#29 |
Drives: bicycle
They'll do just fine in autox since it's mainly low speed. But I wouldn't use any wheel by XXR on a high speed track.
The reason why these wheels are heavy is because they're gravity cast wheels which is also the weakest way to manufacture a wheel. So that's a double negative right there.
#30 | |
#31 | |
The question is, why don't you believe 0.05 seconds can be made up by 20 lbs. |
#32 |
I thought I read .5 seconds... my bad
#33 |
Drives: 83 Toyota Supra, 16 FR-S RS2.0
I use a set of 15 inch xxr002's for autox, they've only had Dot-R/UHP tires, road also. They've been good wheels for me, and unless you autox with a huge, evenly-driven field of identical cars, the time differences caused by different diameters/width in rims, and driver mass will be made up with driver education, effort, and eventual skill. So buy the wheels you want and understand that, yes, any diameter larger than 17 will slow you down.
Eric G |
#34 |
Drives: 2013 BRZ SWP
The XXR 527's are replicas of the Wedssport tc105n. The tc10n's are only 15.4lbs! but they cost a lot more then the XXR's that's for sure. Long term id try to spend the extra money for the Wedssports
#35 | |
Señor Member
Drives: white BRZ 6MT
we're not talking grids vs te37's here. close but not the same.
#36 | |
Drives: 4Runner
diirk
waiting on a Neptune Premium MT |
#37 |
#38 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#39 |
Just the tip
I read an article, that I don't have the link to, that tested Mazda Miata's with identical tires with identical sized wheels with the only difference being the weight (I think it was about 5lbs difference between the two). Times around the track showed that it didn't matter the weight of the wheel. There were laps where the heavier wheel was faster and some where the light ones were. All were very close however. I learned after reading the article that wheels weight doesn't matter. It's all about the drive. Tire compound and tire width does however matter.
#40 | |
Drives: MT WRB BRZ Limited, 2007 911s
#41 | |
Drives: '13 FR-S
| The Following User Says Thank You to CatDaddysBBQ For This Useful Post: | TrqlessWonder (05-22-2014) |
#42 |
Look at Rota Titans. Pretty damn light and still cheap. Good quality. Just not JP quality...
| TSW Wheels (Good/Bad/Experiences?) | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 07-29-2015 09:08 PM |
| DFW Autocross - 8/26/12 | Vanguard | Tracking / Autocross / HPDE / Drifting | 0 | 08-18-2012 07:09 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 11:08 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 04:38 PM |
| Light, wide wheels with good fitment | coyote | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 02-10-2012 05:27 PM |
