Old 09-29-2012, 06:14 AM   #43
BRZranger
Originally Posted by Furtive View Post
I tapped mine into the 10 amp ecu ACC , I'm not sure if that's always on... I'll need to buy a multimeter tomorrow to check and see
If it works, can you take a pic of what you're talking about?
BRZranger is offline   Reply With Quote
Old 09-29-2012, 08:00 AM   #44
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by brzranger View Post
Anyone have pics of where to tap into power for the camera? @sure74 did it to his factory amp and I have heard others do it on reverse lights.
You can't tap into the reverse lights unless you start the car in reverse all the time - the head unit needs to detect the camera as powered at boot up, or it decides you don't have a camera.
Are you trying to find something in the trunk area to tap into? I just ran the wiring back to the fusebox. If you're looking for a nearby power lead, I'd go with the stock amp which you can get to next to the spare tire. Apparently the green line is ACC power. Splice into that and ground to one of the amp bolts.
The Following User Says Thank You to Foobar For This Useful Post:
BRZranger (09-29-2012)
Old 09-29-2012, 01:37 PM   #45
xwd
Ordered the same camera and got the PnP harness from SVXdc the other day, hopefully I can do the install middle of next week.
Old 09-30-2012, 04:49 AM   #46
BRZranger
If I connect power to the fuse box, what amp fuse do I need?
Old 09-30-2012, 08:23 AM   #47
Foobar
SLO NO MO
Foobar's Avatar
I used a 10 as thats what I had lying around. I bet a 3.5 or 5 would be sufficient. I doubt these cameras pull much curent at all.
Sent from my Nexus 7 using Tapatalk 2
Old 09-30-2012, 11:51 AM   #48
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Forester factory camera draws less than 100 mA (less than 0.1 Amps).
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
BRZranger (09-30-2012)
Old 10-13-2012, 02:44 AM   #49
BRZranger
Just finished install. I cheated and plugged camera power to the trunk light, which is always "hot". I know I should use the amp power, but I wasn't sure which one to splice not. Am I good the way it is or should I relocate to amp?
Old 10-16-2012, 09:22 AM   #50
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
I'd move it to the amp power, it is the darker of the green wires on the bigger plug
(next to the red wire which is power for the camera).
sure74 is offline   Reply With Quote
The Following 5 Users Say Thank You to sure74 For This Useful Post:
BRZranger (10-16-2012), johnb831 (10-16-2012), tiz22 (11-12-2013), tripjammer (01-29-2013), Vlad (10-17-2012)
Old 10-17-2012, 03:36 PM   #51
BRZranger
Just finished changing the splice location. Thanks for this picture, made it way easier. Camera works great!
I saw another forum member placed his in the middle of the trunk (premium), looms to be the best viewing angle. With the stock location, its hard to see the rear flank on the driver side.
The Rydeen Duo looks great BTW. Only problem with it is that I used painters tape on it to hold it to the trunk for adjusting. When I pulled the tape off, some of the paint came off. I'll have to use some touch up.
Old 11-06-2012, 10:41 PM   #52
developer
Drives: BRZ Limited
How did you connect the camera power wire to the amp power? Is there some sort of connector that I can't see in the picture?
developer is offline   Reply With Quote
Old 11-07-2012, 07:58 AM   #53
sure74
sure74's Avatar
I just stripped about an inch of the wire, folded it over a few times and shoved it in there. I zip tied my wire to the factory amp wires so it wouldn't fall out. The camera has such a low draw that this won't be an issue.
The Following 3 Users Say Thank You to sure74 For This Useful Post:
developer (11-07-2012), TheBRZsKnees (01-16-2019), tripjammer (01-29-2013)
Old 11-07-2012, 11:53 AM   #54
developer
Drives: BRZ Limited
Awesome.
Old 11-10-2012, 07:27 PM   #55
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Thanks for the thread, it's been a big help... I wish I'd read it before buying a camera. I got a license plate model which seemed to be less invasive and now I wish I went this route. Looks OEM!
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 11-10-2012, 07:31 PM   #56
BRZranger
I used a quick splice connector.
The Following User Says Thank You to BRZranger For This Useful Post:
developer (11-10-2012)
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
