Old 09-28-2012, 02:10 PM   #155
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by 7thgear View Post
they should just banned r-comps and avoided creating another 50 classes
I would have no problem with something like a Star-Spec or RS3 becoming the new "#1 tire", at least the majoirty will switch to that, have a tire to drive on for the entire year and have tons of fun
They're banning sub-200 treadwear tires from RT* next year, so hopefully we'll see some serious development in high performance tires that aren't bald after a season.
Mitch is offline   Reply With Quote
Old 09-28-2012, 02:21 PM   #156
dsgerbc
Drives: BRZ(sold), STI
More like, serious development to make balding-in-one-season tires score 200+ ugtg.
Old 09-28-2012, 02:56 PM   #157
skeeler
skeeler's Avatar
Drives: Miatas of Various Kinds
No development is required. There's no standard for treadwear ratings; each company decides on their own how to label their tires.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
skeeler is offline   Reply With Quote
Old 09-28-2012, 02:56 PM   #158
Mitch
Drives: RIP '13 BRZ
Layered compounds :P Super-hard protective layer that lasts 15,000 miles encasing r-compound rubber. Pity the poor soul who buys them not knowing what they are.
Old 09-28-2012, 03:10 PM   #159
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Living in Canada i find it OKAY to buy a set of high peformance summers in the spring, drive and race all summer and then ditch them around November. Then the winters go on.
it's a pretty cost effective arrangement for a weekend warrior, personal opinion.
Old 09-28-2012, 03:21 PM   #160
dsgerbc
The test is fairly standard though, and could end up leading to fines (let's say a competitor complains to NHTSA) if the wear is grossly overstated.
Old 09-28-2012, 03:25 PM   #161
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
there are minimums, but not maximums
a tire with an actual 300 UTQG rating COULD be branded as 140 by a tire manufacturer if it wanted to. Or 80 or 40 or zero...
Old 09-28-2012, 03:32 PM   #162
dsgerbc
My problem with this - is that in November I'm riding on tires that have very little wet grip.
And?
We're talking branding a tire with an actual 100 utqg as a 200.
In general though I agree that those ratings are very squishy. Some might just slap a different utqg stamp on an existing tire and call it good.
Old 09-28-2012, 03:38 PM   #163
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
And?
we're also talking about the general trend of rule generators of limiting tires by UTQG ratings.
today SCCA says 140, tomorrow its 200,
all the while Hankooks tires are actually 300 (hypothetically) but they just chose to brand them as 140
then when the new rule comes out they just put on their troll hats and make their "new" tires at 200.
Old 09-29-2012, 02:57 AM   #164
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
Do you guys turn off TCS on your runs? Anyone try just turning VSA off?
stanm is offline   Reply With Quote
Old 09-29-2012, 03:32 AM   #165
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I always turn everything off before each run. I had a friend of mine who has been autocrossing for 10+ years co-drive my car at an event earlier this year and he felt it had too much oversteer and he was all over the place, so he tried leaving some electronic nannies on for a run or two. The car was definitely more controllable, also a lot slower.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 09-29-2012, 08:55 AM   #166
des
des's Avatar
I accidentally left mine on at the starting line at Nats. By the first corner my screw-up was obvious but not fixable. I adjusted where I could but mainly kept the gas pedal floored the whole time and let the throttle cutout do its job.
On a 70-second course, the difference was about 1.5 seconds. It's probably even more than that, but I had *plenty* of time to pick a great line.
des is offline   Reply With Quote
Old 09-29-2012, 12:29 PM   #167
TRev
Tire manufacturers cheating with UTQG ratings can rather easily be controlled by the exclusion list as long as the SCCA uses it.
During the RTR meeting at Nats my understanding of the 180 proposal for RTR was just that...a proposed rule change for 2013 and not something that was set in stone. It seemed like the majority of people were against changing it unless ST classes were changed so things were equal across the board. My feeling based on the feedback the SEB got from those who attended the meeting was that it will most likely not change for 2013.
TRev is offline   Reply With Quote
Old 09-29-2012, 05:47 PM   #168
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
The problem is the rule did change. So now its a question of will they reverse it by them. I have no chips in this one but I do think it was too fast.
TomR
ABQautoxer is offline   Reply With Quote
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
