Old 10-02-2012, 02:56 PM   #1
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Exhaust build up/ burning oil
Anyone else notice that there's is alot of black build up from the exhaust?
basically like what you would see from a car burning oil.
I noticed it from before that the tips were always dirty, now with the SRT exhaust I notice it way more cause after few days of driving tips are starting to go black until I wipe them down.
To me generally it means the car is burning oil, Im starting to monitor my oil consumption between every tank up.
Anyone else notice the same?
Bu-Tang is offline   Reply With Quote
Old 10-02-2012, 03:14 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
mmm I will keep note of this and report back incase anything is happening. It could be the engine "breaking it" kind of deposits that are coming out. Have you had an oil change yet to help clean up the liquids inside of your engine?
Old 10-02-2012, 03:25 PM   #3
Argento_FR-S
Drives: Scion FR-S
It's just unburnt fuel... I'm certain that these cars run a little on the rich side due to the high compression to prevent knock. Also due to the SRT exhaust flowing a million times better than stock more of the unburnt fuel residue is getting back to the tips.
Argento_FR-S is offline   Reply With Quote
The Following User Says Thank You to Argento_FR-S For This Useful Post:
CBR600RR (10-02-2012)
Old 10-02-2012, 03:30 PM   #4
CBR600RR
Drives: Raven Black
^ yup - unburnt fuel. if you have the FRS headerback, you only have one cat now, making the unburnt fuel even more 'unburnt' LOL (I have seen many dyno charts of stock cars that show AFR's that are quite rich)
Note your oil level right after an oil change and then right before the next oil change. I bet you are burning no oil or next to no oil.
Old 10-02-2012, 04:12 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Mine gets black after a while. Im running the SRT header back with a high flow cat. I need to get around to doing some logs for Visconti, I might be running a bit rich.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-04-2013, 12:44 PM   #6
Bu-Tang
hey did you ever find out if you were running very rich up top? mine tips are getting black after only a few drives now and has been that way all winter, and if I leave them unattended they will turn completely black. Same for you?
thanks
Old 04-04-2013, 01:47 PM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
thanks
Yea, I've done some logs and he said it looks good. I should be getting my AFR gauge in soon to monitor it a bit better.
Mine still get black, but it doesn't happen as fast as it used to. I haven't washed the car in about two weeks and they are only slightly dirty. I think it may have something to do with the high flow cat.
Sent from my Nexus 4
Parting out HERE
Old 04-04-2013, 01:51 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
My vehicle does that as well. Seems quicker than other cars I've owned but there's no excessive smoke or dreaded CEL so I guess it's ok.
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 05:56 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 02:31 AM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 10:47 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 01:24 PM
