Old 06-09-2011, 10:22 PM   #29
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
for my function>form,
Twin Non-Sequential Turbo - Titanium True Duals with twin EGTs for metering
or
id do true duals for a track car..but single exit for best street performance.
WingsofWar is offline   Reply With Quote
Old 06-09-2011, 10:46 PM   #30
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
"true duals" as in 2 headers going 2->1 on each side? That would be a very unique setup, not sure how I feel about that.
chulooz is offline   Reply With Quote
Old 06-09-2011, 11:01 PM   #31
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
not that unique, true duals are common in the aftermarket sector for both 13b n/a rotary engines and many V configuration engines, but the price of true duals over single exhausts turns people away majority of the time.
350z
Mustang
Mercedes
GT-R
Old 06-09-2011, 11:27 PM   #32
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Im with Ichi on this one. A single exhaust will probably be an all around better option for this car. Except for the personal aesthetic opinions but to those I say: Function > Form (within reason of course)
I'm with the two of you as well. No sense in the added weight for me or the added cost. Others might feel otherwise but that is fine too for them.
tranzformer is offline   Reply With Quote
Old 06-09-2011, 11:34 PM   #33
chulooz
Registered you sir
chulooz's Avatar
I was referencing the engine you are talking about having the exhaust on FB20, boxer 4 now find me dozen of those with a true dual.
Haha, yes i realize many other cars have real/true dual exhasts.
Old 06-09-2011, 11:36 PM   #34
tranzformer
Drives: Zoom Zoom
I was thinking the same. I know many 6 and 8 cylinder cars come with true dual exhausts. But are there any 4's that come with a true dual exhaust from the factory?
Old 06-09-2011, 11:44 PM   #35
bofa
Drives: Ms. Daisy
Hm... if that's the case, then isn't that add more weight to the car? Also two separate cat equal to two extra o2 sensors (before cat & after cat)... which means more ecu crap. Also add to that, isn't it gonna cost more for after market parts?
Yep it does have the potential to add more weight, although its entirely possible a true dual made of aluminum or titanium could still weigh less than the stock exhaust.
I honestly haven't done much research on any boxer engines running a true dual setup. If there is in fact a single o2 sensor stock, I imagine the only way to pull it off would be an X pipe in the middle of the system and to mount the sensor there. Maybe we'll get lucky and see two o2 sensors, but I'm not sure that would happen.
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-09-2011, 11:58 PM   #36
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
i think any inline engine that runs a true dual is kinda retarded, because it has a single exhaust bank. I don't think any 4s come with true duals or any flat-4s for that matter even with 2 exhaust banks.
For small engines like the FB20 i don't believe there are enough exhaust gases being pushed out to see any more gains on a true dual setup vs a single exit on a street car. Just added weight.
But once we get to a level of performance achieved in which fuel and engine tuning are more fickle and demanding, a true duals setup helps further monitor engine performance via 2 EGTs or 2 WO2, and provides additional power to each bank separately. But at that point its more like track car status.
Only reason why rotaries benefit from a true dual setup despite being a 1.3 liter is that they physically push an equivalent gas volume of a 2.6L v6.
Old 06-10-2011, 12:02 AM   #37
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
some tuners use only 1 bank for Narrowband o2 for stock ECU. But most use a crossover pipe for 02 as well, but for the main reason of Exhaust scavenging, or quasi-static scavenging effect based on the Subarus firing order.
Old 06-10-2011, 12:09 AM   #38
bofa
Drives: Ms. Daisy
I think you are right in that it might not make sense for an inline 4. For a flat 4 though, I guess we'd have to see some tests. As for the output volume it would really depend on the diameter. If performance gains are realized for say, a 3" single pipe, it would be reasonable to expect similar or even better gains from a true dual with ~2" pipes.
BRZ before hoes
Old 06-10-2011, 12:17 AM   #39
chulooz
Registered you sir
chulooz's Avatar
or
That is my point... why did you say this? true duals are absurd on such an engine.
Old 06-10-2011, 12:19 AM   #40
bofa
Drives: Ms. Daisy
No idea...
And don't get me wrong fellas, I'm not hellbent on a true dual setup, but I guess we at least have something to talk about.
BRZ before hoes
Old 06-10-2011, 12:19 AM   #41
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
The Output volume doesn't depend on exhaust pipe..its the total exhaust volume that the engine puts out. Typically smaller engines don't give big exhaust pulses. Biggest you should ever go on a small engine, small displacement, N/A is a 2.5 in pipe...you can push 2.75 but your risking performance. A 3 inch exhaust will rape your low end torque band and ultimately rob you of power.
Old 06-10-2011, 12:23 AM   #42
bofa
Drives: Ms. Daisy
Yep I realize that... But I have to admit I was thinking of turbo 4 when talking about the 3" pipe (oops). I agree that N/A, 2.5 is probably pushing it. Maybe they will make a turbo version just so we can have true duals (insert I heard there's gonna be a turbo version thread here)
BRZ before hoes
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 11:27 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-26-2011 12:53 AM
PRIZEFIGHT: Toyota or Subaru? Raiden Scion FR-S / Toyota 86 GT86 General Forum 16 10-25-2010 09:04 PM
