice in a row.
simpleisbest is offline   Reply With Quote
Old 10-05-2012, 03:59 PM   #31
simpleisbest
Senior Citizen
Drives: Scion FR-S
Update: the pedal dance seems to best work when the engine is relatively warmed up.
No matter how many times I try with a cold start, the traction controls won't want to turn off.
Old 10-05-2012, 11:37 PM   #32
Scooter Style
Drives: 2015 BRZ/ Blue Series/ WRB
Originally Posted by 7thgear View Post
not sure if troll, you forgot you had ABS? i think you just forgot you had brakes.
Had ABS on the lexus but disconnected them by disconnecting the wheel speed sensor.
I hate ABS.....
2013 SWP BRZ #137 First BRZ in Columbus, OH! SOLD
2015 WRB Blue Series #900/1000
Team Rowdy
Ohio Native
Instgram brooks_church
Scooter Style is offline   Reply With Quote
Old 10-06-2012, 12:02 AM   #33
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
I haven't had any issues with it comming back on, other than the light that tells you that you lost grip.
I also noticed that you can't have TC fully off and VSC in sport mode. If you turn TC off (5sec) the hit VSC it will kick the TC back as if you only pushed the button.
I was at a high speed autocross and all I did was hold my TC for 5sec to get both off lights.
After that I could but the rear of the car wherever I wanted it, and I have some slides going faster that 30mph
RazBRZ is offline   Reply With Quote
Old 10-06-2012, 11:31 AM   #34
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I have had NO troubles with holding down the TRAC button until the lights turn on. It can be done at any speed.
Here's a video of my sliding the car with no electronic intervention:
[ame="http://www.youtube.com/watch?v=_Jw2_Krx_1g"]7/1/12 OVR SOLO (BRZ Drift) - YouTube[/ame]
Old 12-06-2012, 01:49 AM   #35
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Originally Posted by 086A View Post
Hello,
I was finding this same thing happening to me on some windy roads here. What we are seeing with VSC & TRAC off is yet another system activating, Auto LSD. If one wheel comes off the ground/looses traction it applies the brake to that wheel wheel to transfer the power to the one on the ground/more traction. Used in Toyota trucks and SUVs.
This is what I found after researching the repair manual to turn off VSC, TRAC, and Auto LSD.
What you need to do is put the vehicle in "inspection mode". This mode is recommended for diagnosing safely on a dyno. (Per the repair manual).
I later found out this was called the "pedal dance" by some fellow Lexus friends I have.
Now how to do the so called pedal dance,
First of all, "the disclaimer" Myself and the manufacture WILL NOT take any responsibility for STUPID things you do while in inspection mode. Plus, I am sure the EDR is watching....
These next steps need to be completed within 30sec. So it may take you a few times to get it right. It did for me, but I can't dance so go figure...... Hehe!
Step 1: eng. off in neutral on MT, park on AT, parking brake off on flat ground.
Step 2: start engine apply the parking brake (leave on)
Step 3: depress the brake pedal twice and hold down on the third.
Step 4: while still holding the brake pedal, release and apply the parking brake twice.
Step 5: with the parking brake still applied depress the brake pedal twice. The VSC and TRAC lights should illuminate. (BTW ABS is still active)
Shutting off the ignition and back on will reset it back to normal.
Have some SAFE fun without the auto LSD slowing your exit out of a turn!
Sent from my iPad using Tapatalk HD
it only worked for me when the car is warmed up.. also i started with the ebrake on..
but dont get me wrong isnt this the same as holding the trc button for 10 secs?
imravenit is offline   Reply With Quote
Old 12-06-2012, 02:09 AM   #36
gmookher
mine shuts off and lets me do donuts..
Old 12-06-2012, 03:13 AM   #37
nix
nix's Avatar
Drives: AVO BRZ
go to your dealer, nothing is supposed to grab if both yellows are on.
OP and a few others, you guys got faulty cars so go check them out
You are the one trolling. In multiple threads I've seen you chip in advising people on things you don't know about.
The ECU sends ABS pulses to the loaded rear wheel in this situation even with all electronic aids turned off. That is what people are talking about when they see the extra slip light flash and feel the car only reach a certain slip angle.
I have followed the 'auto LSD disable' feature that 086A posted and it seems to work. Most guys pushing these cars on the track are either pulling the ABS fuse or using a VSC cut like this in order to disable it without impacting ABS.
http://www.autofactory.jp/product/to...?mode=s&seq=14
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
imravenit (12-06-2012)
Old 12-06-2012, 09:15 AM   #38
wparsons
wparsons's Avatar
Hello,
Which wheel does it apply brakes to for the "auto LSD"? I would think that if it's applying brakes to the inside wheel (if it was lifting) it would actually be helpful in putting power down on corner exits since it would be sending power to the outside wheel still instead of unloading the inside wheel?
flickr
Old 12-06-2012, 11:24 AM   #39
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It fully disables for me on track without doing anything beyond holding the tc button down for 5 seconds.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
7thgear (12-06-2012)
Old 12-06-2012, 11:30 AM   #40
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes, i don't know anything about turning TC and VCS off as instructed in the manual and then going wild at an autocross/track without any problems.
Old 12-06-2012, 12:24 PM   #41
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
So if i followhe auto lsd disable step and pull the abs fuse would this solve my problem?
Or u wud recommend buying the trc vsc cut switch u posted?
Old 12-06-2012, 05:47 PM   #42
empower-auto
Kouki-Monster
empower-auto's Avatar
strange enough, it became fully compliant a while back. good to go now!
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
