| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
there's also 7.5 +40 ce28's/le28s
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#16 |
NW Region Moderator
Drives: FR-S No More
Based on the response that @switchlanez got I am updating the topic title and the Wheel Directory to this: Volk Racing CE28 17x8.0 +38
#17 | |
Drives: Some rust bucket
isn't 17x8 a little wide on 215 tires? maybe they wanted the stiffest sidewall and went with skinnier tires? |
#18 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Bump for an answer to this. I know a 215 would be a bit stretched but it would be fine right? I'm have new wheels (17 x 8 et38) but don't have extra room to store the stock tires and I don't want them to go to waste. Could I run the stock tires til I burn them up and van slap on the 225s I want?
#19 | |
in general, you want to match the wheel width to the tire tread width. each tire will have a different tread width. for example, a bridgestone re11 215/45/17 has a tread width of 8'', and the OEM 215/46/17 michelin primacy tire has a tread width of 7.5''. as you can see, both tires have the same specifications, but they have different tread widths. if you look at pictures of the re11, you'll be able to see that the shoulders are much more squared vs. the OEM. this just shows that even though they have the same specification, they're made to accomodate different wheel sizes. for you, fitting 8'' wheels on the OEM tires will give it a more stretched look than the RE11. you can find the tire tread widths on tirerack.com. hope that helps. |
#20 |
Drives: GT86-JDM
#21 |
Add lightness!
Drives: 17' WRX
New Wheels!
I got bored of my OZ wheels and wanted to go lighter. I found this unicorn rim. Custom diamond black powdercoat. 33 pounds with Dunlop Sport Maxx RT 225/45/17 tires. Saved another 1.6 pounds per corner over my last setup which was -5.4 pounds per corner vs. stock already.
#22 |
Drives: '15 BRZ Limited
33 lbs
| Wheel Directory: Volk Racing CE28 18x8.5 +44 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 73 | 07-24-2015 05:02 PM |
| Wheel Directory: Advan RG-D 18x8.0 +45 | wtf.bbq | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 45 | 09-11-2013 05:36 AM |
| Wheel Directory: ESM 004 18x8.0 +40 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 06-13-2013 02:43 PM |
| Will 18x8.5 +35 Fit all around? | wootloops | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-06-2013 06:58 AM |
| WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** | RavSpec | Wheels and Tires | 59 | 07-24-2012 12:07 PM |
